Front air vents
Ommph
just wanna check.....does any of the A5 owners experience mist-up of windscreen when the aircon is on?
I just collected my car today n when i on my aircon, the lower part of my windscreen misted up!!! if i de-mist, the aircon is almost cut off...is this normal for A5?
If it is not normal, i will send it back to CA fo rectification.
Hi,
I have this problem too, and it is due to the air vent in front of the dash, under the windscreen.
Apparently although even the demister is not turn on, there will still be a small amount of air flow from the vents directing at the windscreen. The extreme in temperature then causes this condensation outside your windscreen. Understand from other vrs owners in briskoda that the flow is normal.
Currently i'm setting the temperature at 22, to prevent condensation.
Likely to bring this up, when i send in for my 5000km service 2 weeks later
Went to CA in the afternoon and talked to the SE. He had agreed to get the mechanic to look into this matter for me, after the mechanic arrange for an appt.
I setted it at 22 but the whole lower part of the windscreen still fogged up.
Will let u know the outcome once the problem is rectify.
Quite a common problem on most conti rides. Happen to my previous Peugeot 206cc and my pal's BMW and Saab. Yeah, they also fix the problem on my 206cc by blocking something in the front vent.
Funny thing is that this problem seldom happens on Japanese rides.
happen on korean ride too...my bro aveo also has misting on the front windscreen...they sealed that vent, now he cant use the demister for front windscreen liao...
Sorry to bring up this thread. My car has this issue too but it only occur at the middle part of the windscreen. Should i go about fixing it? Please advise. Thank you.
I have this issue on my perodua...
Usually turn down the aircon, mine is lower to upper part of windscreen, use wipers sometimes to clean off cos abit too foggy on the outside...
you want to try sealing the vents like some of them here?
