Hulk 1st Gear April 28, 2010 Share April 28, 2010 (edited) i wash my air con filter, no soaking just use tap water run through and the dirt all wash off and dry it next surprisingly still as good...its been 1 yr liao with same filter Edited April 28, 2010 by Hulk ↡ Advertisement Link to post Share on other sites More sharing options...
Kelpie 2nd Gear April 28, 2010 Share April 28, 2010 i wash my air con filter, no soaking just use tap water run through and the dirt all wash off and dry it next surprisingly still as good...its been 1 yr liao with same filter Doing your part to save the environment . I thought of doing that but afraid that once washed, the filtering capability would be reduced especially so for those carbo type. Regards, Link to post Share on other sites More sharing options...
Ryanyusoff 2nd Gear April 28, 2010 Share April 28, 2010 You have to decide whether you wanna spend S$15 to S$20 per pc and change at every 10,000km plus or would you rather spend S$40 to $50 to change the filter at every 10,000km or 20,000km? A expensive filter does not mean it will last longer. Still need to change every 10,000km to 13,000km. I would rather change the ac filter at every 10,000km to 13,000 km. Nothing beats a regular pc of clean filter at regular interval change. thats wat i thought of too.coz my friend keep saying that with the better filtration of the Hepa aircon filter,i will reduce the cost of aircon maintainance in long run...as the aircon filter prevent the dust, and ther particles from going thru to the cooling coil way better than using the normal $15 filter. theoretically,its quite right..but feel like waste of money to be forking out something extra which lasts the same as the cheap normal one. Link to post Share on other sites More sharing options...
Pisces69 6th Gear April 28, 2010 Share April 28, 2010 Nah...Too many things already. Gauges....Then I want GPS....Plus ioniser.....Too much on the dashboard.... ============ Ioniser I plug into ciggy lighter socket. Very small size now. Dont take up much space & very inconspicuous. Keeps the air fresh. Especially good for long drives. U wont feel sleepy. Link to post Share on other sites More sharing options...
Pisces69 6th Gear April 28, 2010 Share April 28, 2010 Apparently,during my first meeting with him, he changed my aircon filter at his place in Teck Whye. No additional charges were incurred. =========== If u going to get the AC filter from him, can u pick up 1 for my Optra also? As long as price is <$15 sud b fine. Maybe I need to change mine already. Link to post Share on other sites More sharing options...
Byond 1st Gear April 28, 2010 Share April 28, 2010 he got 3 places of collection.... u can check with him.... Link to post Share on other sites More sharing options...
Byond 1st Gear April 28, 2010 Share April 28, 2010 ac filters are not like food no expiry date the filters are sealed and locked in clear plastic bag, with a carton box. u keep for 10 years also no issue, as long as u dont remove the packaging Link to post Share on other sites More sharing options...
Byond 1st Gear April 28, 2010 Share April 28, 2010 huh? ur filter will not stink? u sure? Link to post Share on other sites More sharing options...
Byond 1st Gear April 28, 2010 Share April 28, 2010 (edited) hmm... bro take one expensive hepa, take one cheap one use for 10,000km for both filters at 10,000km, when its time to change...ask ur fren do u want to change to a new cheap affordable one and let the air circulate thru the ac filter (ur change will cost u maybe, 15$) or do u want to change to a hepa one costing $40 over to $50 per pc? ur fren might NOT even want to change to a new pc. His thinking might be, this hepa grade one, so good filtration, still can tahan for another 10,000km...cos it costs almost 50$, so just close one eye and use lah by the time the filter is choked with dirt, then he may change to a new pc (another $40 to $50 gone)...say, at 30,000km he would have spend $40 to $50 on one change of ac filter u would have spend $45 on 3 changes of ac filters.... then during this time when the ac filter is filled up with more dirt, lesser air flow passes thru the filter, the cabin should not be as cooled as when u changed to a new pc of ac filter, so what does the driver do? increase fan speed to next level, speed 2 at 10,000km usage.... then when reaches 20,000 km usage, what does he do again when the filter becomes more choked? increase speed to level 3 at 30,000km usage he is just working the nuts out of the air con compresser and air con blower... more wear and tear at the expenses of a S$15.00... when the compressor fails, it dont cost u S$15, it dont cost u $150, the repair costs falls in the region of 500$ to 1000$... no joke leh... there is a saying, prevention is always better than cure... another thing to note : air always recirculate thru the used ac filter at 10,000km, 20,000km and 30,000km mileage before changing u really think hepa filter can filter off so much dust? filter once choked, is considered choked.. not much ways to remove the dust and dirt.. u really think the recirculated air at 30,000km is fresher than air that recirculates thru a newly changed ac filter at every 10,000km? think of the logics... if u take out ur ac filter after 20,000km, u will notice there is a layer of dust and dirt forming on the filter it means the pores of the filters are already filled up...no more space for the dust and dirt to be trapped already, which is why it is choked then only way to push in more air flow is by increasing the fan speed... u are just working the compressor and blower harder, more rpm means more wear and tear.. its a logical thing if the filter pores still got allowance to trap more dirt and dust, they would be inside the filter already, and not forming a layer of dust on top of the dirty filter..... think about it.. Edited April 28, 2010 by Byond Link to post Share on other sites More sharing options...
Hulk 1st Gear April 28, 2010 Share April 28, 2010 (edited) huh? ur filter will not stink? u sure? yes very sure, no stink occurred. But 1 year already, time to change a new one also Edited April 28, 2010 by Hulk Link to post Share on other sites More sharing options...
Byond 1st Gear April 28, 2010 Share April 28, 2010 ac filter are a BATA thing buy and throw away unlike engine filters which can last u a life time lol NOT recommended to wash... the pores of the filters are filled up already how to wash? Link to post Share on other sites More sharing options...
Zniper 2nd Gear April 28, 2010 Share April 28, 2010 mine already 32k haven't change once omg, like tat mine nearing 50k oso haven change before confirm charcoal color liao... Link to post Share on other sites More sharing options...
Byond 1st Gear April 28, 2010 Share April 28, 2010 look for him then.... sure ur ride stinks! hahaha Link to post Share on other sites More sharing options...
Axela72 5th Gear April 29, 2010 Share April 29, 2010 ac filters are not like food no expiry date the filters are sealed and locked in clear plastic bag, with a carton box. u keep for 10 years also no issue, as long as u dont remove the packaging Thx fi=or the info Link to post Share on other sites More sharing options...
GoodCar 4th Gear April 29, 2010 Share April 29, 2010 (edited) Best combination, Carbon Cabin filter plus ioniser ! Don't ever use those perfume staff. Edited April 29, 2010 by GoodCar Link to post Share on other sites More sharing options...
Chiangauto Clutched April 29, 2010 Share April 29, 2010 thanks for your advice.agreed with you,air con filter must change regularly. Link to post Share on other sites More sharing options...
Ryanyusoff 2nd Gear April 29, 2010 Share April 29, 2010 thanks man for the sincere reply.i'll just go for the normal filters then.. Link to post Share on other sites More sharing options...
Yuan 6th Gear April 29, 2010 Share April 29, 2010 ============ Ioniser I plug into ciggy lighter socket. Very small size now. Dont take up much space & very inconspicuous. Keeps the air fresh. Especially good for long drives. U wont feel sleepy. Need to repair my siggy socket. Shorted..... Anyway, I just go for the primitive aircon filter for the moment. ↡ Advertisement Link to post Share on other sites More sharing options...
Change Disc Rotors
Change Disc Rotors
Home Aircon
Home Aircon
Dehumidifier recommendations
Tool to change Spark Plug
