Blackyv Turbocharged April 17, 2007 Share April 17, 2007 well, infact, im not really sure is it advisable but i know mine recommended is 230F/210R and i always pump to 240F/220R on my 16".... what really shock me is the other day, saw one guy pump 300 for all 4 tyres for his 15"... .. i was behind him and saw him pump it till it hits 300kpa... if im not wrong, tyre has a limit and anyone here pump till that level??... actually, that is not all ... after me, one guy with a bicycle waiting after me for air pump also... when i board my car, saw him adjust till 300kpa also and pump his bicycle happily and the tyre seems can take it...... not too surprise about the car but a bicycle tyre also can take 300kpa?.. ↡ Advertisement Link to post Share on other sites More sharing options...
Meloble 2nd Gear April 17, 2007 Share April 17, 2007 Haha, bro, FYI, Bicycles can pump much higher than cars... Road bikes can pump up to 600++KPA ! Don't be surprised, 300KPA is probably a norm for mountain bikes... Link to post Share on other sites More sharing options...
Friendstar Supercharged April 17, 2007 Share April 17, 2007 ya i agree i use to pump 270 for my mountain bike also Link to post Share on other sites More sharing options...
Dwoon 1st Gear April 17, 2007 Share April 17, 2007 I've never followed the recommended pressures stuck on the car door area. Yes, I've pumped to 300Kpa on my stock 16" previously (although recommended was 230F/200R (I think). I usually gauge that the tyres have about 1 baby's foot contact with the ground. For my 17" now, I don't have to go to 300Kpa. About 260 will achieve that. Moreover, there's a warning on the tyre not to exceed 275KPa anyway. Dunno whether advisable or not.... but I've been doing this. Link to post Share on other sites More sharing options...
Watwheels Supersonic April 17, 2007 Share April 17, 2007 Actually for tyres they can max take up to 4~5 times more than their working pressure. 300kPa = almost 3 times the atm pressure ( 1 atm pressure = 101.325 kPa, at sea level) I pump 300kPa for my company's van also. It's like 3 times the normal atm pressure around us. Google and read up in wiki if u wanna know more. The numbers look very big but in fact in atmospheric pressure is not a lot. Link to post Share on other sites More sharing options...
Nhrisuzu 1st Gear April 17, 2007 Share April 17, 2007 (edited) i pump 245F/235R on 15".. recommended is 220F/200R.. Edited April 17, 2007 by Nhrisuzu Link to post Share on other sites More sharing options...
Robin 4th Gear April 17, 2007 Share April 17, 2007 i only do about 230kpa on my 15" .. i think if u over-infate also not good Link to post Share on other sites More sharing options...
Kozen Neutral Newbie April 17, 2007 Share April 17, 2007 Just to check, what gas/air do we usually use for tyre? I heard from my colleague that pumping nitrogen gas to tyres are the best, is it true? Link to post Share on other sites More sharing options...
Nine_eleven 2nd Gear April 17, 2007 Share April 17, 2007 correct tire pressure is related to load index of the tire, not the size.... Link to post Share on other sites More sharing options...
Boyboy 1st Gear April 17, 2007 Share April 17, 2007 not too surprise about the car but a bicycle tyre also can take 300kpa?.. mountain bike knobby tire can take up to 60 PSI MTB slick (road) tire can take up to 80 PSI. Road bike thin slick tyre, 100 over PSI. now, i believe 30+ psi= to 200+ kPa.. not too surprising now eh? i've seen van driver pump over 300 kPa also. in fact, my prev ride, a kangoo, had recommended inflation pressure at just under 300kPa for rear tyres.. abt 280/290? if running on full load. however, for normal car, i believe it's too high. unless toyota alphard or ssyanong stavic Link to post Share on other sites More sharing options...
Cactus Clutched April 17, 2007 Share April 17, 2007 I think its beter to follow the recommended settings.. at least for my case. Whenver I pump 230 and above.. the ride gets very bumpy and choppy, and any road imperfection can be felt, very uncomfy. So usually pump 210F. For rear.. i dont even bother to pump frequently, so long as I see they are still "full". Link to post Share on other sites More sharing options...
Boyboy 1st Gear April 17, 2007 Share April 17, 2007 what's ur reason for overinflating by that much? i'm sure it compromises grip and comfort. FC and steering response (due to reduced sidewall flex) may improve.. but still i keep to within 20kpa of recommended pressure.. btw, what pressure do u use for track (as compare to daily use)? i'm new to it so learning where i can . some say use a bit lower pressure cos tyres heat up. Link to post Share on other sites More sharing options...
Route88 2nd Gear April 17, 2007 Share April 17, 2007 Shouln't be a problem when the tyre is hot (expanding)....the pressure will reduce if the tyre is cold. Link to post Share on other sites More sharing options...
Blackyv Turbocharged April 17, 2007 Author Share April 17, 2007 never knnow bike's tyre can take such load.... Link to post Share on other sites More sharing options...
Dwoon 1st Gear April 17, 2007 Share April 17, 2007 It does to a certain extent compromise on the comfort, if I really over pump. But with one baby's foot contact (flattened length about 8cm), it is still quite alright, unless I hit humps or bumps. Reasons.... hmmm... it gets me better FC. I'm lazy to inflate tyres often. I also hope to wear the tyres out at the centre (as my tyres seem to wear more at the edges). Maybe I'm totally wrong for the last part and someone can enlighten me how to get more even wear. I usually have quite a full load (but when I pump tyres, I'm usually alone). So although I pump so full, when I load up with stuff and passengers and then observe the tyre's contact area, you'll notice that the contact is now more. As mentioned, I do not claim this to be a correct practise .... just that I've been doing it, that's all. Link to post Share on other sites More sharing options...
Victorco 2nd Gear April 17, 2007 Share April 17, 2007 260 when heated when driving will be over 275 plus your drive load. sure more then that. maybe u wan to lower the amt u pump in. Link to post Share on other sites More sharing options...
Dwoon 1st Gear April 17, 2007 Share April 17, 2007 Errr.... but my tyres are already heated up when I pump leh.... Normally do it on my way home from work. I don't pump them when cold. So actually, will the pressure increase since the tyres contract slightly upon cooling??? Link to post Share on other sites More sharing options...
Russ 1st Gear April 17, 2007 Share April 17, 2007 I overinflate as well but only 20kpa over the recommendation. 300 kpa is a bit on the high side IMO ↡ Advertisement Link to post Share on other sites More sharing options...
Portable Tyre Pump
Portable Tyre Pump
Pump Petrol In JB - Worth it
How often do you pump air for tyres?
Bedok Esso faulty pump
Here we go again... Pump price up
The Journey Of Your New Car getting pumped
Pump Diesel in JB
Pump Diesel in JB
Fuel Pump Change
Fuel Pump Change
