Solar Turbocharged November 15, 2017 Share November 15, 2017 (edited) For Long distance, Yes you are right in that the air temperature in the Tyres will increase. But when deflate or lowered tyre pressure will result in more heat produced and actually a lowered deflated Tyres caused Tyres to burst. So in fact you have to pump up slightly more air. If usually your car is travelled with 1 driver and 1 passenger and you pump 220kpa, for Long distance driving, itâs safer to pump at least 230. If full loaf then should do minimum 20-30kpa more. Minimum nothing less than whatâs recommended on the door side tyre pressure guide (if on stock size Tyres) Tyre pressures usually can take up to 350kpa. To add on.. Assuming the same amount of heat is applied to 2 containers of water, one full and the other three quarters. Which one boils first. Edited November 15, 2017 by Solar ↡ Advertisement Link to post Share on other sites More sharing options...
Bobo07 3rd Gear November 15, 2017 Share November 15, 2017 Most important rule is to keep left at all times when you are travelling slow.. Allow fast cars to pass on the right lane... Don't road hog.. Link to post Share on other sites More sharing options...
inlinesix Hypersonic November 15, 2017 Share November 15, 2017 Most important rule is to keep left at all times when you are travelling slow.. Allow fast cars to pass on the right lane... Don't road hog.. You are only half right. Even travelling at 200km/h, still need to lookout over rear view mirror. There could be goondu driving at 250km/h trying to overtake. 2 Link to post Share on other sites More sharing options...
Bobo07 3rd Gear November 15, 2017 Share November 15, 2017 (edited) You are only half right. Even travelling at 200km/h, still need to lookout over rear view mirror. There could be goondu driving at 250km/h trying to overtake. Yes, if you travel long enough on the NS highway, it is classified as the Autobahn of Germany no speed limit... Seen many powerful cars gg at super high speed.. So for our usual driving habit like in SG, please remember to keep left at all times unless you are driving a Supercar. Edited November 15, 2017 by Bobo07 2 Link to post Share on other sites More sharing options...
Colin03 4th Gear November 15, 2017 Share November 15, 2017 Always rest at resting point when you feel tired and not speed up to shorten the travel time. have a drink in car to slip a little especially in this hot weather. listen to some songs that you can sing along do help. Anyone going up KL this fri ? Can travel with me if you want. 3 Link to post Share on other sites More sharing options...
zipping Supersonic November 15, 2017 Share November 15, 2017 (edited) imho...abt tyres...u need to know ur tyre capabilities... mny yrs bck i join a friend of mine on a drive up to KL (nite drive, avg 140-160km/h)....1/2 way thru e drive there was this little 'pulsing' feeling to e car's steering wheel (i can't feel anything as a passenger, no licence to drive yet)...and we dismiss it as e tyre running on e lanes divider and also during stop-overs, we visually chk e tyre and no visible signs damage or distress on the tyre. Thereafter e 'pulsing' feel nvr subside according to e driver. once we reach KL, for safety and peace of mind, we drove to a ws to chk, imagine our shock when one of the back tyre belly-out on e tread surface when e car was hoisted up (back pair of tyre was abt 1-2wks old). Most likely cause is e steel belt/linings broke (according to e tech) We ask e ws wat happened? izzit bcos e tyre too new n havn't run in yet? imagin to our horror, e tech inform us tat e tyre involved cannot handle speeds of 120 or 140km/h (can't remember which) and abv!!! Well, we were told by e ws tech we was lucky e tyre nvr blow out and cause an crash. So...moral of story, know e capabilities of ur tyre...not oni e rim size/width/aspic ratio......but more impt e load index and speed ratings, esp if u go on long drives that will involve high-speed driving. my 2¢ Edited November 15, 2017 by zipping 4 Link to post Share on other sites More sharing options...
Dannnn 4th Gear November 15, 2017 Share November 15, 2017 Good to know what you should do when your windscreen shattered due to stones from the front vehicle in highway. How to continue driving to the next stop and ask for help. Having emergency contacts will be helpful too. Don't rush and enjoy the drive. If windscreen ever crack or chip, best isnapply clear nail polish on it. So that the crack or chip will nt spread Link to post Share on other sites More sharing options...
Solar Turbocharged November 15, 2017 Share November 15, 2017 You are only half right. Even travelling at 200km/h, still need to lookout over rear view mirror. There could be goondu driving at 250km/h trying to overtake. Absolutely correct. Long time ago i overtook a car at about 160 but within seconds a LS460 zoomed by my left within an eye blink. He must have done much higher. Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged November 15, 2017 Share November 15, 2017 To add on.. Assuming the same amount of heat is applied to 2 containers of water, one full and the other three quarters. Which one boils first. Got put salt in water? And both container density same? Do advice so some intellect can answer factually 1 Link to post Share on other sites More sharing options...
Kb27 Supersonic November 15, 2017 Share November 15, 2017 Tyre burst due to being overheated. Normally, It overheats when it's deflated, you're rubbing the tyre against the ground. Friction cause heat. I experienced it twice. So make sure your tyres are properly inflated before you set off for any journey. 2 Link to post Share on other sites More sharing options...
Bobo07 3rd Gear November 15, 2017 Share November 15, 2017 Absolutely correct. Long time ago i overtook a car at about 160 but within seconds a LS460 zoomed by my left within an eye blink. He must have done much higher. Proton there can do over 200km/h sab sab water... LS460 smell no smoke... just let them pass and don’t road hog for the safety of everyone.... Link to post Share on other sites More sharing options...
Solar Turbocharged November 15, 2017 Share November 15, 2017 Proton there can do over 200km/h sab sab water... LS460 smell no smoke... just let them pass and donât road hog for the safety of everyone....Just split second. he was really fast.I was focusing on an overtaking without knowing the LS came along. But yeah, keep left always Link to post Share on other sites More sharing options...
ChloeAng Neutral Newbie November 15, 2017 Share November 15, 2017 tires really very crucial criteria for safety driving. i ever seen accident caused by tire bursting at high way, that's terrible. that's y better spend more money on high quality tyre especially for those often on long distance driving like me. myself using cc6. that's many factors causing accident, expensive tyres doesn't mean guarantee road safety, my experience is send my car to service before long distance driving. at least can ensure the car is safe for driving. 1 Link to post Share on other sites More sharing options...
ChloeAng Neutral Newbie November 15, 2017 Share November 15, 2017 Tyre burst due to being overheated. Normally, It overheats when it's deflated, you're rubbing the tyre against the ground. Friction cause heat. I experienced it twice. So make sure your tyres are properly inflated before you set off for any journey. oh really? now only i know wat caused the tyre burst. i often heard foreman said premium tyre has good quality can ensure safety, but seems like no much different in terms of safety, myself using economy tyre so far is ok. Link to post Share on other sites More sharing options...
Gnahp Turbocharged November 15, 2017 Share November 15, 2017 Tyre burst due to being overheated. Normally, It overheats when it's deflated, you're rubbing the tyre against the ground. Friction cause heat. I experienced it twice. So make sure your tyres are properly inflated before you set off for any journey. I think it is the excessive flexing of under inflated tire side wall that generate the heat and weaken the carcass Link to post Share on other sites More sharing options...
Kb27 Supersonic November 15, 2017 Share November 15, 2017 oh really? now only i know wat caused the tyre burst. i often heard foreman said premium tyre has good quality can ensure safety, but seems like no much different in terms of safety, myself using economy tyre so far is ok. Not true that expensive "good quality" tyre won't burst. Once it's deflated usually bcuz of a puncture, any tyre WILL BURST when you continue driving and pushing it. The cheap economy tyre may not give you absolute "good braking distance", but it's safe for normal driving, as long as it's properly inflated and of cuz have treads and not "bald" For long distance driving, the advice is to pump up the pressure a bit. Some people pump 70% or 80% of max pressure (printed on the tyre sidewall). Most cars specify between 220~230kpa. I usually pump 240 or 250kpa depending on the tyres. 2 Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic November 15, 2017 Share November 15, 2017 Dont go at night if u dont have good headlight. Most of the street doesnt have lamp For tyre nowadays new tyre are ok can go 120-140safely. But if want to do top speed check the tyre rating also the tyre tread thickness 1 Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic November 15, 2017 Share November 15, 2017 Actually the key is not whether you have good headlight or not, but to practice defensive driving. For Malaysia, I would say the added risk for the lack of lighting is the potholes. If not familiar with the road condition then better slow down, or avoid night driving altogether. Frequently in Singapore even with good lighting, I see people speeding in narrow neighborhood roads which they are unfamiliar with. Singapore is one of the very few countries, if not the only country that have street lamps located close to one another, most other countries including US, Europe, China and Japan do not have so so many street lamps densely installed for various reasons - country too big, energy saving policies, limited budget, etc. If in country side then no need to say, often there are no street lamps. Turn on the high beam when there are no vehicles in front, and turn it off when there are oncoming vehicles or in front. Not only about potholes. Sometimes even in nshw there could be fallen debris so need pay more attention. Some car high beam like no effect unless using led headlight. Most importantly if not familiar dont drive fast ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Class 4 Driving License
PSA: Driving in Malaysia and How To Handle Accidents and Theft
Malaysia Ringgit Exchange Rate
Singapore separation: The Albatross File
Malaysia: Flood in Malaysia
Gaming Can’t Guarantee You A Future? 27-Year-Old M’sian Esports Gamer Just Bought A Ford Mustang
Rule of 78 loan abolished finally, in Malaysia
