Edenboy Neutral Newbie March 9, 2007 Share March 9, 2007 Would it be advisable? What are the cons? ↡ Advertisement Link to post Share on other sites More sharing options...
Blackyv Turbocharged March 9, 2007 Share March 9, 2007 most car model dont recommend that... maybe after 5K to be on the safe side....and i believe most jap car recommend 10K to use synthetics... btw, tumpang your post abit since we r on it... im wondering how about semi-synthetic after 5K??... Link to post Share on other sites More sharing options...
Genie47 1st Gear March 9, 2007 Share March 9, 2007 Waste money lah! At 5k, they will drain the oil out again. Syn oil so expensive and you want to use it for such a short mileage. Very wasteful. Link to post Share on other sites More sharing options...
Ccssgm 1st Gear March 9, 2007 Share March 9, 2007 Hyundai.....Advise My Colleague to change It after 1K.........Later He change it... After 5K.......He visit again.......Also Change Synthetic Oil...... Wat the waste........... Link to post Share on other sites More sharing options...
Marcostan 4th Gear March 9, 2007 Share March 9, 2007 Engine oil is just like the blood in human being. I dun think it is a waste to give a good blood to your body. After 1K I am using Redline fully synthetic oil and change out at 5K and 10K after just follow to change every 10K. Link to post Share on other sites More sharing options...
Newsunny Neutral Newbie March 10, 2007 Share March 10, 2007 Agree with Genie and ccssgm, oil is hardly "stessed" after 4-5k km unless you do a lot of high-revs and long engine idling with aircon on. Don't waste your $$ on synthetic. Use synthetic at 10k km if you want. Link to post Share on other sites More sharing options...
Ccssgm 1st Gear March 10, 2007 Share March 10, 2007 Not Really......The Engine need Double Strength .......... Link to post Share on other sites More sharing options...
Panalogic Neutral Newbie March 11, 2007 Share March 11, 2007 i was told by my mechanic that if i were to change synthetic at 1k, i dun need the 5 k... Is this true? Link to post Share on other sites More sharing options...
Windwaver Turbocharged March 12, 2007 Share March 12, 2007 Yes. Link to post Share on other sites More sharing options...
Panalogic Neutral Newbie March 12, 2007 Share March 12, 2007 if this id true, then it's not so worthwhile to change the oil at 5k mineral mah? Won't it cost more money and hence why do most ppl still do it? Link to post Share on other sites More sharing options...
Swiftly Neutral Newbie March 13, 2007 Share March 13, 2007 It should be highly recommended. Better still add ZX1 metal conditioner to the engine oil and gear box oil. The con, higher outlay initially but you will gain in FC etc. My friend got a Toyota Pirus and he has been driving it for about 5,000km on mineral oil. He used to clock average 4.9 to 5.2 lit per 100km. After adding synthetic oil, he immediately got 4.5 to 4.7 lit per 100 km. All measured by onboard fuel computer. Link to post Share on other sites More sharing options...
Lengendcf 1st Gear March 13, 2007 Share March 13, 2007 Engine oil is just like the blood in human being. I dun think it is a waste to give a good blood to your body. After 1K I am using Redline fully synthetic oil and change out at 5K and 10K after just follow to change every 10K. It's not like not wanting to give the best.. It's just that, before the 10000km, the engine parts need to run in. Use a thinker oil is better.. Link to post Share on other sites More sharing options...
Seanboi 1st Gear March 13, 2007 Share March 13, 2007 most car model dont recommend that... maybe after 5K to be on the safe side....and i believe most jap car recommend 10K to use synthetics... btw, tumpang your post abit since we r on it... im wondering how about semi-synthetic after 5K??... am thinking of using semi-syn for 5K. any advise? Link to post Share on other sites More sharing options...
Seanboi 1st Gear March 13, 2007 Share March 13, 2007 Some AD are using 30wt mineral oils. Unlike last time where they used 50wt mineral oil. Link to post Share on other sites More sharing options...
Garunguni Neutral Newbie March 13, 2007 Share March 13, 2007 Seriously for run-in, its not about thin/thick or syn or not oil. Importance is in the ingredients (addictive package) of the oil. For run-in, high detergent capability and cleaning usually needed to effectively carry away the metal debris of the new engine. Hence, dino oil like Chevron Supreme can actually serve as very good oil for run-in with its high moly content. Link to post Share on other sites More sharing options...
Octopus 3rd Gear March 13, 2007 Share March 13, 2007 i was told by my mechanic that if i were to change synthetic at 1k, i dun need the 5 k... Is this true? I think its true, cos my colleague went directly to synthetic after the first servicing, so next servicing skip the 5k and went to 10k then service. But I feel its better to don't skip the 5k oil change, cos maybe still have some tiny metal fines remaining in a new engine due to running-in period, so better to change the oil with shorter duration... I think its also a good idea to change-out the transmission oil within the first 10k km due to wear particle of a new gear box. Link to post Share on other sites More sharing options...
Falc 3rd Gear March 13, 2007 Share March 13, 2007 One of those no right or wrong question. If you feel your car engine is sufficiently run-in by 1k, then use synthetic by all means, with next oil change at 10k. If you are more conservative kind, then do mineral at 1K and switch to synthetic at 5k. Link to post Share on other sites More sharing options...
Stinkray Clutched March 13, 2007 Share March 13, 2007 Hello Bro, Follow the Veh handbook is the best..... ↡ Advertisement Link to post Share on other sites More sharing options...
Volvo Servicing
Volvo Servicing
Servicing at Tan Chong
Is Tan Chong Servicing Package NPMP value for money?
