Sstar Neutral Newbie January 22, 2007 Share January 22, 2007 Hi, need to check with you guys, what is the warranty period for EZ-Stab? is it advisable to buy a used one? What is the possibility for this device to be damaged or malfuction? Thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Xclang Neutral Newbie January 22, 2007 Share January 22, 2007 Ezstab make of supercaps. These are prone to voltage spikes FYI. Link to post Share on other sites More sharing options...
Maxxwell Neutral Newbie January 23, 2007 Share January 23, 2007 which means? Link to post Share on other sites More sharing options...
Derrick479 Neutral Newbie January 23, 2007 Share January 23, 2007 what is the EZ stab compared to Pivot (Blue)Stab in terms of functions? Link to post Share on other sites More sharing options...
Dermocyma Neutral Newbie January 23, 2007 Share January 23, 2007 may i know what is supercaps? Link to post Share on other sites More sharing options...
Xclang Neutral Newbie January 24, 2007 Share January 24, 2007 SuperCap is a cross between a capacitor & battery. Small & high power. Read this http://www.cellergy.co.il/capacitor.html Unfortunately, they can be damage by high (or negative) voltage spikes. For new pivot...ezstab...no problem. But used part, hard to tell spoilt. Only owners know. :P Link to post Share on other sites More sharing options...
Xclang Neutral Newbie January 24, 2007 Share January 24, 2007 Unfortunately, they can be damage by high (or negative) voltage spikes. For new pivot...ezstab...no problem. But used part, hard to tell spoilt. Only owners know. :P Link to post Share on other sites More sharing options...
Sstar Neutral Newbie January 24, 2007 Author Share January 24, 2007 sometimes, even owner doesn't know either, whether it is working properly... Link to post Share on other sites More sharing options...
Maxxwell Neutral Newbie January 25, 2007 Share January 25, 2007 oic now have a slightly better idea Link to post Share on other sites More sharing options...
Maxxwell Neutral Newbie January 25, 2007 Share January 25, 2007 but i thought can feel the difference? Link to post Share on other sites More sharing options...
Hattee Neutral Newbie January 26, 2007 Share January 26, 2007 Not exactly sure for less than SGD200, EZ-Stab is giving a serious supercap. Current price is at least USD400 for a piece of 8Farad 20VDC. But its ESR is many times lower than electrolytic capacitor. But we need probably at least 24VDC to be safe and can it survive the daily temperature changes of 25-90-25 deg C in the engine compartment? Quote Ezstab make of supercaps.These are prone to voltage spikes FYI. Link to post Share on other sites More sharing options...
Carmour 4th Gear January 26, 2007 Share January 26, 2007 FYI, EZ-Stab has undergone lab testing and proved resistant to heat and stresses. Link to post Share on other sites More sharing options...
Hattee Neutral Newbie February 7, 2007 Share February 7, 2007 (edited) send error Edited February 7, 2007 by Hattee Link to post Share on other sites More sharing options...
Dermocyma Neutral Newbie February 7, 2007 Share February 7, 2007 what is "send error"? Link to post Share on other sites More sharing options...
Normal_aspirated Clutched February 7, 2007 Share February 7, 2007 from the webby........these supercaps max voltage currently up to 12V only. How's possible to use in the engine bay.......put two in series to make up to 24V? Supercaps has much higher current energy than electrolytic ones.......can help lengthen battery life (tats wat the webby says) Link to post Share on other sites More sharing options...
Zheshi Neutral Newbie February 10, 2007 Share February 10, 2007 If my car is install with voltage stablies and 6 point grounding. Does installing the EZ-Stab will have any more effect on it? Or since i have voltage stablies.. there is no need to install the EZ-STAB le? Does these two item able to work together? Link to post Share on other sites More sharing options...
Normal_aspirated Clutched February 10, 2007 Share February 10, 2007 if EZ-stab uses supercaps of values in terms of Farads......then the other volt-stab which uses tens of thousands micro-farads, it can be used together with these supercaps. Link to post Share on other sites More sharing options...
Hattee Neutral Newbie February 12, 2007 Share February 12, 2007 (edited) Perhaps, some understanding of supercapacitor can be found at http://www.avxcorp.com/docs/masterpubs/bestcap.pdf which are mostly in mF. But they are certainly not cheap at this moment. For less than $200, don't know what EZ-stab has offered. Whether its box can seriously house many farads of over 20VDC supercapacitor, I leave it to your imagination. Edited February 12, 2007 by Hattee ↡ Advertisement Link to post Share on other sites More sharing options...
Parking lot is serious business
Two Teens Stab a 17 yo
Girl found dead with two stab wounds at tampines flat: repor
EZ-STAB....Impressed by genuine service...Pdt not sure yet...
Customer jailed for threatening to stab mechanic in neck
Husband Stab Wife, Intestines Come out!
Man Kena Stab, Dies
Man Kena Stab, Dies
NTU student stab her own head
