Xstudio Neutral Newbie January 11, 2007 Share January 11, 2007 Can anyone please provide me with the toyota rush sepc in full details? I'm considering buying this car most probably... it's fit me.... I'll be grateful should anyone provide me with more details or perhaps you can simply leave me a link to it thank you... i cannot find details like the top speed, 0-100km pick up...etc and lastly the price range as well thank you. I ref from sg carmart and it ranges from SGD 46,100 - 64,900. How true is it? Please show me some guidance thank you very much. ↡ Advertisement Link to post Share on other sites More sharing options...
Ivan96935sg Neutral Newbie January 11, 2007 Share January 11, 2007 Do a search in the net....should have the specs. Link to post Share on other sites More sharing options...
Quantum 5th Gear January 12, 2007 Share January 12, 2007 Look at this:DIMENSIONS & WEIGHT FEATURES Length (mm) : 3995 Width (mm) : 1695 ABS with EBD Height (mm) : 1690 Wheelbase (mm) : 2580 Dual Front Airbags Fuel Tank (litre) : 50 Min Ground Clearance (mm) : 180 VVT-i Engine Tread-Front (mm) : 1450 Brake Assist Tread-Rear (mm) : 1460 Min turning Radius (mm) : 4900 Foot Parking Brake Curb Weight (kg) : 1150 Front Fog Lamps ENGINE - Type : DOHC Water-cooled 4 Cylinder 16 Valves VVT-i - - Displacement (cc) : 1495 - Bore x Stroke (mm) : 72.0 x 91.8 - Compression Ratio : 10.0 - Max Output (bhp/rpm) : 107/6000 - Max Torque (Nm/rpm) : 141/4400 - Top Speed (kmh) : - - Acceleration - 0 to 100kmh (s) : - - TRANSMISSION - 4-speed Automatic with Super ECT - STEERING FUEL SYSTEM Rack and Pinion Electronic Fuel Injection System BRAKES SUSPENSION Front : Disc Brakes Front : MacPherson Strut Type, Coil Spring Rear : Drum Brakes Rear : Multi-link Type, Coil Spring Link to post Share on other sites More sharing options...
Watwheels Supersonic January 12, 2007 Share January 12, 2007 This type of car reminds me of the Pajero Mini from Mit back in the 90s. Although engine capacity is twice of the Pajero Mini but it falls in the same category of small&fun SUV. In fact Rush is very much bigger in most ways. More practical I guess. Looking at price range of 46k, I dun think COE is included, read the fine print carefully. If I were u I avoid PI and get from Daihatsu. Link to post Share on other sites More sharing options...
So_nice 6th Gear January 12, 2007 Share January 12, 2007 (edited) terios and rush uses different engine actually. and the accessories are different from my knowledge. rush uses the VVT-i while terios(daihatsu) is using the DVVT if i'm not mistaken. at 46k+ confirm plus chop not inclusive of coe one. Edited January 12, 2007 by So_nice Link to post Share on other sites More sharing options...
So_nice 6th Gear January 12, 2007 Share January 12, 2007 u got pm Link to post Share on other sites More sharing options...
Picanto 3rd Gear January 12, 2007 Share January 12, 2007 Better be careful of those PI. there is an article in TODAY about them. no point paying cheap cheap, but in the end end up with lots of troubles. Link to post Share on other sites More sharing options...
Roadhogger 2nd Gear January 12, 2007 Share January 12, 2007 Daihatsu build this car and oem to Toyota as Rush. Daihatsu now own by Toyota. Link to post Share on other sites More sharing options...
Xstudio Neutral Newbie January 12, 2007 Author Share January 12, 2007 Hi thank you for your advise but pls indicate what sort of troubles are you indicating? I don't get you somehow, thanks. Link to post Share on other sites More sharing options...
Touch_n_go Neutral Newbie January 12, 2007 Share January 12, 2007 juz like Toyota Passo=Daihatsu Sirlion=Perodua Myvi!! wats the price diff btween Rush n Terios??? Link to post Share on other sites More sharing options...
Gobbler Clutched January 12, 2007 Share January 12, 2007 (edited) terios and rush uses different engine actually. and the accessories are different from my knowledge. rush uses the VVT-i while terios(daihatsu) is using the DVVT if i'm not mistaken. at 46k+ confirm plus chop not inclusive of coe one. please lah, dun give misleading info www.daihatsu.com/news/n2006/06011701/ Edited January 12, 2007 by Gobbler Link to post Share on other sites More sharing options...
Kyousuke Neutral Newbie January 12, 2007 Share January 12, 2007 terios and rush uses different engine actually. and the accessories are different from my knowledge. rush uses the VVT-i while terios(daihatsu) is using the DVVT if i'm not mistaken. at 46k+ confirm plus chop not inclusive of coe one. DVVT is VVT-i. They are exactly the same engines. Link to post Share on other sites More sharing options...
Xstudio Neutral Newbie January 12, 2007 Author Share January 12, 2007 So can i say that basically they are the same? other than the branding? and the pricing wise? i guess not too far apart as well? And also I realize there X and G model.... seems the same after all is it? Link to post Share on other sites More sharing options...
Kyousuke Neutral Newbie January 12, 2007 Share January 12, 2007 They are exactly the same. In fact, Toyota has "subcontracted" Daihatsu to manufacture some of its products. Etc, Rush, Bb.. Link to post Share on other sites More sharing options...
Nkps 1st Gear January 12, 2007 Share January 12, 2007 (edited) terios and rush uses different engine actually. and the accessories are different from my knowledge. rush uses the VVT-i while terios(daihatsu) is using the DVVT if i'm not mistaken. at 46k+ confirm plus chop not inclusive of coe one. can you tell me what is the different between ROTI PRATA and ROTI CANAI? and what is the different between VVT-i and DVVT?? i apologize for my ignorant. Edited January 12, 2007 by Nkps Link to post Share on other sites More sharing options...
Guardsboy Neutral Newbie January 15, 2007 Share January 15, 2007 The Rush and the Tertios is the same car. VVT-i and DVVT is the same. If u look at other Daihatsu models like Siron is also PI Toyota Passo. So if you don't feel like getting from PI, just get from Daihatsu. Link to post Share on other sites More sharing options...
Bluewater Clutched January 15, 2007 Share January 15, 2007 Go to http://www.rushteriosclub.com Link to post Share on other sites More sharing options...
Blueblack Neutral Newbie January 17, 2007 Share January 17, 2007 Real experience here - If you can stand small problem like those little noise here and there when u go thru hump and so on. Then buy Rush for the obviously better price and spec (talking @ 2WD). If you like my wife cannot tahan this kind of noise, then you better get the Terios. Reason being u still can go back to the agent and there is a whole team of technican there to help you solve problem. But if you die die want 4WD than choice is obvious. Don't bother by wat vvti, dvvt or wat engine wat gear box... different manufacturer name their problem differently. A 1.5L car is 1.5L car the 2 or 3hp difference is also another bxxxxxxt. You can't feel any difference in everything driving at those rpm range. ↡ Advertisement Link to post Share on other sites More sharing options...
Toyota Corolla Cross
2022 Toyota bZ4X
2022 Toyota bZ4X
Full DAy Bus Lane BEWARE!
