Hawker Clutched January 6, 2007 Share January 6, 2007 is there any car that can run @ 100Km/h but only 2000rpm ? what is the rpm for normal @80km/h what is the rpm for normal @90km/h what is the rpm for normal @100km/h my previous citreon 2.0i 80km/h @2000rpm 100km/h @2400rpm ↡ Advertisement Link to post Share on other sites More sharing options...
Terenc3 1st Gear January 6, 2007 Share January 6, 2007 My 1.6AT Sunny runs 100KM/H at around 2300 to 2400RPM too.. 80KM/H I think its around 2000RPM. Cant really remember for 80KM/H.. Link to post Share on other sites More sharing options...
Watwheels Supersonic January 6, 2007 Share January 6, 2007 My car lor. 100km/h @ 2000rpm 5 speed auto. Does it matter?? It depends on the final gear ratio of your gearbox. It more quiet and smooth compare to higher rpms I guess. Better FC? That's all I could think of. Link to post Share on other sites More sharing options...
Blackyv Turbocharged January 6, 2007 Share January 6, 2007 let try to remember mine.. vios, auto... ~2.0 K rpm for normal @80km/h ~2.5 K rpm for normal @100km/h ~3.0 K rpm for normal @120km/h ~3.5 K rpm for normal @140km/h ~4.0 K rpm for normal @160km/h ~4.4 K rpm for normal @170km/h ~4.7 K rpm for normal @180km/h (after some distance of dragging with 160/170km/h....) btw, if u ask is there any cars that can run 100km/h with 2K rpm, if my memory not failing me, when i was in states driving a ford mustang, it did cruise at around 2K rpm only with a speed of ~60mph..... Link to post Share on other sites More sharing options...
Skinky 1st Gear January 6, 2007 Share January 6, 2007 The new 4.3 Rav 4 2.4l runs 100km/h at 1500rpm. Believe it or not :) Link to post Share on other sites More sharing options...
Blackyv Turbocharged January 6, 2007 Share January 6, 2007 ... that means the FC would be very if crusing along NSH...... Link to post Share on other sites More sharing options...
Watwheels Supersonic January 6, 2007 Share January 6, 2007 I believe bigger displacement of the engine runs lower on rpm @ 100km/h. Link to post Share on other sites More sharing options...
Stitchohana Neutral Newbie January 6, 2007 Share January 6, 2007 Mine 2000rpm - 95kmph FIT 1.3A Link to post Share on other sites More sharing options...
Eavr4 Neutral Newbie January 6, 2007 Share January 6, 2007 Quote is there any car that can run @ 100Km/h but only 2000rpm ?what is the rpm for normal @80km/h what is the rpm for normal @90km/h what is the rpm for normal @100km/h my previous citreon 2.0i 80km/h @2000rpm 100km/h @2400rpm My Odyssey (RA8) 100km/h @ just under 2000rpm 110km/h @ 2000rpm 130km/h @ 2500rpm ..... 180km/h reads a little over 4000rpm. As its JDM, even without speedcut,meter only reads upto 180, but at top speed, rpm reads ard 5300. As for Legacy GT, 90kmh @ 2000rpm 110km/h @ 2500rpm 140km/h @ 3300rpm 160km/h @ 4000rpm 200km/h @ 4800rpm 240km/h @ 5500rpm 260km/h @ 6200rpm (Max liao!) EA Link to post Share on other sites More sharing options...
Sapience Clutched January 6, 2007 Share January 6, 2007 that's not the only factor... the RS4 (as reported by ST) runs at 2600rpm at 100kmh so this whole thread is rather pointless... and mine is a useless contribution Link to post Share on other sites More sharing options...
Lancer79 Neutral Newbie January 6, 2007 Share January 6, 2007 Mine 2500rpm - 90kmph lancer 1.6M Link to post Share on other sites More sharing options...
Watwheels Supersonic January 6, 2007 Share January 6, 2007 Performance car will definitely be different as they have a higher redline rpm. I'm talking about normal NA cars. RS4 is force induced right? Link to post Share on other sites More sharing options...
Boyboy 1st Gear January 6, 2007 Share January 6, 2007 i'm the champion so far!!! 100km/h @ 3000 rpm small engine bor pian the bigger the engine, the more torque. hence the higher the top gear can be without straining the engine. however, i believe this rule may be bent for close ratio gearbox or better pickup but sacrifiing FC and maybe top speed. Link to post Share on other sites More sharing options...
Nhrisuzu 1st Gear January 6, 2007 Share January 6, 2007 i am around there as u.. 90kmh already at 2.5krpm.. and have a vibrating seat below my arse.. Link to post Share on other sites More sharing options...
Shull Turbocharged January 6, 2007 Share January 6, 2007 my civic does that... 100kmh at 2000rpm Link to post Share on other sites More sharing options...
Decksurgeon Neutral Newbie January 6, 2007 Share January 6, 2007 (edited) think the RS4 runs at much less than 2000rpm at 100kmh. 2600rpm probably looking at 100mph more like it. im running 1900rpm at 100kmh to the thread starter. anyway, there is no 'fixed' rpm for 'fixed' speed as a rule of thumb. your RPM with respect to speed varies with: (a) gear ratios (b) final drive ratio this is most commonly translated to kmh/mph per RPM in a comprehensive car review like Autocar Magazine. the kmh/mph per RPM will also be given for each gear of the car and be displayed as a graph usually. if youre running CVT the ratios are variable. unless the programming makes the CVT act like a fixed ratio convetional gearbox you cant do the same measurements on it. hope this helps Edited January 6, 2007 by Decksurgeon Link to post Share on other sites More sharing options...
Vino Clutched January 6, 2007 Share January 6, 2007 Quote The new 4.3 Rav 4 2.4l runs 100km/h at 1500rpm. Believe it or not :) I'm driving this make and would say it's ard 1700rpm or so hence very fuel economical! Link to post Share on other sites More sharing options...
Ccssgm 1st Gear January 6, 2007 Share January 6, 2007 Mine Is 80km/h @ 1800rpm 100km/h @ 2000rpm....... ↡ Advertisement Link to post Share on other sites More sharing options...
Almost reach 3000rpm when travel at constant 100km/h
100km/h and Rpm at 4000 is it normal?
Proton Savvy 0-100km/h in 11 sec
Mad Parent, 8 years old drive 100km/h
Incredible chery QQ cutting in/out traffic at 100km/hr
100km Traffic Jam!
100km Traffic Jam!
F10 535i - 100km and already in the pre-owned market
Wah 100km only
Wah 100km only
