Jac Neutral Newbie August 14, 2012 Share August 14, 2012 Was thinking to buy a used XC90.. Any advise on whther to get T5 or T6.. or not to buy any.... lol Help , Help .. Thanks in advance,,,,,,, ↡ Advertisement Link to post Share on other sites More sharing options...
Vino Clutched August 17, 2012 Share August 17, 2012 Was thinking to buy a used XC90.. Any advise on whther to get T5 or T6.. or not to buy any.... lol Help , Help .. Thanks in advance,,,,,,, Pro... If safety is what you are after then it's none other than a XC90. This car is made of boron and it's probably the toughest passenger car you can find. Con... As this car is well 'armoured' hence it's weighed 2.2 tonne and that's heavy so FC is high compared to jap. However, tuning will improved your FC provided you don't go crazy with the improved bhp. Go join volvosgclub.com as there is a bunch of very friendly folks who is highly competent and very knowledgeable on Volvo. Link to post Share on other sites More sharing options...
Roadhogger 2nd Gear August 17, 2012 Share August 17, 2012 Was thinking to buy a used XC90.. Any advise on whther to get T5 or T6.. or not to buy any.... lol Help , Help .. Thanks in advance,,,,,,, Avoid T6...the Gearbox is hell...worst than 7spd DSG Link to post Share on other sites More sharing options...
Hamburger Hypersonic August 17, 2012 Share August 17, 2012 T5 uses aisin autotrans?? Link to post Share on other sites More sharing options...
Vino Clutched August 17, 2012 Share August 17, 2012 (edited) The lousy transmission was made by GM years back so if u can get the newer models which are using aisin transmission there's certainly no issue. However, it's advisable to do an ATF bypass (go google xc90 ATF bypass) regardless of whichever transmission system. It will cost you just a few hundred buck for that piece of mind. Edited August 17, 2012 by Vino Link to post Share on other sites More sharing options...
LoverofCar 6th Gear August 23, 2012 Share August 23, 2012 The lousy transmission was made by GM years back so if u can get the newer models which are using aisin transmission there's certainly no issue. However, it's advisable to do an ATF bypass (go google xc90 ATF bypass) regardless of whichever transmission system. It will cost you just a few hundred buck for that piece of mind. what is the problem with the transmission that need a ATF by pass? Is it installing a ATF cooler? Link to post Share on other sites More sharing options...
Vino Clutched August 23, 2012 Share August 23, 2012 I suggest u google for a more detailed explanation. This topic has been extensively discussed in both vocsg & volvosgclub. Basically it's to prevent water (from radiator) from getting into your gearbox. Link to post Share on other sites More sharing options...
Alheych 6th Gear August 26, 2012 Share August 26, 2012 didn't know that such a monster is available in singapore! http://www.sgcarmart.com/used_cars/info.ph...497&DL=1229 Link to post Share on other sites More sharing options...
LoverofCar 6th Gear August 26, 2012 Share August 26, 2012 All Volvo are understated and very tunable car....many 2l are tuned to 300 bhp... Link to post Share on other sites More sharing options...
The_chanster Clutched August 30, 2012 Share August 30, 2012 XC90 - Good solid SUV/MPV. They're not called Swedish Tanks for nothing. ↡ Advertisement Link to post Share on other sites More sharing options...
2026 Volvo ES90
2026 Volvo ES90
Volvo Servicing
Volvo Servicing
2020 Polestar 2
2020 Polestar 2
Volvo V70
Volvo V70
2024 Volvo EM90
2024 Volvo EM90
