Sarong1 1st Gear December 22, 2006 Share December 22, 2006 (edited) Some one asked me recently a relevant question on damping factor, here is one article that explain it in a more layman manner. Abstracted from http://www.crownaudio.com/pdf/amps/damping_factor.pdf UNDERSTANDING DAMPING FACTOR [/left] Loudspeakers have a mind of their own. You send them a signal and they add their own twist to it. They keep on vibrating after the signal has stopped, due to inertia. That's called "ringing" or "time smearing." In other words, the speaker produces sound waves that are not part of the original signal. Suppose the incoming signal is a "tight" kick drum with a short attack and decay in its signal envelope. When the kick-drum signal stops, the speaker continues to vibrate. The cone bounces back and forth in its suspension. So that nice, snappy kick drum turns into a boomy throb. Fortunately, a power amplifier can exert control over the loudspeaker and prevent ringing. Damping is the ability of a power amplifier to control loudspeaker motion. It's measured in Damping Factor, which is load impedance divided by amplifier output impedance. Let's explain. If the speaker impedance is 8 ohms, and the amplifier output impedance is 0.01 ohms, the damping factor is 800. That's a simplication. Since the speaker impedance and amplifier output impedance vary with fre- quency, so does the damping factor. Also, the impedance of the speaker cable affects damping. Thick cables (with low AWG) allow more damping than thin cables with (high AWG). The lower the amplifier's output impedance, the higher the damping factor, and the tighter the sound is. A damping factor of 1000 or greater is considered high. High damping factor equals tight bass. How It Works How does an amplifier control speaker motion? When the loudspeaker cone vibrates, it acts like a micro- phone, generating a signal from its voice coil. This signal generated by the speaker is called back EMF (back Electro Motive Force). It travels through the speaker cable back into the amplifier output, then returns to the speaker. Since back EMF is in opposite polarity with the speaker's motion, back EMF impedes or damps the speaker's ringing. The smaller the amp's output impedance, the greater is the effect of back EMF on the speaker's motion. An amplifier with low output impedance does not impede the back EMF, so the back EMF drives the loud- speaker with a relatively strong signal that works against the speaker's motion. When the speaker cone moves out, the back EMF pulls the speaker in, and vice versa. In short, the loudspeaker damps itself through the amplifier output circuitry. The lower the impedance of that output circuitry, the more the back EMF can control the speaker's ringing. To prove it to yourself, take a woofer that is not connected to anything. Put your ear next to the cone and tap on it. You might hear a low-pitched "bongggg" if the speaker itself is poorly damped. Now short the speaker terminals and tap again. You should hear a tighter thump. Damping factor varies with frequency. As you might suspect, damping factor is most important at low fre- quencies, say 10 Hz to 400 Hz. Edited December 22, 2006 by Sarong1 ↡ Advertisement Link to post Share on other sites More sharing options...
Slonez Clutched December 22, 2006 Share December 22, 2006 (edited) This is what the designer (Steven Mantz) of your amplifier has to say (see attached). I suspect what he said is true cos no/very few manufacturers nowadays emphasis high damping factor as a good design criteria. High damping factor was the "IN THING" a decade ago where you find many amps with damping factor of 1000 or 2000. Steven Mantz happens to be a renown amplifier designer for those of you who do not know. Cheers! Edited December 22, 2006 by Slonez Link to post Share on other sites More sharing options...
Sarong1 1st Gear December 22, 2006 Author Share December 22, 2006 This is what the designer (Steven Mantz) of your amplifier has to say (see attached). I suspect what he said is true cos no/very few manufacturers nowadays emphasis high damping factor as a good design criteria. High damping factor was the "IN THING" a decade ago where you find many amps with damping factor of 1000 or 2000. Steven Mantz happens to be a renown amplifier designer for those of you who do not know. Yes you are right, once in a while, I will flip back what was written in the manual that came with the amp. But that was a bit too technical for some newbies to digest, and the someone that posed me the same question, happened to be a newbie as well. No wonder I don't see so much of the manufacturer mentioning about damping factors nowadays. Thanks bro. Link to post Share on other sites More sharing options...
Coolbreeze90 Neutral Newbie December 23, 2006 Share December 23, 2006 Think this is a really good article on the damping factor... Really explains it in the most simplest terms... Maybe the administrators can think of coming up with a sub folder for audio tech talk?? it can be a good reference for newbs like mua to do some reading?? Link to post Share on other sites More sharing options...
Kermit 1st Gear December 23, 2006 Share December 23, 2006 ya ya...more audio tech talk pls...should have such discussions long time ago...many such parameters are seldom understood, which is maybe why many amp manufacturers don't even bother to tell you such things, THD, S/N ratio blah blah blah. Tell u also dun understand, bring you there too far... Let's keep educating ourselves with such tech discussion!!! kudos. Link to post Share on other sites More sharing options...
Bluemice 2nd Gear December 23, 2006 Share December 23, 2006 the top part too cheem ... OT a bit: the para on the RMS seems quite off, imo. the ( Root of 4)^2 example is way off... as both parameters are of different units, can just write off in such simplistic manner. any PE in electrical can comment ? mice Link to post Share on other sites More sharing options...
Sarong1 1st Gear December 23, 2006 Author Share December 23, 2006 More will come, I hope the moderator can keep a subfolder under "Audio Tech Talk" as sticky so that folks including me can continue to contribute and the knowledge wouldn't be lost. Link to post Share on other sites More sharing options...
Ukexports Neutral Newbie January 20, 2007 Share January 20, 2007 alot of useful info ther Link to post Share on other sites More sharing options...
Ractis Neutral Newbie January 21, 2007 Share January 21, 2007 (edited) I belong more towards the school of thought that damping factor isnt a really important metric of sound quality. Anyway, another good article here talking about DF, when applied to passive vs active crossover network. In summary, it is saying that DF is greatly reduced when applied to passive x-over networks, hence it is advocating active x-overs. http://sound.westhost.com/biamp-vs-passive.htm Also, tube amps and class D amps tend to have lower DF, if this means anything at all :) Edited January 21, 2007 by Ractis Link to post Share on other sites More sharing options...
Kermit 1st Gear January 21, 2007 Share January 21, 2007 Bro, maybe you like to explain a bit more on why you believe DF isn't a really important metric of SQ? Perhaps we can gain some insights? You may have valid grounds to think so...interesting. Link to post Share on other sites More sharing options...
Ractis Neutral Newbie January 22, 2007 Share January 22, 2007 The article bro slonez posted above explains it rather nicely. From theory, actual effective DF depends more significantly on the speaker/crossover resistance, so much so that an amplifier with DF of 20 or 2000 wouldnt make much difference Practically, I have heard from tube amps to class D and class T amps that control the bass very well, hence I really do not think a high DF is a must for better control of the speakers. For amplifiers, I personally would look at the s/n ratio, wattage at 1% thd and reliability features (fault protection, noise/turn on-off pop rejection, good heat management) Link to post Share on other sites More sharing options...
Kermit 1st Gear January 22, 2007 Share January 22, 2007 oic. You're talking about the DF of amplifiers...fair enough. I tot u're saying in general that DF isn't really affecting SQ...got a scare...thanks for clarifying. Of cos, given a choice, amp with good DF is a good to have lah. ↡ Advertisement Link to post Share on other sites More sharing options...
Audio Shop Recommendation
Nothing Phone, Nothing but it's New to Me
US$50,000 turntables amp up tunes for affluent vinyl fans
Recommend audio installer
Let's talk about NS... good memories or nightmares?
Is there any topic you could talk for 30 minutes without preparation?
