Fff0 Neutral Newbie December 14, 2006 Share December 14, 2006 Hi Guys/ Gals, I am contemplating to buy a RIM + tyre from my friend whom profile is slightly bigger than the stock size. Case: Stock - 175/70/13 New Rim - 195/55/15 The difference in the diameter is about 3.5%. I know the speedometer/ ODO will reflect 3.5% slower too... May I know what will happen if I go for such a change? 1) Will the tyre rub against the Fender? 2) Braking prob? 3) Alginment problem? 4) Causing the axle to wear out much faster? 5) Any other implication to the car drive abilty? ↡ Advertisement Link to post Share on other sites More sharing options...
Blackyv Turbocharged December 14, 2006 Share December 14, 2006 1) Will the tyre rub against the Fender? (If the offset is the same, no problem.. wrong offset should be the concern..) 2) Braking prob? (no problem..) 3) Alginment problem? (no problem..) 4) Causing the axle to wear out much faster? (well,some say yes but i dont see the concern) 5) Any other implication to the car drive abilty? (nope....) btw, make sure the nuts pitching is the same.....(some using 4, some using 5 and some diameter 100 pitch and some 101.6...) Link to post Share on other sites More sharing options...
Weixiang_06 Clutched December 14, 2006 Share December 14, 2006 ur original stock size is a 13" is your car a QQ? that's a 13" car that i know of.... curious Link to post Share on other sites More sharing options...
Fff0 Neutral Newbie December 15, 2006 Author Share December 15, 2006 no la... nvr considered that car.... Accent only la. Link to post Share on other sites More sharing options...
Fff0 Neutral Newbie December 15, 2006 Author Share December 15, 2006 tks for the adv. for offset, whats the usual limit ? Pitching, I know... should not be a prob... as my friend car is an altis and mine is an accent , both 4X100PCD. Link to post Share on other sites More sharing options...
Blackyv Turbocharged December 15, 2006 Share December 15, 2006 different car has diff limit..... not sure what's the limit for accent... Link to post Share on other sites More sharing options...
Toyo 1st Gear December 15, 2006 Share December 15, 2006 My previous toyota soluna stock rim also 13" Link to post Share on other sites More sharing options...
Toyo 1st Gear December 15, 2006 Share December 15, 2006 it is recommended to keep within +/-3%. in yr case, it is a bit out. u can get the 15" rim but downsize to 185/55 or 195/50 tire Link to post Share on other sites More sharing options...
Yeobh 4th Gear December 15, 2006 Share December 15, 2006 (edited) Try getting a kid to wear a pair of army boots and observe how he walks- from the observations you should be able to correlate to bigger size tyres for small cars. Edited December 15, 2006 by Yeobh Link to post Share on other sites More sharing options...
Vit4wd 1st Gear December 16, 2006 Share December 16, 2006 Proton Wira & Kia Picanto also uses 13" rims Link to post Share on other sites More sharing options...
Vit4wd 1st Gear December 16, 2006 Share December 16, 2006 Just have to bear in mind tyhat the wide tyres will affect your fuel economy and ride comfort Link to post Share on other sites More sharing options...
Fff0 Neutral Newbie December 17, 2006 Author Share December 17, 2006 This I know but need better grip... ma.. good tyres unavail for 13" or 14" Link to post Share on other sites More sharing options...
Toyo 1st Gear December 18, 2006 Share December 18, 2006 Agreed. Most UHP tyre are available from 15" onwards for 14" i thk bridgestone GR80 is not bad. anyway i had seen accent on 15" rim so shld not be an issue. just rememeber to get a lower profile tyre with lighter rim Link to post Share on other sites More sharing options...
Fortress Clutched December 18, 2006 Share December 18, 2006 Generally higher fuel consumption, more costly tyres, more discomfort in your ride and if the tyres is budging out of the mudguard, it is an offend under LTA ruling. Link to post Share on other sites More sharing options...
Mroonws Clutched December 18, 2006 Share December 18, 2006 I saw before Kelisa, using i think its 14" rims, using Advan Neova Tyres.... ↡ Advertisement Link to post Share on other sites More sharing options...
Any recommended tyre shop
Continental CSC 7.
Continental CSC 7.
Tyre puncture
Tyre puncture
Feedback
Feedback
Tyre Rotation and balancing
Continental closing Alor Setar plant
