Pskvin Neutral Newbie November 29, 2006 Author Share November 29, 2006 as far i can remember, sunny is better built & better drive then altis. ↡ Advertisement Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear November 29, 2006 Share November 29, 2006 (edited) Noisy meh? Sounds ok to me leh Maybe, i'm a bit 'Chow Hee Lang' aka deaf Before the engine is warm up, it is definately more noisier as compared to after warm up Edited November 29, 2006 by Mzrmazda3 Link to post Share on other sites More sharing options...
Magfocus 5th Gear November 29, 2006 Share November 29, 2006 why so many bros/sis said mazda engine is noisy? especially mz3 & mz6. i owned mondeo, tried altis, gen2 & recently vios, getz, they are all noisier then the mz3, the worse is the mondeo. I can't remember how is sunny behave but i have not try honda. you're like saying why all Toyotas handle poorly..its a generalising statement. Link to post Share on other sites More sharing options...
Xefera 6th Gear November 29, 2006 Share November 29, 2006 (edited) yeah... i noticed that with mine too. esp if i have not switched on the engine for say a couple of days. but once it reaches the idle speed, the noise is less significant. Edited November 29, 2006 by Xefera Link to post Share on other sites More sharing options...
Xefera 6th Gear November 29, 2006 Share November 29, 2006 is the ride ur tested on dress with 15 or 16 inch rims? the optimum config for mazda3 is with 15". I noticed that when i upsized the other time. now regretting it a bit Link to post Share on other sites More sharing options...
Xefera 6th Gear November 29, 2006 Share November 29, 2006 maybe check the rubber insulation around the doors. could be worn and gone soft, that's why less effective in keeping out the road noise. most noise filters into the cabin through slits, nooks and cracks. so the likely places to check will the the firewall areas, transmission and doors. just my 2 cents Link to post Share on other sites More sharing options...
Law_ong Neutral Newbie November 29, 2006 Share November 29, 2006 why so many bros/sis said mazda engine is noisy? especially mz3 & mz6. i owned mondeo, tried altis, gen2 & recently vios, getz, they are all noisier then the mz3, the worse is the mondeo. I can't remember how is sunny behave but i have not try honda. the engine cant really be heard of when u inside the car with audio on..(even when u rev the car)..there is a in-built audio limiter thingy with the built in that actually increase ur audio level when the car is cruising at high spd (to cover out the noise intrusion)...in fact mz3 engine noise is much louder than my previous protege's...the engine of mz3 is built using aluminium parts compared to cast iron of protege..the material is so much thinner thus noise is louder than protege and noise produced is those hollow type... hear liao veri sian...but good thing its covered up with the soundproof material while you in the car... Link to post Share on other sites More sharing options...
Law_ong Neutral Newbie November 29, 2006 Share November 29, 2006 Mazda 3 looks nice but cannot run... :( toking about pickup wise.. but during cruising...you can try spd with it... but prepare to suffer veri high fc.... Link to post Share on other sites More sharing options...
Law_ong Neutral Newbie November 29, 2006 Share November 29, 2006 Tried Altis, omg the pickup is even slower. Floor accelerator like car too dam heavy to move . Engine starts to make loud noise when high rpm engage. cannot be lar..altis is lighter and has more efficient engine compare to mz3 leh...the pickup is much faster... Link to post Share on other sites More sharing options...
Pskvin Neutral Newbie November 29, 2006 Author Share November 29, 2006 sound logic. new to me. Link to post Share on other sites More sharing options...
Law_ong Neutral Newbie November 29, 2006 Share November 29, 2006 which part? the audio? its found in the manual....engine? its stated in the spec sheet..and personal comparison for owning both mz3 and protege.. Link to post Share on other sites More sharing options...
Zakuii 1st Gear November 29, 2006 Share November 29, 2006 I do not agree wif yr statement, mdz definitely can run, if u hav mz3 on the expressway, u know what i means. But agree tat it is slow in pick-up. Floor the accelerator of Mz3 before. Just won't move. Link to post Share on other sites More sharing options...
Shiwao Clutched November 29, 2006 Share November 29, 2006 eh ok, mazda cars dun fly off the ground even if you pedal to the metal. the speed you want is only there when you push it slowly and ahem, gently. Link to post Share on other sites More sharing options...
Law_ong Neutral Newbie November 29, 2006 Share November 29, 2006 u rite...the 1st and 3rd gear u floor it is basically waste of petrol.... Link to post Share on other sites More sharing options...
Roh96 6th Gear November 29, 2006 Share November 29, 2006 When you say engine noise, are u refering to idle stage or during driving? Some engine may sound louder during idle but they are smoother and quieter during drive. Link to post Share on other sites More sharing options...
Shiwao Clutched November 29, 2006 Share November 29, 2006 yea i learnt that the last time when I tried to floor it. you can 'coach' your Mz3 to be a little response. After running in your car, try to see which way is more effective. Of course, no zero to 100 in 6 secs lar Link to post Share on other sites More sharing options...
Pskvin Neutral Newbie November 29, 2006 Author Share November 29, 2006 the 'insulation' of the aluminium & cast iron engine block Link to post Share on other sites More sharing options...
Law_ong Neutral Newbie November 29, 2006 Share November 29, 2006 i learnt to use 2nd and 4th gear more for the revs...gear 1 and 3rd are shift to the next higher gear at almost the instance.... ↡ Advertisement Link to post Share on other sites More sharing options...
Car aircon blows cold and hot air at the same time!!
2025 Mazda 6e
2025 Mazda 6e
MAZDA 6
MAZDA 6
2015 Mazda CX3
2015 Mazda CX3
