Cyberet Neutral Newbie November 19, 2006 Share November 19, 2006 after a few months, the doors will be easier to close. i did it to all my 4 doors, and my boot ↡ Advertisement Link to post Share on other sites More sharing options...
Corgan Neutral Newbie November 19, 2006 Share November 19, 2006 dunno where bro. Benny's and marcostan's lobang. but for the price and the effect it has on wind noise, its definitely worth it should be organising one session with TLC with bro benny and marcostan's help. so look out for it Link to post Share on other sites More sharing options...
Garlic 1st Gear November 19, 2006 Share November 19, 2006 Roughly how thick is the foam tape? Does it come in contact with the factory insulation when the doors are closed? Link to post Share on other sites More sharing options...
Marcostan 4th Gear November 19, 2006 Author Share November 19, 2006 5-6mm thick and it do contact with the factory rubber insulation. Link to post Share on other sites More sharing options...
Lexxmexx Neutral Newbie November 20, 2006 Share November 20, 2006 Yes, it is good but I have difficulties closing the doors. How long do they take to season out? Link to post Share on other sites More sharing options...
Marcostan 4th Gear November 20, 2006 Author Share November 20, 2006 Bro, U just open a bit of yr window, then it's more easy to close. It might take 1-2 months to season out. But at that time u already make use of it. The reason why it's more difficult to close the door is because the cabin is completely sealed up. Therefore, there's no space to let the air out when u closing the door. This is a good prove that all sort of noises are being isolated............ Marcos Link to post Share on other sites More sharing options...
Newcarowner Neutral Newbie November 20, 2006 Share November 20, 2006 Hi Marcostan, Nice meeting you. Thanks for doing up my car and recommending this effective and cheap stuff. . Wind noise reduced alot. Tried your method yesterday. Indeed easier to close the door. Link to post Share on other sites More sharing options...
Clubace Clutched November 20, 2006 Share November 20, 2006 Talk about difficulty in closing the doors.......i have to ask pple to slam it shut. Of coz, in my case, i put in double layer..... heh heh. Link to post Share on other sites More sharing options...
Apollo 1st Gear November 20, 2006 Share November 20, 2006 do b careful of soundproofing. it is impt to remember that you cannot seal up all gaps. eventually u will reach a stage where the noise tat permeates into the car through unseen gaps (eg cable penetration thru firewall) will b trapped within the car. unlike a lexus which has well thot out ideas how this is to b prevented where the sources r, what measures to take. amatuer approach is to seal and leak. you seal some areas which r prime noise zone. and u do not seal some areas like carboot, rear doors, etc so tat noise which enters the cabin can leak out effectively and will not resonate. Link to post Share on other sites More sharing options...
Lexxmexx Neutral Newbie November 20, 2006 Share November 20, 2006 Single layer already got problems, you so kiasu put double layers Link to post Share on other sites More sharing options...
Clubace Clutched November 20, 2006 Share November 20, 2006 Ah...i have no problem with a single layer (door frame).....the problem lies in the 2nd layer....(at different part of the door)...but the noise really goes down alot. Link to post Share on other sites More sharing options...
Gimmegimmes Neutral Newbie November 20, 2006 Share November 20, 2006 Hard to shut properly when I'm inside the cabin, gonna do it a few times. By-passers must be thinking that this ah siao like to slam the door a few times before moving off . Link to post Share on other sites More sharing options...
Linus Clutched November 20, 2006 Share November 20, 2006 now u no more policking siao, become insulation siao... [laugh] still got DA weekly ? Link to post Share on other sites More sharing options...
Clubace Clutched November 20, 2006 Share November 20, 2006 (edited) our detailing siao never whip out his rotary/DA so i never take out my DA. Must give respect. Anyway, i do my washing and waxing on saturday. Seldom DA liao but i got a couple of scratches that i would like to remove. Edited November 20, 2006 by Clubace Link to post Share on other sites More sharing options...
Chan0004 Neutral Newbie November 20, 2006 Share November 20, 2006 looks interesting.......can share where to get the material and... is $10 for all 4 doors or 1?? Link to post Share on other sites More sharing options...
Clubace Clutched November 20, 2006 Share November 20, 2006 $10 for 1 roll which is enough for a layer for each door. Link to post Share on other sites More sharing options...
Linus Clutched November 20, 2006 Share November 20, 2006 quite sianz nowadays. everyday rain, rain, rain...... [:|] Link to post Share on other sites More sharing options...
Clubace Clutched November 20, 2006 Share November 20, 2006 (edited) But if dont do it weekly then the problem accumulates. Then by the time u tackle the problem...have to do until back break. Check with maddriver for some great long lasting sealant. Edited November 20, 2006 by Clubace ↡ Advertisement Link to post Share on other sites More sharing options...
Reckless Cyclist
Reckless Cyclist
Portable Tyre Pump
Portable Tyre Pump
Tyre puncture
Tyre puncture
Continental CSC 7.
Continental CSC 7.
