T.M. WORKS: VSD-II & Ignite-REV
Marcostan
I believed it can last, take note the Ignite Rev is go according to car model
and engine.
Please check that this 2nd hand one can be use in your ride, otherwise u just waste yr
If really not for you car can please PM me which model this used one for.
Thanks
Marcos
Nope..... it wasn't good. Wasted my half a day for installation (and $80 wasted labour) and taking out.... why???? Because I think 2 of them pieces were faulty.
Don't think I'll even try getting used stuff in future, when its on the plugs area.
AFter installation, I ran a CEL and the entire engine was wobbling.... apaprently, the ODBII diagnostic shows misfiring on 3 and 4. Take out and eveything back to normal.
So, these thinggies aren't too reliable and will spoil. Never did have a chance to see if they even work for my ride. [mad]
  Quote
Hi,
Anyone installed both of these or either one.
What's your feedback?
Hi there SIFU, as you remember I installed the Ignite REV somewhere Nov last year without the VSD-II as someone had taken my harness [laugh] . I felt the Ignite REV didn't perform too well on its own and had it taken out after a month. Dec '06 I installed the VSD-II and as you said better FC, even with my heavy foot I was hitting around 10km/L.
This year I was inform to reinstall the Ignite REV as it worked good paired together. I did so last wednesday. I'm flying now...somehow the engine is much smoother and quieter, am achieving higher speeds at a shorter time. Don't ask me about FC, you know I never really cared. But for you... I'll measure a few tanks and let you know in a months time.
Care for a test Drive [sly]
After having the Ignite Rev in the car for the past 2 months and still constantly monitoring my fuel consumption, I would say that it has improved (or in my case, maintained) my fuel consumption.
I used to get around 8.3 to 8.7 km per litre of 95 Octane for my S15 Silvia.
Right now, with a heavier right foot for driving after I installed it, it seems to have maintained the same fuel consumption as well.
Thus in return, I got better "more km" for my litre in terms of being able to be more heavy footed right now without sacrificing on fuel consumption effeciency.
After 2+ months of using only VSD-II, my feedback is:
1. Not much help in my FC
2. Engine is much more respond [thumbsup]
Still try hard to save some money for Ignite-Rev [blush]
VSD II is a voltage stabiliser connected to battery only?
I more interested in ignite rev, anyone installed? I not sure how many set I need to have. should be 4 set right?
No, VSD II from TM Works is not a voltage stabilizer.
Yes, it was connected to battery but it also need to connect to the ignition coil.
The installation time for my Rav4 took almost 1 hour because there's a lot of connection
that the mechanic need to connect. The final step was connect to battery.
Hi Brock, VSD II unit is transferable from car to car, but the wiring harness may not be. You probably have to get a new set of wiring harness from imperial concepts.
Have installed both VSD II and Ignite Rev, seems to help alittle on FC with VSD II, but dont expect miracles. Performance wise, I would say it does help a little on pick up. If you have the dough, no harm fixing it on. But be careful when you send the car for servicing, have to ask the mechanic to take care when changing the spark plugs. You do not want them to damage the glass tubings of the ignite Rev.
Cheers,
Tommy
