Pisces69 6th Gear October 23, 2006 Share October 23, 2006 No prob bro. U been missing for a long time. Where u been? ↡ Advertisement Link to post Share on other sites More sharing options...
Bluemice 2nd Gear October 23, 2006 Share October 23, 2006 not tat long la... now that theres a micelet in the family ... more time with him and wife, esp after her maternity... so less time for forums, even mitups i also rarely go liao... even my car wash regime from weekly dropped to fortnighly ... sometimes even 3 weeks then wash mice Link to post Share on other sites More sharing options...
Rollagt 5th Gear October 23, 2006 Share October 23, 2006 I want to add in, Use wet tissue or get some tissue and wet it and "pull" through the rubber blades then take a look then U will understand what i am talking abt.. Applying those solution will make the windscreen surface too "siap" and rubber cannot move smoothly. I always go throught the rubber using wet tissue after a heavy downpour..all the dirt all collected in the blades.. One more thing wash ur windscreen using plain water only ! Try it ! Link to post Share on other sites More sharing options...
Dumb 4th Gear October 23, 2006 Share October 23, 2006 Hi all My wipers have been juddering very badly whenever i turn it on. The wipers are new (new ride collected about 3 wks ago) and it was fine and it happened about a week ago. Spoke to some friends and they mentioned to wipe away the dust from the wiper blade and also clean the windscreen with glass cleaner (the type of blue solution we use to wipe our windows at home). Have done it but still no use. Any kind bros/sis out there can give advice? Many thks!! Since you car and ride is new, the juddering will go away after sometime because the seller could have applied something like rainex on your screen. Just wash the screen with shampoo that has no wax. Link to post Share on other sites More sharing options...
Adawang 1st Gear October 23, 2006 Share October 23, 2006 When it starts to judder, give it a squirt using your washer, then it will be ok but only temporary. I have been doing this Link to post Share on other sites More sharing options...
Ed520 Neutral Newbie October 23, 2006 Share October 23, 2006 i also get juddering sometimes! but the biggest problem is whenever it rains heavily, even with the wiper at full speed, it does not seem to wipe the windscreen clear and i cannot see properly. Link to post Share on other sites More sharing options...
Gen2 Neutral Newbie October 24, 2006 Share October 24, 2006 (edited) Hi bro Sunnyyip, you can try getting some glass polishing compound from either Autopacs or Stamford outlets. It should be able to reduce or eliminate the juddering problem . Edited October 24, 2006 by Gen2 Link to post Share on other sites More sharing options...
Bluemice 2nd Gear October 24, 2006 Share October 24, 2006 Hi bro Sunnyyip, you can try getting some glass polishing compound from either Autopacs or Stamford outlets. It should be able to reduce or eliminate the juddering problem Wink . mice Link to post Share on other sites More sharing options...
Wolfy3769 2nd Gear October 24, 2006 Share October 24, 2006 One of the solution i try was claybar the window... it work for me but not sure whether are there any side effect of using claybar on windscreen.... those who are familiar with claybar, pls advise.. Link to post Share on other sites More sharing options...
Zoom99 Neutral Newbie October 24, 2006 Share October 24, 2006 Hi all My wipers have been juddering very badly whenever i turn it on. The wipers are new (new ride collected about 3 wks ago) and it was fine and it happened about a week ago. Spoke to some friends and they mentioned to wipe away the dust from the wiper blade and also clean the windscreen with glass cleaner (the type of blue solution we use to wipe our windows at home). Have done it but still no use. Any kind bros/sis out there can give advice? Many thks!! I encounter the same experience too. I do a test myself supsecting that the car shampoo is the cause. True enough, if u don't wask your windscreen with car shmapoo/rain-x, then yr wiper would not judder. Link to post Share on other sites More sharing options...
Helix Neutral Newbie October 24, 2006 Share October 24, 2006 I do not think there's any side effect. If there is, its making your windscreen to squealy clean for some brands of wiper such that they will making this squeaky noises when wiping. I too have the juttering problem and tried all sort of methods to rectify it...claybar, autoglym glass polish & fast clean and newspaper...all don;t seem to work for me. Untill I took my car for servicing and told the mechanic about it. He applied some checmical...is it some kind of ceramic oxide?...and the juttering problem is gone. However, my wiper (twister) is still making these squeaky noises which I figure out must be the wiper's rubber material that is causing this problem. Will be changing back to the disposable wiper soon to check out the effect. Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear October 24, 2006 Share October 24, 2006 Hi bro I'm on Twister Wipers. It wipes smoothly during heavy downpours but do take note that the wiper will produce a loud spueaking sound when rain is light aka drizzling However, it has a warranty of 3 years and you just need to give that company a ring and they'll come down to get it fixed up So far so good, squeaking sound is almost gone after they came to rectify it Link to post Share on other sites More sharing options...
Pdesign1 Neutral Newbie October 24, 2006 Share October 24, 2006 So where to find forummer Sheeto or the compound that your mech uses (assuming ceramic oxide?) Link to post Share on other sites More sharing options...
Apollo 1st Gear October 24, 2006 Share October 24, 2006 tried soft99 b4, found to b rather useless. for real clean glass, mama lemon + razor blade is good. for sparkling clean, i use HG glass cleaner (fr Cold storage at peace center) this is good stuff. spray and wipe off. glass become squeaky clean. Link to post Share on other sites More sharing options...
Tomatoes Neutral Newbie October 24, 2006 Share October 24, 2006 i use moisturiser. works well for me, but must put once a week lah Link to post Share on other sites More sharing options...
Spikedoll Clutched October 24, 2006 Share October 24, 2006 i use 3M sandpaper-like sponge to wipe clean the windscreen..very effective in removing surface particles that may cause the juddering..only $2 or $4 from stamford tyres Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 24, 2006 Share October 24, 2006 Congratulations. So a new addition to the pack. Anyway nice to see u back. Yah but pack more important lah. I u'stand cos also got a family. Hee. Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 24, 2006 Share October 24, 2006 If your blade cannot give u a clear view, it's time to change the wipers. Some pple give them a new life by using very fine sandpaper to sand the edge of the rubber blade but I think it wil only b temporary, although I never done this b4. ↡ Advertisement Link to post Share on other sites More sharing options...
Car accident advice
Car accident advice
Advice on exhaust.
Advice on exhaust.
Need Advice on Self Storage
