Patrickquek Neutral Newbie October 18, 2006 Share October 18, 2006 Hi, Need 10L for my ATF flushing - Riverview charges $12.50 / quart for their Mitsubishi DIAQUEEN ATF. Any suggestions? Royal Purple's going for like $17.50. Expensive... thanks! ↡ Advertisement Link to post Share on other sites More sharing options...
Ccssgm 1st Gear October 18, 2006 Share October 18, 2006 Singapore Almost @ this Price... JB will be Cheaper.. Link to post Share on other sites More sharing options...
Dcturbo Neutral Newbie October 18, 2006 Share October 18, 2006 Try Stamford Jurong - look for Mohan. Can try also Racetech - look for Roland. Link to post Share on other sites More sharing options...
Ccssgm 1st Gear October 18, 2006 Share October 18, 2006 Try Ann Joo Motor Service Blk 176 Sin Ming Ave #02-17 Sin Ming autocare Tel: 64510747 Mr POH Link to post Share on other sites More sharing options...
Elantrahatch Neutral Newbie October 18, 2006 Share October 18, 2006 I think Mit. and Hyundai uses the same ATF. I got mine from this place called Song Yi @ Veersamy Road. Per litre is less then S$10.00 if i am not wrong. If you are interested, maybe you could PM me and I will go find the addy for you. On an additional note, the last time when I flushed my Matrix ATF, it costs around less then S$100.00 at CAS. Perhaps if you are keen, check out with them. I did mine at Khang Auto @ Sin Ming. Link to post Share on other sites More sharing options...
Itguy28 Neutral Newbie October 18, 2006 Share October 18, 2006 Bro, If u are driving Mit, u can only use Mit Diaqueen ATF. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic October 18, 2006 Share October 18, 2006 (edited) Ask those Mitsubishi stockist. www.autoparts.com.sg. Fong Ee and Min Ghee are not bad. Edited October 18, 2006 by Fcw75 Link to post Share on other sites More sharing options...
Patrickquek Neutral Newbie October 18, 2006 Author Share October 18, 2006 Thanks all for your prompt and helpful response! Forgot to mention that my ride is Tuscani 2.0A. Elantrahatch: Is yours a drain & top-up or a full flush (which uses 10L or so of ATF)? When i checked with CAS they only use mineral, not synthetic ATF. Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 18, 2006 Share October 18, 2006 Quote Hi, Need 10L for my ATF flushing - Riverview charges $12.50 / quart for their Mitsubishi DIAQUEEN ATF. Any suggestions? Royal Purple's going for like $17.50. Expensive... thanks! ========================= U cannot use RP as it's Dexron III. Not same as Diaqueen hor. BTW my RP ATF cost abt $10/qt only. Where u buy for $17.50/Qt????? Link to post Share on other sites More sharing options...
Trex101 3rd Gear October 19, 2006 Share October 19, 2006 You can use Synthetic (group III/IV) Schaeffer 204SAT which is rated SP III for your Hyundai auto. Link to post Share on other sites More sharing options...
Hogster Neutral Newbie October 19, 2006 Share October 19, 2006 Got my SP3 from Min Ghee at $28 for 4L. That works out to $7 per 1L. Comes in 4L container, might want to check with them if they sell by the L instead. Link to post Share on other sites More sharing options...
Virgin Neutral Newbie October 19, 2006 Share October 19, 2006 bros using Hyundai SPIII, Song yi can get for $25 Link to post Share on other sites More sharing options...
Dcturbo Neutral Newbie October 19, 2006 Share October 19, 2006 Yeap! Highly recommend this oil ... some more its fully-synthetic! Good value for money too! Link to post Share on other sites More sharing options...
Multi 3rd Gear October 19, 2006 Share October 19, 2006 Where to get this oil and how much? Link to post Share on other sites More sharing options...
Nullbig Clutched October 19, 2006 Share October 19, 2006 Quote Thanks all for your prompt and helpful response! Forgot to mention that my ride is Tuscani 2.0A. Elantrahatch: Is yours a drain & top-up or a full flush (which uses 10L or so of ATF)? When i checked with CAS they only use mineral, not synthetic ATF. Anyone can advise how often do we flush our engine? Like say after how many drain and top-up?? Link to post Share on other sites More sharing options...
Patrickquek Neutral Newbie October 20, 2006 Author Share October 20, 2006 I was quoted $17.50 for RP ATF at Earthworm (Dawson Place Shopping Ctr). Got my RP 5W30 engine oil at $12.90/l there. I called Song Yi - its $25 for 4L of Hyundai SPIII ATF. Another $35 for ATF filter + gasket. I assume its mineral and not the fully synthetic type... Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 20, 2006 Share October 20, 2006 (edited) As far as I know, ALL RP engine oil & ATF is fully synthetic. I used to get my RP from the importer, Pacific Petroleun, Mr. Brown is the boss. But his prices keep going up since a couple of years back & I found a kaki in here who can also supply at a better price. U can also try MX Trdg as I see them mentioned several times as RP supplier. I got a couple of bottles of RP ATF left but wil change to the Toyota ATF for my next flush cos their price is better. I am moving away from RP cos their prices keep rising. Maybe cos they getting too popular? But if u using Diaqueen then u CANNOT use RP ATF anyway cos it's Dexron III. Last time my Hyundai was using Dexron ATF so I cud use RP. Edited October 20, 2006 by Pisces69 Link to post Share on other sites More sharing options...
Genie47 1st Gear October 20, 2006 Share October 20, 2006 SPIII is specified by MMC to be a synthetic blend on paper. If they list it as SPIII it must follow the minimum requirements of SPIII by MMC. Therefore, there is no such thing as "mineral SPIII". ↡ Advertisement Link to post Share on other sites More sharing options...
Petrol Discounts in Singapore
Where you cut your hair?
