Ambious Neutral Newbie October 16, 2006 Share October 16, 2006 Was just wondering if anyone here ever put home speaker into the car and use it as car speaker or vice vesa? I notice that the ohm and max watt output is the same on a 5" speaker of a home theatre system and thought of trying it out in the car. Also, thought of plugging the woofer from the car into the home hi-fi. Will there be any side effects or explosion? Eva ↡ Advertisement Link to post Share on other sites More sharing options...
Headshok 1st Gear October 16, 2006 Share October 16, 2006 here's my understanding lah. home spkrs are generally 8 ohm, car spkrs are 4 ohm. if u put an 8 ohm spkr in a car (off an amp which pushes nominal power @4ohms), the amp will only push out 1/2 of the power due to the higher impedence. but if u put a 4 ohm spkr on a home system which accomdates 8 ohm only, this aint too healthy for ur home amp. but i tink most home amps can take 4ohm loads (the cheap technics one i had could do it). i'm sure there's a more cheem explanation, but this is my 2 cents lah cheers Link to post Share on other sites More sharing options...
Ilovesupremo Neutral Newbie October 17, 2006 Share October 17, 2006 i guess sound quality will be different from the home as it do not have enough to power max the speaker whein it's in the car. Link to post Share on other sites More sharing options...
Ac67 Neutral Newbie October 17, 2006 Share October 17, 2006 (edited) i think the difference is the material used for the speaker/boxes. car as you know is more harsh than home use. otherwise, the built and design of car and home speaker should be very similar - with just one difference - car speakers are designed for close proximity listening and home audio speaker is for wide-hall listening with beaming for a sweet-spot. but then this can be compensated using DSP processing. Edited October 17, 2006 by Ac67 Link to post Share on other sites More sharing options...
Ac67 Neutral Newbie October 17, 2006 Share October 17, 2006 some home audio component speakers are also 2-4ohm impedance. Link to post Share on other sites More sharing options...
Sarong1 1st Gear October 17, 2006 Share October 17, 2006 I think the passive crossover in home application may be built differently from that of the car. I am not sure. Slonez may be able to provide some advice. Link to post Share on other sites More sharing options...
Wankie Clutched October 17, 2006 Share October 17, 2006 i have seen HK mags where they test car spkrs using home audio equipment. tweets & drivers installed in cabinets with the x-over sitting on top Link to post Share on other sites More sharing options...
Sarong1 1st Gear October 17, 2006 Share October 17, 2006 Yes, I have seen that too...but have not heard the actual ones for a full audition. . Have you??? Link to post Share on other sites More sharing options...
Ractis Neutral Newbie October 17, 2006 Share October 17, 2006 There shouldnt be any explosion but the main factor here could be the mounting/enclosure differences. The 5" home theatre speaker driver could be optimized for a box of certain volume, and either sealed or ported for eg. You will not be able to get the same situation when the 5" is mounted in your car door. It may work out okay but chances are that the home theatre speaker wouldnt sound optimal in a door. To make an educated guess, you might need to know the thiel/small parameters of the speaker driver in concern, the volume of air in your door and whether or not you have a layer of sound insulation to act as a baffle in the car door. Link to post Share on other sites More sharing options...
Ac67 Neutral Newbie October 17, 2006 Share October 17, 2006 just occurred to me, will any car designer actually design the car door panel to work like a speaker box? thus providing top-end audio from stock? Link to post Share on other sites More sharing options...
Ambious Neutral Newbie October 17, 2006 Author Share October 17, 2006 Hi, some of u had mention about the driver thingy. What's that thing, how it works and where to find it? Eva Link to post Share on other sites More sharing options...
Ericrio Neutral Newbie October 17, 2006 Share October 17, 2006 Wht abt connecting a 18V Altec Lansing Subwoofer (PC) to a car HU, viable? Link to post Share on other sites More sharing options...
Wankie Clutched October 18, 2006 Share October 18, 2006 its the mid bass unit, the big cone & basket thingy Link to post Share on other sites More sharing options...
Ac67 Neutral Newbie October 22, 2006 Share October 22, 2006 Check http://en.wikipedia.org/wiki/Loudspeaker to understand what we meant by 'driver'. Link to post Share on other sites More sharing options...
Xtravel Neutral Newbie October 22, 2006 Share October 22, 2006 can... if you are technically incline. read the specs before hooking up ↡ Advertisement Link to post Share on other sites More sharing options...
Simple home DIY repairs
Home Aircon
Home Aircon
Home renovation tips
