Lexxmexx Neutral Newbie October 10, 2006 Share October 10, 2006 Previously, my anti-slip mat had melted on my dashboard which left bits and pieces of the mat on the surface, and cannot be removed by normal wiping. So after hearing some comments here that using lighter fluid might help, I tried with alcohol swabs which i thought might be a substitute for the lighter fluid. Yes, some of the mat stains were removed but it seems like a layer of my black dashboard surface was stripped as well. Now, I can see a big whitish and somehow sticky patch on the area where I had used alcohol to rub. I had used the Autoglym Vinyl and Rubber care lotion but the whitish patch is still there. Are there any ways to get rid of the white patch and restore my dashboard back to to normal? Thanks in advance! ↡ Advertisement Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 10, 2006 Share October 10, 2006 I think u r making the problem bad to worse. Now u have to custom make a fabric cover to put on your dash to cover the stains. Or use another non-slip mat to cover the stain. Back to square 1. Link to post Share on other sites More sharing options...
Yanuk Neutral Newbie October 10, 2006 Share October 10, 2006 alcohol and lighter fluids are different stuff... Link to post Share on other sites More sharing options...
Lexxmexx Neutral Newbie October 10, 2006 Author Share October 10, 2006 Ya man, I learnt that lesson the hard way. Now see if there's any way to fix it. Link to post Share on other sites More sharing options...
Nutty 4th Gear October 10, 2006 Share October 10, 2006 Ops... looks like you have made an unrepairable damage to your dashboard. Ever considered spraying your dashboard? I had the same experience of melting slip mat on my dashboard. I dare not use anything to wipe other than my vinyl protectant. Everyday rub a bit, the residue slowly came off. Link to post Share on other sites More sharing options...
Lexxmexx Neutral Newbie October 11, 2006 Author Share October 11, 2006 Dunno whether Kiwi can help to restore the blackness or not? Link to post Share on other sites More sharing options...
Nutty 4th Gear October 11, 2006 Share October 11, 2006 Kiwi? Your passenger will when they put their hands on the dashboard. Link to post Share on other sites More sharing options...
Lexxmexx Neutral Newbie October 11, 2006 Author Share October 11, 2006 Aiyah, of course will polish clean one lah. then one more layer of the vinyl care to 'seal' it. Will try it this weekend, hopefully it works Link to post Share on other sites More sharing options...
Cspeck Neutral Newbie October 11, 2006 Share October 11, 2006 may be wipe with a little petrol can help. try before to removed the dubble sidder tape balance at deshboard Link to post Share on other sites More sharing options...
Yanuk Neutral Newbie October 11, 2006 Share October 11, 2006 you ever tried? or are you asking Lexxmexx to try on your behalf since his dashboard already koyak liao. you try on your dashboard first then let us know k? Link to post Share on other sites More sharing options...
Cspeck Neutral Newbie October 11, 2006 Share October 11, 2006 (edited) I try already . to removed the dubble sidder tape at dashboard also to removed the sticky patch area after that do some polishing then done. Edited October 11, 2006 by Cspeck Link to post Share on other sites More sharing options...
Droozy Neutral Newbie October 11, 2006 Share October 11, 2006 mmm.. me ever have some white patches after i put a wet cloth for drying then i use amourall protectant and rubbed a few times.. it was ok till now.. maybe u can try ? Link to post Share on other sites More sharing options...
Nutty 4th Gear October 11, 2006 Share October 11, 2006 Hey sis, I used Armourall protectant to clear off my melted anti-slip mat residue too. Also need to rub a few times. Link to post Share on other sites More sharing options...
Lexxmexx Neutral Newbie October 11, 2006 Author Share October 11, 2006 The Armourall protectant, is it similar to the Autoglym vinyl and rubber care solution? Using petrol ah? Sounds dangerous leh....will try during the next pump nevertheless. The white patch is like those scratch marks when u scratch on rubber surfaces (try scratching a football). Now dashboard koyak liao, can bochap and try all suggested methods. Thanks everyone Link to post Share on other sites More sharing options...
Lexxmexx Neutral Newbie October 11, 2006 Author Share October 11, 2006 Quote I try already . to removed the dubble sidder tape at dashboard also to removed the sticky patch area after that do some polishing then done. Bro, what did u you use to polish? Link to post Share on other sites More sharing options...
Cspeck Neutral Newbie October 11, 2006 Share October 11, 2006 use BxxxxMXXXX, Link to post Share on other sites More sharing options...
Lexxmexx Neutral Newbie October 12, 2006 Author Share October 12, 2006 huh? what is BxxxxMXXXX ah? Link to post Share on other sites More sharing options...
Cspeck Neutral Newbie October 12, 2006 Share October 12, 2006 Black Mxxxc ↡ Advertisement Link to post Share on other sites More sharing options...
Wads the fine for parking opposite continuos white line?
Whiter than white? Christopher De Souza
Dashboard wrap
Dashboard wrap
Questions on Toyota Altis dashboard
White Horse Demonstrate Horsepower
Whatsapp updates
Whatsapp updates
How do you maintain your white car?
Something to get off my Chest About Mercedes Cars
