Macross1 Neutral Newbie September 22, 2006 Share September 22, 2006 I've got a silly question. Why aren't steering wheels built to a turning ratio of 1:1? E.g. If you turn the Steering wheel of the car 90 degrees, the wheel should turn 90 degrees as well. Wouldn't a car like that be easier to drive? Just wondering.... ↡ Advertisement Link to post Share on other sites More sharing options...
Atlantis_boi Clutched September 22, 2006 Share September 22, 2006 Wun this make the car's steering ultra sensitive? This wuld b dangerous at high speed Link to post Share on other sites More sharing options...
Macross1 Neutral Newbie September 22, 2006 Author Share September 22, 2006 Also means you can avoid danger quicker no? Link to post Share on other sites More sharing options...
Slayer Clutched September 22, 2006 Share September 22, 2006 rather , it require a more steady hand to handle your car at higher speed. mean high risk of going into longkang for nothing. :) avoid danger don't need turn too much one lah. right? Link to post Share on other sites More sharing options...
Zyrofillica 1st Gear September 22, 2006 Share September 22, 2006 wah like tt i dig my nose with my left hand and the weight of my right hand of about 3kg, shifts the wheel down 5cm and taking into account the diameter of my stock steering wheel, it would move clockwise 2 degrees, my wheels would the turn out 2 degrees to the right? So if im on the expressway at 100km/h, or rather at 27m/s... my car will shift to the right at 3.5m/s... so effectively ill do a lane change just by digging my nose Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear September 22, 2006 Share September 22, 2006 in addition to the dangers. have you parked a car without power steering... imagine that while needing even more force. Btw, the power steering would need to be pretty darn massive to handle that and the elect power steering motors cant get enough power from the batt to allow that kind of ratio. Link to post Share on other sites More sharing options...
Ambious Neutral Newbie September 22, 2006 Share September 22, 2006 Very detail Eva ↡ Advertisement Link to post Share on other sites More sharing options...
Wheel Spacer Installation DIY
Wheel Spacer, where to buy?
Steering leather wrapping
Wheel Hubs
Wheel Hubs
Porsche’s First Steer-By-Wire System Is Designed For Less Feedback, Not More
Steering column
Steering column
