Zrun Neutral Newbie September 19, 2006 Share September 19, 2006 I helped my friend replace engine oil for this 2002 Ford Focus (in USA, 2.0 ZETEC engine).He has about 60k km on his car, and I found that the middle part of the engine is oily, to the point of forming drips. This is observable near/under the exhaust manifold area.Valve cover, oil pan, front/rear seals are completely dry. Does this mean the head gasket is bad? Is this a common problem? ↡ Advertisement Link to post Share on other sites More sharing options...
Gz0707 4th Gear November 9, 2006 Share November 9, 2006 is ur friend's problem solved? if not u may want to try the ford forum below : http://www.madsumm.org/smf/ fyi - the US model is also known as the older Mark I model here locally. Link to post Share on other sites More sharing options...
Zrun Neutral Newbie November 13, 2006 Author Share November 13, 2006 problem solved. it is just the valve cover gasket. I looked carefully again. These cars are famous for premature valve cover gasket problem. ↡ Advertisement Link to post Share on other sites More sharing options...
Comparing Opel Astra 1.6 Twinport and Ford Focus 1.6 H/B
2018 / 2019 Ford Focus
How Head Unit Can Be A Part of Entertainment?
Payment mode for changing HU
Head Unit upgrade(Apple CarPlay)
Android Head Unit - Video
Pioneer Head Unit
Pioneer Head Unit
