Sunray Neutral Newbie September 22, 2006 Share September 22, 2006 Haven't got chance to go thru the manual. My authorised service centre only carries W30 (from Japan) and W40 (from US) syn oil. ↡ Advertisement Link to post Share on other sites More sharing options...
Cmsense Neutral Newbie September 22, 2006 Share September 22, 2006 Last visit I ask the chief mec a similar question. He say 20 or 30 is ok for lightfoot driver. For heavyfoot who often rev the rpm is better to stick to 40 or above for more protection. Rev often cause high heat and 20 oil become too watery offers less protection and engine wear off more. Engine will not wear off immediately but more in longer run resulting drop of power and more smoke. For urban driver change oil more often is better. I think his explanation makes sense. Manufacture sure like people to change more often Link to post Share on other sites More sharing options...
Sunray Neutral Newbie September 22, 2006 Share September 22, 2006 Got it from a helpful lady at the service centre. Ok, min is 0W30 as stated in the owner's manual. Link to post Share on other sites More sharing options...
Trex101 3rd Gear September 22, 2006 Share September 22, 2006 My apologies to hitch a ride on this thread. Can anyone comment on the Caltex Havoline engine oils? Seems like it is not a common oil to be discussed in the forum.. The USA version Havoline mineral oil contains a heavy dose of "Moly", in the range of 400-500ppm. It's very highly regarded in BITOG and is consider as one of the best mineral oil around. Oh, fyi Havoline & Chevron Supreme are the exact same product produce by the same company. Havoline 10w30 http://www.mxxxxxxxxs.com/Chevron/PDSHavoline10w30.pdf Chevron Supreme 10w30 http://www.mxxxxxxxxs.com/Chevron/PDS10w30.pdf Link to post Share on other sites More sharing options...
Victorco 2nd Gear September 22, 2006 Share September 22, 2006 (edited) Getz auto 1.3 can hit 14km/l with 50%/50% plus 2 adult and aircon and shift at 3k normally... using w30 and on 16" rim. your tomyam how many user wat % e'way/city? aircon? shift at rpm? auto/manual? Edited September 22, 2006 by Victorco Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear September 22, 2006 Share September 22, 2006 Go looks at the viscosity vs temp chart in the manual. the single reccomended viscosity is an all rounder for many extremes. Link to post Share on other sites More sharing options...
Sabian Turbocharged September 22, 2006 Share September 22, 2006 huh? Link to post Share on other sites More sharing options...
Genie47 1st Gear September 23, 2006 Share September 23, 2006 This is indeed the season of Bullsh1t! This is the worse kind of BS I have every seen! Link to post Share on other sites More sharing options...
Cmsense Neutral Newbie September 24, 2006 Share September 24, 2006 Izzit? I mention to him that I hear people say 20 oil is very ok. The chief mec say, sure ok because the people who say not paying for the tear and wear in the engine. The owner is. If anything wrong the owner need to replace parts or scrap and replace the car. He say if car rev with thin oil will guarantee wear off more, make sense? What do you think ah? Link to post Share on other sites More sharing options...
Trex101 3rd Gear September 24, 2006 Share September 24, 2006 Ask him to prove it! There's alot of UOA that has proven beyond doubt that under normal (non-racing) situation, 20wt oil protects the engine as well as 40wt oil in our tropic climate. Link to post Share on other sites More sharing options...
Genie47 1st Gear September 25, 2006 Share September 25, 2006 Check with the Honda drivers who have made a switch to 20wt oil. Their engines are made for it. Ditto with Ford and Mazda and now Toyota. Other car makes, check manual but 20wt will become standard. Link to post Share on other sites More sharing options...
Thermodynamics Neutral Newbie September 26, 2006 Share September 26, 2006 Hi Genie You seem to know a lot about engine oil. I currently driving a new car. The manual says servicing for 1k 5k and 10k should be done in 1mth, 3mth and 6mth respectively. Should I follow the milage or interval? For example, after 1 mth if my milage is only 600km, should I go change the oil? Or wait until 1000km which should take more than a month? Should I stick to mineral for 1k and 5k servicing and then use synthetic for 10k servicing? Will it do any harm to my engine if I use a thin oil at 10k servicing? Any recommendations? Link to post Share on other sites More sharing options...
Genie47 1st Gear September 26, 2006 Share September 26, 2006 If you make 600km/mth, I suggest a 6mth interval. If you make 10k in 4mths, then I suggest a 3mth interval. Thin oil will not harm your engine. New car engines like their oil thin. Link to post Share on other sites More sharing options...
Thermodynamics Neutral Newbie September 26, 2006 Share September 26, 2006 But what about new car? For 1k servicing, should I go after one month even though I have not reach 1000km yet? Link to post Share on other sites More sharing options...
Genie47 1st Gear September 26, 2006 Share September 26, 2006 1k servicing is obsolete. The factory fill in the car is the best synthetic ol there is by the manufacturer. Best got 10k then drain but I doubt your retailer is going to let you do that. Link to post Share on other sites More sharing options...
Thermodynamics Neutral Newbie September 26, 2006 Share September 26, 2006 But I thought the first 1k is running in period so there will be lots of metal deposits floating around the oil hence should drain more often? Or else would not they act as abrasives to the piston and rings? Link to post Share on other sites More sharing options...
Genie47 1st Gear September 26, 2006 Share September 26, 2006 You filter is there to catch them, right? Link to post Share on other sites More sharing options...
Thermodynamics Neutral Newbie September 26, 2006 Share September 26, 2006 So why do all the car sellers advocate the 1k, 5k and 10k servicing schedule? To sucker our money? ↡ Advertisement Link to post Share on other sites More sharing options...
Change Disc Rotors
Change Disc Rotors
Tool to change Spark Plug
X for twitter change request
ATF oil change
ATF oil change
