Weixiang_06 Clutched September 2, 2006 Author Share September 2, 2006 the rev will be quite high wor... ↡ Advertisement Link to post Share on other sites More sharing options...
Lucien Neutral Newbie September 2, 2006 Share September 2, 2006 Nope. 1.5k rpm. My car can roll in gear2 or even 3 without stepping on gas, it will keep moving w/o stall Link to post Share on other sites More sharing options...
Weixiang_06 Clutched September 2, 2006 Author Share September 2, 2006 for gear 3, i use it for slowing down.... that's the lowest i would go.. and let it roll for tens of metres, below the speed get low <30km/h.. that's where i apply brakes and clutch in.... i seldom engage in the lower gears... not sure whether my method is correct or not... but for me. i find no need to engage to gear 2 for slowing down.. gear 3 sufficient.. then roll until <30km/h then brake in, clutch and complete stop. your are driving an accent right? my previous ride was a marchie... Link to post Share on other sites More sharing options...
Kwchan 1st Gear September 2, 2006 Share September 2, 2006 how about half clutch at gear 1, then upshift to gear 2? mine is diesel engine, so gear 2 still very powerful. that's why if i let go the clutch at gear 1, the vehicle will jerk badly. but if i stick to gear 2, the engine also vibrate badly. not sure which is the best method too, if half clutch too much also not good for the clutch Link to post Share on other sites More sharing options...
Lucien Neutral Newbie September 2, 2006 Share September 2, 2006 Yes mine accent. For me, i nvr used gear 2 to slow down(unless its downslope). Only for pickup. Gear 3 is more than enough to brake. 30km/h is gd enough to use brakes fully to bring to stop. Can clutch in. No probs. For jams, try put to gear 2 and let it roll off by itself. Dun wory, should not stall. Mine can roll at 15km/h at gear 2. It will not stall. So normally, i creep behind at gear 2. And by the time i reach the car infront, they would have move off. so no braking and continue. Unless the front car complete stop. Then LL gear 1 again. Link to post Share on other sites More sharing options...
Lucien Neutral Newbie September 2, 2006 Share September 2, 2006 ur engine vibrate badly @ gear 2 w/o stepping gas? If u have tat prob, u can always half clutch in with gear 2 as well, then use it like gear 1. should have smoother pace. Link to post Share on other sites More sharing options...
Kwchan 1st Gear September 2, 2006 Share September 2, 2006 Quote usually i just slow down the car purposely to less than 10km/h, then engage 1st gear and catch up. not necessary to maintain constant distance frm the car infront mah do that during the jam and the car behind probably think u road hog driver become more impatient during jam, if cannot keep a close distant with vehicle in front, surly will let other cars cut in (esp cab), then got to jam brake will be even worse Link to post Share on other sites More sharing options...
Lucien Neutral Newbie September 2, 2006 Share September 2, 2006 No worry lar. let them cut they cut lor. Why u want to keep up with front car. Behind car think u hog? Let them think lor. Safety and wallet more important that those behind cursing u. Link to post Share on other sites More sharing options...
Weixiang_06 Clutched September 2, 2006 Author Share September 2, 2006 ya lor.. so i tend to stay away from half clutch... for me, i would prefer the shifts to be clean cut... so upshifting and downshifting is good but for the downshifting to the lower gears (1st and 2nd) that i usually dun do... its a bit tricky for me... if i want smoothness.. have to use the clutch delay thing... i dun want premature clutch wear leh... but i think at least i can pat my shoulder.. coz my friend asking me you are driving a auto ride, i say no... why leh? she said coz feel smooth... but those were in situations without the super massive jams.... come to jam hor, quite a bit different le.. Link to post Share on other sites More sharing options...
Kwchan 1st Gear September 2, 2006 Share September 2, 2006 after get used to it i can feel if i should half clutch or let go all the way. the engine wont vibrate at gear 2 or gear 3 w/o stepping gas, provide that the speed match. Link to post Share on other sites More sharing options...
Lucien Neutral Newbie September 2, 2006 Share September 2, 2006 Then should be fine. Use gear 2 in jams is gd nuff. Can always let it roll by itself. No need to go down to 1 lor. Link to post Share on other sites More sharing options...
Weixiang_06 Clutched September 2, 2006 Author Share September 2, 2006 think singapore traffic really getting bad to worse... next time, i think i will opt for a auto ride... driving 40 months of manual.. i feel abit tired le... haha... next time need to keep my left hand free for some other things le... Link to post Share on other sites More sharing options...
Kwchan 1st Gear September 2, 2006 Share September 2, 2006 (edited) Quote For jams, try put to gear 2 and let it roll off by itself. Dun wory, should not stall. Mine can roll at 15km/h at gear 2. It will not stall. provide that you are not on an up slope. flat or slightly downslope surly can work. if up slope, better change to gear 1, wait engine stall and u start to roll backward Edited September 2, 2006 by Kwchan Link to post Share on other sites More sharing options...
Lucien Neutral Newbie September 2, 2006 Share September 2, 2006 no wory bro. ur clutch is not as weak as u think it is. Anyways, replace clutch is not as exp as serving a broken auto tranny. Auto tranny cost over $3-5k to replace. Link to post Share on other sites More sharing options...
Lucien Neutral Newbie September 2, 2006 Share September 2, 2006 Yes upslope then LL. But sometimes upslope if u half clutch in gear 2 should be able to go up. But rev hard. maybe 2-2.5k rpm. Link to post Share on other sites More sharing options...
Weixiang_06 Clutched September 2, 2006 Author Share September 2, 2006 mmz... but those jam where ur speed is cut to Link to post Share on other sites More sharing options...
Weixiang_06 Clutched September 2, 2006 Author Share September 2, 2006 mmz.. that was what i taken into consideration... its like the clutch (fully assembly) is 1k right? and servicing cheaper and simpler compared to auto.... some more, manual more power, better FC... better control.... can use engine brake, reduced brake pad wear and etc.... and cheaper somemore... that's why i chose back a manual again.. Link to post Share on other sites More sharing options...
Lucien Neutral Newbie September 2, 2006 Share September 2, 2006 If 10km/h and u feel lag in gear 2. Clutch in and rev harder, then release it as if were gear 1. But have to have gd leg muscles. And dun cramp. LOL!!! ↡ Advertisement Link to post Share on other sites More sharing options...
Driving in Europe
Driving in Europe
Strange Mural at Holland Drive Food Center
Home renovation tips
