Kk88 Neutral Newbie August 24, 2006 Share August 24, 2006 Make : Honda city Age : 1.3yrs. Just change CVT oil, and front brakes. So, what else do it need to change other than enigne oils @40,000km? Thanks Thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Teddi Neutral Newbie August 24, 2006 Share August 24, 2006 Change 1- Sparkplugs 2- Oil & Fuel Filter Feeling Rich? 1- Shock Absorbers (front & Back) 2- Top up aircon oil & gas 3- Flush & change new Coolant, brake fluid & Power steering fluid Link to post Share on other sites More sharing options...
Kk88 Neutral Newbie August 24, 2006 Author Share August 24, 2006 dun feel rich.... 40,000km not consider major servicing? Link to post Share on other sites More sharing options...
Redfever Neutral Newbie August 24, 2006 Share August 24, 2006 (edited) For my 40k servicing, the following were done .... - Coolant flushed and replaced - Fuel Pump filter replaced - Air Con filter replaced - Engine Oil replaced - Oil Filter replaced - Brake Fluid replaced - Spark Plugs inspected - And the normal 23 Point checks Car serviced with Agent.4OK considered a major servicing for my ride. Edited August 24, 2006 by Redfever Link to post Share on other sites More sharing options...
Kk88 Neutral Newbie August 25, 2006 Author Share August 25, 2006 Thanks bro, What's the damage done with servicing with the agent? I am planning to cut cost and go for comfort. Does comfort provides all these service? Thanks Link to post Share on other sites More sharing options...
Redfever Neutral Newbie August 29, 2006 Share August 29, 2006 Cost me an unbelievably whopping $536 bucks!!! Link to post Share on other sites More sharing options...
Stingerquek Clutched August 29, 2006 Share August 29, 2006 Did my 40k servicing 2 wks back at Kah motor.Bring down my own engine oil and cost me around $350.Forget about what they change already ,can call and check with them Btw,I'm also driving City Link to post Share on other sites More sharing options...
Magiclamp Neutral Newbie August 31, 2006 Share August 31, 2006 Hi Redfever, What is the normal 23 point checks? Link to post Share on other sites More sharing options...
Hosaybo 6th Gear August 31, 2006 Share August 31, 2006 In comfort aka CAS, major servicing you can try their enhance servicing package that cost around 200++ for syn oil. however, their package does not include change of transmission oil (which I feel is important at 40K... some bro even do a flushing)and they only clean your air filter. Link to post Share on other sites More sharing options...
Kk88 Neutral Newbie September 1, 2006 Author Share September 1, 2006 WoW..........i think i better aviod Kah motor... Thanks for the tips! Link to post Share on other sites More sharing options...
Kk88 Neutral Newbie September 1, 2006 Author Share September 1, 2006 Hey, thanks bro... planning to go CAS...tranmission oil is it? the CVT gear oil? If yes, i just had it change FOC at kah.... Link to post Share on other sites More sharing options...
Linus Clutched September 1, 2006 Share September 1, 2006 usually for jap cars, every 40k is considered a major service. Link to post Share on other sites More sharing options...
Kk88 Neutral Newbie September 1, 2006 Author Share September 1, 2006 thanks bro Link to post Share on other sites More sharing options...
Redfever Neutral Newbie September 1, 2006 Share September 1, 2006 Check / Inspect / Top up certain parts .....Examples are - Check Fuel lines - Top up Brake Fluid - Inspect Spark Plugs - Timing belt inspection - Check Steering Fluid - Clean Air Filter - Tyre rotation n balancing - Top up Wiper Fluid - Check Air Con system - Top up Air Con gas .....blah ...blah....blah.....Cant remember the rest leh. Link to post Share on other sites More sharing options...
Picanto 3rd Gear September 2, 2006 Share September 2, 2006 the important thing is do they really top up/inspect those things mentioned in the checklist? Link to post Share on other sites More sharing options...
Vblaster_w211 2nd Gear September 2, 2006 Share September 2, 2006 (edited) For 30K to 40K servicing, besides the usual, should look out for: 1. Transmission oil change 2. Checking brakes (change brake pads if needed) and bleeding of brake fluid 3. Change spark plugs (if non Iridium) 4. Rotate tyres (balance if necessary) For 60K, fuel pump filter change. Frankly, as for the "x" no of checks, I always wonder if they even bother to really do so. I also believe in changing air filter every 10K or so, unless you're on performance air filter - nothing robs performance like a clogged up air filter, especially if you're on TB or SC. You can "air pressure" clean it, but it's never the same as brand new. Edited September 2, 2006 by Vblaster_w211 Link to post Share on other sites More sharing options...
Redfever Neutral Newbie September 2, 2006 Share September 2, 2006 You are maybe right....My observation is.... some things they really do check....others, they just seem to go thru the motion. Link to post Share on other sites More sharing options...
Magiclamp Neutral Newbie September 6, 2006 Share September 6, 2006 Thanks Redfever! ↡ Advertisement Link to post Share on other sites More sharing options...
Change Disc Rotors
Change Disc Rotors
Need Advice on Self Storage
Tool to change Spark Plug
X for twitter change request
