Quantum 5th Gear August 3, 2006 Share August 3, 2006 last week I pumped up my tyres, I found some water and oil around the nozzle , so I worry the water and oil has gone into my tyres , so sad it will corrupt tyres the fuccking air pump station ↡ Advertisement Link to post Share on other sites More sharing options...
Caltis Neutral Newbie August 3, 2006 Share August 3, 2006 In any case, the air you pump at most station will also contain moisture, i doubt they will spend money to put in a dryer. Oil compressor are cheaper than oil-free compressor and thus they are used in most pump station. But still you should not see oil in the air or coming out from the tube unless its a major leak..............which also means the compressor also KABOOMMMM...already Link to post Share on other sites More sharing options...
Quantum 5th Gear August 3, 2006 Author Share August 3, 2006 is the oil air harmful for tyre?? Link to post Share on other sites More sharing options...
Yeobh 4th Gear August 3, 2006 Share August 3, 2006 (edited) Don't expect too much as the service point provided is FOC. Water and compression lub oil will not do any harm to your tyres. Edited August 3, 2006 by Yeobh ↡ Advertisement Link to post Share on other sites More sharing options...
Family of three electrocuted to death at Taman Jurong
