Frost98 1st Gear July 15, 2006 Share July 15, 2006 Hi folks, I am thinking of buying some gear oil for my car. But I do not know how much I will need. Anyone has any idea? Thanks. ↡ Advertisement Link to post Share on other sites More sharing options...
Hungryforcar 1st Gear August 17, 2006 Share August 17, 2006 Dun buy, just go to the workshop and changed the new gear oil. I not sure how are you going to change the oil. i saw the workshop is using some machine to drain the oil out from the gear box below and pump in the new gear oil. Link to post Share on other sites More sharing options...
Octopus 3rd Gear August 18, 2006 Share August 18, 2006 Not sure about your car, but mine corolla G6 took in exactly 3 quarts. I've tried Mobil 1 synthetic 75w90, and currently using Redline MT-90. Both synthetic gear oil indeed provide much better shifting than those normal gear oil provided by workshops. Do check if your gearbox is using GL4 or GL5 specification gear oil. Link to post Share on other sites More sharing options...
Frost98 1st Gear August 19, 2006 Author Share August 19, 2006 Mazda 121 is GL4, capacity is 2.5L. Thanks to all whom reply. Anyway, what is the difference betw GL4 and GL5? Link to post Share on other sites More sharing options...
Octopus 3rd Gear August 20, 2006 Share August 20, 2006 GL4 spec. is for gear box which contain yellow metal component, such as brass, bronze, etc. it will not attack these yellow metal component inside. GL5 spec. is usually meant for differential gearbox, such as those you see on lorry where they have a gear box at the rear axle, or cars which are rear-wheel drive but engine infront. Those differential gearbox required GL5 cos this spec. contain sulfur additive, which will attack yellow metal component. The presence of sulphur additive cos its a extreme pressure (EP) additive. Quite difficult to find GL4 gear oil, I only know Redline which is a pure GL4 spec from MxTading, or Royal Purple which is a GL4/GL5 spec gear oil. I think Mobil 1 synthetic gear oil at Autobac is also GL4, if I'm not mistaken... ↡ Advertisement Link to post Share on other sites More sharing options...
MAZDA 6
MAZDA 6
2025 Mazda 6e
2025 Mazda 6e
2026 Mazda EZ-60 / CX-6e
Mazda FC3S RX-7
Mazda FC3S RX-7
Win a Limited-Edition Mazda RX-7 Diecast in Sgcarmart livery!
2022 Mazda CX-5 Facelift
Original Mazda MX-5 chief designer dead 😢
