Earthboy 4th Gear September 30, 2014 Share September 30, 2014 like that you sibei lucky lei. PM me your car number. we go buy 4d. :) so would you be changing all 4 or just get a replacement? no....this wan is the original wan. The wan from previous page was the right side.....this one is left side....T1R cannot change left to right. ↡ Advertisement Link to post Share on other sites More sharing options...
Evillusion Supersonic September 30, 2014 Share September 30, 2014 (edited) like that you sibei lucky lei. PM me your car number. we go buy 4d. :) so would you be changing all 4 or just get a replacement? i just changed all 4 rims.......saw my money got wing.....flap flap away.....sibei sad! Lucky they had a used t1r and manufacturing date nearly the same as my previous. Now car is pulling to the right......got to go for wheel alignment........there goes my money again! The tyre guys say t1r can swop left right but must take out from rim and do the swop.........! ok....go buy 4d....8908! Edited September 30, 2014 by Eviilusion Link to post Share on other sites More sharing options...
Earthboy 4th Gear September 30, 2014 Share September 30, 2014 huat ah! alignment 50-70 nia, not too bad lar. i just changed all 4 rims.......saw my money got wing.....flap flap away.....sibei sad! Lucky they had a used t1r and manufacturing date nearly the same as my previous. Now car is pulling to the right......got to go for wheel alignment........there goes my money again! The tyre guys say t1r can swop left right but must take out from rim and do the swop.........! ok....go buy 4d....8908! Link to post Share on other sites More sharing options...
Evillusion Supersonic September 30, 2014 Share September 30, 2014 huat ah! alignment 50-70 nia, not too bad lar. i scared the wishbone will be bent due to the way i hit the bloody rock.....that will be expensive! Now i drive car tends to pull to right and something just doesnt feels right! Link to post Share on other sites More sharing options...
Earthboy 4th Gear September 30, 2014 Share September 30, 2014 i scared the wishbone will be bent due to the way i hit the bloody rock.....that will be expensive! Now i drive car tends to pull to right and something just doesnt feels right!Go get it check asap. Probably camber also kana. Link to post Share on other sites More sharing options...
Titank 1st Gear May 1, 2017 Share May 1, 2017 Anyone know still able to find TOYO PROXES T1R in Singapore? Link to post Share on other sites More sharing options...
ClesterClarence 2nd Gear May 1, 2017 Share May 1, 2017 Anyone know still able to find TOYO PROXES T1R in Singapore? OKAY What tire profile ? 1 Link to post Share on other sites More sharing options...
Titank 1st Gear May 1, 2017 Share May 1, 2017 What tire profile ? 205/55/R16 1 Link to post Share on other sites More sharing options...
SZ_ford 5th Gear June 26, 2019 Share June 26, 2019 hi, has anyone tried Proxes Sport? Supposed to be the successor for T1 Sport. Can't find much info about it online 1 Link to post Share on other sites More sharing options...
Cypher 4th Gear June 26, 2019 Share June 26, 2019 Can consider TR1. https://www.toyotires.com.my/tire/pattern/proxes-tr1 1 Link to post Share on other sites More sharing options...
SZ_ford 5th Gear June 26, 2019 Share June 26, 2019 Can consider TR1. https://www.toyotires.com.my/tire/pattern/proxes-tr1 thanks but seems like limited sizes looking for 265/35/19 Link to post Share on other sites More sharing options...
Roberttan 5th Gear July 2, 2019 Share July 2, 2019 thanks but seems like limited sizes looking for 265/35/19 this is not a very common size ,except on some sports model like BMW M / Porsche , if you are drving those Super car please do consider better Performance tire . Just MHO Link to post Share on other sites More sharing options...
SZ_ford 5th Gear July 2, 2019 Share July 2, 2019 this is not a very common size ,except on some sports model like BMW M / Porsche , if you are drving those Super car please do consider better Performance tire . Just MHO i also hope i'm driving a super car but i'm not, haha currently using 255/35/19 on my 19*9.5 rim which is a square look. I prefer the tyre to be slightly wider than rim for a meaty look. that's why i'm looking for 265. I do feel toyo is a rather good tyre. I have used proxes c1s before. for my style of driving, i don't need top top performance tyre thanks for advice though Link to post Share on other sites More sharing options...
Roberttan 5th Gear July 3, 2019 Share July 3, 2019 i also hope i'm driving a super car but i'm not, haha currently using 255/35/19 on my 19*9.5 rim which is a square look. I prefer the tyre to be slightly wider than rim for a meaty look. that's why i'm looking for 265. I do feel toyo is a rather good tyre. I have used proxes c1s before. for my style of driving, i don't need top top performance tyre thanks for advice though personally do not encourage to change your tire size like this. Tire size is technically first to consider when replaces. the looks like Squrare 1 st can be due to The constrcution or designed of the Tire Sidewall , 2nd your wheel widh can also change the sidewall look. switching from 255 to 265 for your case , you are taking a risk of rubbing fender. Link to post Share on other sites More sharing options...
SZ_ford 5th Gear July 3, 2019 Share July 3, 2019 personally do not encourage to change your tire size like this. Tire size is technically first to consider when replaces. the looks like Squrare 1 st can be due to The constrcution or designed of the Tire Sidewall , 2nd your wheel widh can also change the sidewall look. switching from 255 to 265 for your case , you are taking a risk of rubbing fender. thanks for the advice i did check the tyre label on my door. it can fit 275 wide tyre, haha it's safe for now ↡ Advertisement Link to post Share on other sites More sharing options...
New Ford Mondeo
New Ford Mondeo
Parking against traffic flow...beware
Toyo tyres made in Japan
Toyo Proxes CF2
Toyo Proxes CF2
TOYO C1S
TOYO C1S
Facelift Mazda 6
Facelift Mazda 6
