Apollo 1st Gear June 8, 2006 Share June 8, 2006 most likely cause is Engine mounting, esp if the steering is also vibrating badly. next possible cause is EGR fault. this 1 and the rest above mentioned can b traced thru Diagnostic. another cause is engine oil breakdown or use of very low viscosity oil which is not suitable for cars >60,000km eg 0W20. ↡ Advertisement Link to post Share on other sites More sharing options...
Ben50 Neutral Newbie June 8, 2006 Author Share June 8, 2006 Currently, I'm using 5W/40. Can I change to 0W/30? Link to post Share on other sites More sharing options...
Audi69 Neutral Newbie June 9, 2006 Share June 9, 2006 Go for it bro....your car engine will LOVE it Link to post Share on other sites More sharing options...
Ben50 Neutral Newbie June 9, 2006 Author Share June 9, 2006 Bro, my Pinic is already at 80KM...0W/30 will be too thin for my car engine right?? Link to post Share on other sites More sharing options...
Oilguy Neutral Newbie June 9, 2006 Share June 9, 2006 80,000 is still OK go ahead and try 0W30 Link to post Share on other sites More sharing options...
Nine_eleven 2nd Gear June 10, 2006 Share June 10, 2006 bro, how old is your picnic? Link to post Share on other sites More sharing options...
Ben50 Neutral Newbie June 10, 2006 Author Share June 10, 2006 34 months Link to post Share on other sites More sharing options...
Nine_eleven 2nd Gear June 10, 2006 Share June 10, 2006 oic... just before the warranty dries up... lucky! Link to post Share on other sites More sharing options...
Rooney Neutral Newbie June 11, 2006 Share June 11, 2006 how serious are the vibrations? Link to post Share on other sites More sharing options...
Rooney Neutral Newbie June 11, 2006 Share June 11, 2006 did they charge you for the overhaul of TB? Link to post Share on other sites More sharing options...
Ben50 Neutral Newbie June 12, 2006 Author Share June 12, 2006 Not very serious...once while....only when I stopped my ride. Link to post Share on other sites More sharing options...
Ben50 Neutral Newbie June 12, 2006 Author Share June 12, 2006 Yes, I paid for the overhaul. Link to post Share on other sites More sharing options...
Fnscasey Neutral Newbie June 12, 2006 Share June 12, 2006 Was driving a Kangoo. Does engine mounting experience vibration ONLY at Sationary Position ? My Kangoo has a mild vibration when starting the engine or sometime at stationary position. But since i bring my kangoo to service at CAS, changing brake pad, brake shoe, changing to synthetic oil from mineral oil.... Found the vibration is stronger than usual and it EVEN vibrate or rather the engine seem to 'push' the vehicle forward... Does mixing of mineral oil and synthetic oil has any avast effect on a vehicle ? Does engine mounting also causes a vechicle to vibrate(pushing forward) even when a vehicle is moving ? Link to post Share on other sites More sharing options...
Ben50 Neutral Newbie June 13, 2006 Author Share June 13, 2006 Sorry bro, I really do not know the answers. Any bro can help Fnscasey??? Link to post Share on other sites More sharing options...
Apollo 1st Gear June 13, 2006 Share June 13, 2006 nope... most likely is oil pressure but you should not mix mineral and synthetic ( i think if you do oil change is ok) Link to post Share on other sites More sharing options...
Fnscasey Neutral Newbie June 13, 2006 Share June 13, 2006 So mineral and synthetic should not be mixed ? Went to C#S for their service package and it comes with Fully synthetic oil change of 4L. So the mechanic will not drain away the mineral oil and just top up with the synthetic oil ! I thought they will at least inform or suggested to have an oil change to use synthetic oil... How would i know if mineral oil and synthetic oil can be mixed ? Link to post Share on other sites More sharing options...
Apollo 1st Gear June 13, 2006 Share June 13, 2006 who say? of cos remove oil filter 1st, unplug then drain off before topping mah mai scare urself. Link to post Share on other sites More sharing options...
Fnscasey Neutral Newbie June 15, 2006 Share June 15, 2006 Went down to a workshop recommended by ppl.... Told him my problem ( engine seem like pulling and pushing my car) Test drive my kangoo for a few round, say that it is not engine mounting but mainly the injector is clog and so when u are driving the diesel cannot flow smoothly causes the 'pull ans push' problem. Ask me to buy those STP addivities to clean it...... But will take 1-2 weeks to slove my problem... How true is this ? ↡ Advertisement Link to post Share on other sites More sharing options...
Driving in Europe
Driving in Europe
Strange Mural at Holland Drive Food Center
