Multi 3rd Gear June 27, 2006 Share June 27, 2006 Quote I personally feel that Sun's Hot Inazma range is one of the top VS around. Though a tad expensive, it works very well for me. Get another capacitor for your ICE (if u need the extra ommp) Agreed. Being using it since 2003 till now, no problem and its still working. ↡ Advertisement Link to post Share on other sites More sharing options...
Whitecvt Clutched June 27, 2006 Share June 27, 2006 don't think there is a way to tell which VS is good...... but i've tried RMK/Pivot/zstab (1st 2nd, ez-stab) ..... i still think z-stab and ez-stab feels the best... Link to post Share on other sites More sharing options...
Zimmy83 Neutral Newbie June 27, 2006 Share June 27, 2006 don't mind me askin but what is the volt stabilizer for actually??? Link to post Share on other sites More sharing options...
Atlantis_boi Clutched June 27, 2006 Share June 27, 2006 Quote don't mind me askin but what is the volt stabilizer for actually??? This topic on Volt Stab has been debated to death in the forum Do a search & u will get lots of answers Link to post Share on other sites More sharing options...
Mdfaz 2nd Gear July 2, 2006 Share July 2, 2006 how come the same thing happened to my max volt also? changed to pivot raizin already. heard it's good and recommended. Link to post Share on other sites More sharing options...
Frozebite Neutral Newbie July 2, 2006 Share July 2, 2006 Where you got your pivot from???Get from where @$80 Link to post Share on other sites More sharing options...
Wolverine Neutral Newbie July 2, 2006 Share July 2, 2006 Link to post Share on other sites More sharing options...
Frozebite Neutral Newbie July 2, 2006 Share July 2, 2006 Heard that to check the pivot is real one is to see the capacitor below is the +sign right ??? Link to post Share on other sites More sharing options...
Wolverine Neutral Newbie July 2, 2006 Share July 2, 2006 + is fake K is original .... Link to post Share on other sites More sharing options...
Frozebite Neutral Newbie July 2, 2006 Share July 2, 2006 oh so k is orginial . Thanks Link to post Share on other sites More sharing options...
Yc86 Clutched July 2, 2006 Share July 2, 2006 the caps i bought frm SLT also got the K on top... Link to post Share on other sites More sharing options...
Wolverine Neutral Newbie July 2, 2006 Share July 2, 2006 Click this http://www.pivotjp.com/imitation/imitation-raizin-e.html Link to post Share on other sites More sharing options...
Yc86 Clutched July 2, 2006 Share July 2, 2006 Quote Pls excuse me, can I know how to judge whether a VS is good or no good?My ride got no Amp, can I benefit from it? A VS is good if you can 'feel' the benefits... the more you pay, the more sensitive your 'feel' becomes Link to post Share on other sites More sharing options...
Yc86 Clutched July 2, 2006 Share July 2, 2006 Quote Extracted the following from: http://forum.onemotoring.com.sg/mvnforum/m...read?thread=103 Just ensure that the Voltage Stabilizer comes with 4 capacitors. The capacitors are the ones that help to stabilize the flow of current. one alone will not be very good. and its also good to have 5 grounding cables. these are for the:- 1. car body 2. firewall (on car body. between engine and driver) 3. distributor 4. cylinder head 5. alternator it is also good to buy those stabilizers that actually have a bulb that lights up when connected to the battery. a good way to test if th estabilizer is working is to connect and disconnect. when you disconnect, if the light is still on, the stabilizer is working well. if it simply goes off after a second or two, that's not something you want in your car. do be careful of those fully covered voltage stabilizers as you may never know what's inside. there are some who rip off customers by having Any comments? like abit cut-off halfway leh.. rip off customers by having? Anw, capacitors in this case, act as a filter to filter out AC signals. our alternator outputs in AC current, which is converted into DC by a converter n regulated to ard 14+V. maybe for older cars, this process may not be as efficient.. different capacities of caps filter out different frequencies of these noises.. p.s, i'm not an electrical engineer, so not familiar with the exact details... Link to post Share on other sites More sharing options...
Yc86 Clutched July 2, 2006 Share July 2, 2006 quoted frm webbie: Quote Capacitors are connected in parallel with the power circuits of most electronic devices and larger systems (such as factories) to shunt away and conceal current fluctuations from the primary power source to provide a "clean" power supply for signal or control circuits. Audio equipment, for example, uses several capacitors in this way, to shunt away power line hum before it gets into the signal circuitry. The capacitors act as a local reserve for the DC power source, and bypass AC currents from the power supply. This is especially useful in car audio applications, when a stiffening capacitor compensates "power lag" from the lead-acid car battery. Link to post Share on other sites More sharing options...
Seanboi 1st Gear July 14, 2006 Share July 14, 2006 Quote Let me share my sequence. Pivot installed. Used for a year. Installed Max Volt. Thought higher cap, better. Gave my pivot to my brother. After around 6 months, Max Volt swelled and smoked. Removed. This morning just installed Pivot again. :) Got it at $80 (without grounding cables). Bro where u got ur VS from? If plus cable hw much ah? Link to post Share on other sites More sharing options...
Dec7f Neutral Newbie July 17, 2006 Share July 17, 2006 (edited) My cooked Max Volt VS..... Now looking around for new vs, pivot or ez-stab or Sun's Hot Inazma?? Btw, where to get tis sun vs, price range? Tis cooked vs does done it's part, could felt auto gear more smooth, air-con more cooler & audio system sounds better Edited July 17, 2006 by Dec7f Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear July 17, 2006 Share July 17, 2006 The casing was cooked til melted??? ↡ Advertisement Link to post Share on other sites More sharing options...
Which airline is the best?
Advice: which web hosting good?
Honda Civic servicing... Which workshop to go?
