Kooler Neutral Newbie April 29, 2006 Share April 29, 2006 I changed my profile 55 tyres to profile 50 tires.I know that speedo readings would not be accurate,BUT would it under or overstate my actual speed or mileage readings?If so by how much is the difference?Say if my speedo shows 100km/hr,wat would be my actual speed? Likewise when my odometer reads 100KM,wat is the actual distance I covered? ↡ Advertisement Link to post Share on other sites More sharing options...
Calfskin Neutral Newbie April 29, 2006 Share April 29, 2006 Hi Kooler. You can find all the answers on this sticky. http://www.mycarforum.com/forum/Aftermarke...ulator_P729080/ Link to post Share on other sites More sharing options...
Octopus 3rd Gear April 30, 2006 Share April 30, 2006 Yes, your actual speed would be higher than your speedometer reading if you change from 55 profile to 50 profile, while maintaining your original rim size and tyre width. Link to post Share on other sites More sharing options...
Simonleng Neutral Newbie April 30, 2006 Share April 30, 2006 isit? my lower the profile.... but when i am 100km/hr my gps state 97 nia... then i put the gps on another car with stock tyre, 100km/hr the gps show 100km/hr Link to post Share on other sites More sharing options...
Fitvip Supersonic April 30, 2006 Share April 30, 2006 I think it is the opposite! Speedometer reading higher than the actual speed! Link to post Share on other sites More sharing options...
Kooler Neutral Newbie April 30, 2006 Author Share April 30, 2006 Wat abt odometer reading?Would it overstate or understate if lets say my odometer shows 100km travelled wat would be my actual odometer. Link to post Share on other sites More sharing options...
Orablue 1st Gear April 30, 2006 Share April 30, 2006 if ur speedo is correct, then the odo should also be correct. if not correct, then look up the sky and see if there's any UFO near by... then look at the rear view mirror and do a head count... hehe Link to post Share on other sites More sharing options...
Octopus 3rd Gear May 1, 2006 Share May 1, 2006 Oh ya, should be speedometer showing higher than actual.. Link to post Share on other sites More sharing options...
FGY7022 Neutral Newbie May 1, 2006 Share May 1, 2006 did you increase you rim size while you reduce the profile? Link to post Share on other sites More sharing options...
Kooler Neutral Newbie May 1, 2006 Author Share May 1, 2006 nvr change rim size,using 15' correct profile should be 55 but I used profile 50mm on purpose Link to post Share on other sites More sharing options...
FGY7022 Neutral Newbie May 1, 2006 Share May 1, 2006 hmmmm... then like that your overall size of your wheel will become smaller lor... so...if i am not wrong, if your meter shows you traveled 300km, you are actually travelling lesser than that.... is it har?? a bit luan liao.... but i know the distance traveled would be diff lor... Link to post Share on other sites More sharing options...
Easyfil2000 Clutched May 3, 2006 Share May 3, 2006 but its only abit right ↡ Advertisement Link to post Share on other sites More sharing options...
Petlas Or Giti?
Petlas Or Giti?
Is this tyre good? Made in SG!! Giti tyres!
