Dennisk Clutched April 14, 2006 Share April 14, 2006 i was caught in flood....CAI suck in water....engine stalled....i tired to push start a few times...but didn't managed to start...now my car is being towed to workshop...can anyone advise me what will the damage on my car be and also what should i do.... ↡ Advertisement Link to post Share on other sites More sharing options...
Wyv9 Neutral Newbie April 14, 2006 Share April 14, 2006 Er... ur combustion chamber fill with water liao. Pretty big time repair. Overhaul required. This is the problem with CAI. Take it easy. Link to post Share on other sites More sharing options...
Dennisk Clutched April 14, 2006 Author Share April 14, 2006 how much will it cost? overhaul ? Link to post Share on other sites More sharing options...
Cool_jazz Neutral Newbie April 14, 2006 Share April 14, 2006 (edited) Sorry to say this... but I think you are looking at quite a major job if your CAI really took in water. It could be that your car stalled because the exhaust was below the water level.... I believe that might be less of a worry. CAI is to take in air into the combustion chamber. Along the way, it will pass by the MAF (air flow sensor). So you could be looking at MAF replacement, engine overhaul.... look on the bright side... maybe its time to change cams or do a port and polish at the same time. Edited April 14, 2006 by Cool_jazz Link to post Share on other sites More sharing options...
Spade Neutral Newbie April 14, 2006 Share April 14, 2006 (edited) gotta open up and flush out the engine... everything should be okay unless something is bent out of place, then you really need to change parts of the engine - thus overhaul (at least 2k) depending on your warranty covered. flush out engine is labour time... shouldn't be that expensive. I too have installed a CAI, the thing is my CAI is a very large diameter and water doesn't tend to climb up it. it is 5 inches wide with holes in it... Edited April 14, 2006 by Spade Link to post Share on other sites More sharing options...
Beachboys Clutched April 14, 2006 Share April 14, 2006 IMHO, its not worth to do CAI in Singapore, considering the gains vs the risk~ Link to post Share on other sites More sharing options...
King 1st Gear April 14, 2006 Share April 14, 2006 what car r u driving?if u dun mind me asking Link to post Share on other sites More sharing options...
Dennisk Clutched April 14, 2006 Author Share April 14, 2006 me driving a 323.... Link to post Share on other sites More sharing options...
Dennisk Clutched April 14, 2006 Author Share April 14, 2006 i did open up my air filter box to see... there is really water inside... my air filter is also wet...does overhaul include changing of cams and port & polish? Link to post Share on other sites More sharing options...
Dennisk Clutched April 14, 2006 Author Share April 14, 2006 my car is not under any warranty...hopefully it will be less than 2k... Link to post Share on other sites More sharing options...
Wolverine Neutral Newbie April 14, 2006 Share April 14, 2006 jialat liao ....sure a killer...your wallet will have to go thru an overhaul after the engine... better go jb and buy a NEW engine.... Lup a 2.5L ! Link to post Share on other sites More sharing options...
Petrewon Neutral Newbie April 14, 2006 Share April 14, 2006 "If water get thru and go into the combustion chamber.. the engine will cease to function.. When that happen... NEVER NEVER try to start your engine... Get a tow struck to tow to the nearest dry place or workshop... Drain out all the engine oil, remove the spark plugs and use spanner at the pulley to crank and you will see the water "shooting out" from the spark plug hole... Wait till the water is drain out... then put back engine oil and spark plugs... then ok liao. Your engine is saved and $$ also saved." Advice from a lao jiao in my forum... Link to post Share on other sites More sharing options...
Dennisk Clutched April 14, 2006 Author Share April 14, 2006 but i already tried to start... Link to post Share on other sites More sharing options...
Dennisk Clutched April 14, 2006 Author Share April 14, 2006 i can do cam change right? change to better cam or same one as stock? Link to post Share on other sites More sharing options...
Petrewon Neutral Newbie April 14, 2006 Share April 14, 2006 Since u oredi crank.....guess need a major overhaul. Wait for the workshop to access the damage first, before making any decision. Link to post Share on other sites More sharing options...
Knighthunter 4th Gear April 14, 2006 Share April 14, 2006 Hopefully you piston rods are not bend. Should be carefull with CAI setup, do not allow 100% suction to inlet air tube. Proposely make it leak to prevent from sucking water when you inlet pipe is submerged in water. Another thing is use big pipe for CAI inlet pipe. Link to post Share on other sites More sharing options...
Dennisk Clutched April 14, 2006 Author Share April 14, 2006 i did try to crank but it only sounded a click sound...didn't have the normal cranking sound...so is it consider cranked? i suppose have to wait for the workshop to access...was thinking maybe if overhaul then do somethings to my engine......anyone can advise? Link to post Share on other sites More sharing options...
Cool_jazz Neutral Newbie April 14, 2006 Share April 14, 2006 i did open up my air filter box to see... there is really water inside... my air filter is also wet...does overhaul include changing of cams and port & polish? Overhaul does not include change of cams, port & polish. But they will need to drain out your engine oil, strip down your engine to ensure that all water/flood sediments are removed. Since they are doing that... may as well change to fast road cams and do port and polish. ↡ Advertisement Link to post Share on other sites More sharing options...
MyResponder app to call SCDF
Help with STA report remarks
