Owen_fan 2nd Gear March 29, 2006 Share March 29, 2006 As above, where can I get it repair? ↡ Advertisement Link to post Share on other sites More sharing options...
Stress Neutral Newbie March 29, 2006 Share March 29, 2006 What happened? Cigarette lighter seldom spoil. Most likely it is the fuse that has blown off. Just go to any car workshop and they can replace the fuse for u. If DIY, check your car manual on the fuse voltage and then go to DIY shop to buy the fuse and replace it. Link to post Share on other sites More sharing options...
Owen_fan 2nd Gear March 29, 2006 Author Share March 29, 2006 This morning using car vaccum to clean my ride & wanted to pull out the connection from the cigarette lighter socket but it can't so I applied more force to pull it out & in the end the socket came off (but the wire still stay in connection). Try to push the socket back to the orginal poistion, but now can't use it as when I tried to plug the vaccum back to it, it stuck & need to force it out & the socket came off again. Link to post Share on other sites More sharing options...
Mavvy Clutched March 29, 2006 Share March 29, 2006 i dunno where to repair..hahaha.. but you can buy a splitter next time... and leave it there.. so you risk spoiling your splitter rather than actual cig lighter socket... Link to post Share on other sites More sharing options...
Stress Neutral Newbie March 29, 2006 Share March 29, 2006 Most car repair shop will be able to help you. Small matter Link to post Share on other sites More sharing options...
Mivec9 1st Gear March 29, 2006 Share March 29, 2006 confirm fuse blown.... Link to post Share on other sites More sharing options...
Hungryforcar 1st Gear April 7, 2006 Share April 7, 2006 As above, where can I get it repair? Hey, i diy repair. i bought the socket at the autobac, then connect back to the wire and it works. Do take note on the panel hole size for the socket. ↡ Advertisement Link to post Share on other sites More sharing options...
Car repair and maintenance
Where you cut your hair?
NBA - Where Amazing Happens
Used Mercedes buyer spends $40,000 on repairs
Grinding racket
Grinding racket
