Fabiaman 1st Gear April 23, 2002 Share April 23, 2002 Hi all who are keen to know which tyre shop in JB did myself and NILKZ went to which we feel deserves to get a recommendation here. The srevice was pretty good and they guys there aint too pushy. Nilkz's field report can be found here : http://www.mycarforum.com/forum/gforum.cgi?post=12286 Honestly, we are unaware of other tyre shop services but I think both of us are so happy with it, we will almost certainly return to that place the next time we get there for rotation or alignment. The shop's name is PUSAT SERVIS & TAYAR SENTOSA. I have attached the map here. The location of that shop is the block shaded RED and the route to there from THE STORE in SENTOSA is the red lines. The map is presuming you know the way to The Store in Sentosa. Basically, go straight in on the big main road opoosite direction to THE STORE. You will drive past a long stretch of shop houses. You will reach the end of the road which only allows you to turn left. At there, do a left turn and within the next 200m, do a right at the end of the stretch. This right is unmistakable as the slope is quite steep down when you do the right turn. After turning right, go straight and make a right turn again at the main junction. This main junction is a T junction to go either left or right. Turn right and immediately at the first available U-turn, make a U turn and immediately keep left and turn left at the first lane in. There, you will see a BIG BIG sign that says Ah Kun Fishball. A lot of Singaporeans think that place serves good"sai tor" fish fishballs... but I disagree. Anyway, turn into the small lane beside Ah Kun Fishball and drive past Ah Kun. You will see a BIG BIG Bridgestone sign at the end of the small lan. That is the shop we are refering to. If you are lost trying to reach there, just look for The Store in Sentosa and follow the instructions I have given here, you shld get there very easily. Hope this helps. untitled2.bmp ↡ Advertisement Link to post Share on other sites More sharing options...
Guyver 1st Gear April 23, 2002 Share April 23, 2002 Is it one of those shop opposite sentosa? Btw.. do u think u are able to convert it to jpg file and attached again? Link to post Share on other sites More sharing options...
Mondeo Neutral Newbie April 23, 2002 Share April 23, 2002 Wah, dun understand the map la~, why dun go together one day? Link to post Share on other sites More sharing options...
Fabiaman 1st Gear April 23, 2002 Author Share April 23, 2002 Okay , converted to gif format. To go there, you must be familiar with where The Store is at in Sentosa. Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie April 24, 2002 Share April 24, 2002 It's much deeper than the map shows, almost reaching the bridge to Permas Jaya. After the store it'll be probably another 2km before reaching the left turn. Link to post Share on other sites More sharing options...
Guyver 1st Gear April 24, 2002 Share April 24, 2002 Go to JB... show this map to a local there... and hopefully they give u the right directions..... Link to post Share on other sites More sharing options...
Emkay 1st Gear April 24, 2002 Share April 24, 2002 Hi, to make thing easier, you can drive along the main road (Jalan Tebrau) that from come from Singapore toward sentosa. Intead of turning right into Sentosa, you turn right 2 junction before (i.e. the T-junction just after Plaza Pelangi and name Jalan Serampang) .. drive straight down and you'll pass Leisure mall on your right and at the end of Jalan Serampang you turn left at the T-junction and drive straight u'll see Ah Khoon fish ball on your left. MK Link to post Share on other sites More sharing options...
Newtonapple Neutral Newbie April 24, 2002 Share April 24, 2002 Hi Fabiaman Thanks for sharing the location where one can get the wheels aligned. How much do they charge? But seriously, as long as the vehicle does not hit the kerb, or hit a pothole or when thru some form of accident that may affect the wheel alignment, all one need to do (on a periodic basis - say 20K km or 1 yr ) when you do your tyre rotation, is to have the tyre mechanic (if they have a sideslip machine) to measure the amount of sideslip, so that the tyre mechanic (with a simple tool of a spanner) to adjust the tie-rod bolt to correct the sideslip error. That would do, it also means you save on wheel alignment. All that computerised wheel alignment would go to waste if all your vehicle needs is just a sideslip adjustment, which incidentally applies to most vehicle owners, unless one had a bad experience of hitting a pothole at some speed etc. newtonapple Link to post Share on other sites More sharing options...
Carbine Neutral Newbie April 25, 2002 Share April 25, 2002 Agreed. "If it ain't broke, don't fix it!" Link to post Share on other sites More sharing options...
Georgecheng Neutral Newbie December 15, 2004 Share December 15, 2004 Can I have the address of PUSAT SERVIS & TAYAR SENTOSA(The wheel alighnment shop). Are they doing the 4 wheel alihnment together with the machine or one by one type. Thanks Link to post Share on other sites More sharing options...
Lightzvs Neutral Newbie November 3, 2006 Share November 3, 2006 Anyone had recommendation for JB tyre shop? Is it cheaper? Link to post Share on other sites More sharing options...
Ccssgm 1st Gear November 4, 2006 Share November 4, 2006 If go JB for Tyre......... Go for TOYO tyre Made In Japan............. Link to post Share on other sites More sharing options...
Lorrliew Neutral Newbie November 4, 2006 Share November 4, 2006 How much is the aligment there? Which brand of tyres they carry? Is it cheaper there? Thanks! Link to post Share on other sites More sharing options...
Sfrtuscani Neutral Newbie November 4, 2006 Share November 4, 2006 four wheel computerised alignment is RM$40.....high speed balancing is RM$15/wheel Link to post Share on other sites More sharing options...
Sfrtuscani Neutral Newbie November 4, 2006 Share November 4, 2006 jb wont be cheaper lah..unless u buy m'sia tyres....rims, tyres and electronics buy in s'pore!!!! Link to post Share on other sites More sharing options...
Tannedguy78 Neutral Newbie November 6, 2006 Share November 6, 2006 i did my wheel alignment at RM30 only at Hawk tyres at Extra shopping centre... Link to post Share on other sites More sharing options...
Kk88 Neutral Newbie November 6, 2006 Share November 6, 2006 singapore only $20 mah? why spent our $$ there??? Link to post Share on other sites More sharing options...
Tannedguy78 Neutral Newbie November 6, 2006 Share November 6, 2006 no lar ...where got $20 for wheel alignment in sg? at least $50-60 in sg for all 4 wheels computerised wheel alignment....jb only RM30 ....bro, pls dun bull sxxt down... if have , tell us the shop name then... ↡ Advertisement Link to post Share on other sites More sharing options...
Tyre puncture
Tyre puncture
Any recommended tyre shop
Continental CSC 7.
Continental CSC 7.
Tyre Rotation and balancing
Continental closing Alor Setar plant
