Nutty 4th Gear March 11, 2006 Share March 11, 2006 Anyone using this to dry your car? How good is it? Does it cause scratches? Where to buy? http://www.autoglym.co.uk/htfwb2/index.htm ↡ Advertisement Link to post Share on other sites More sharing options...
Koren Clutched March 11, 2006 Share March 11, 2006 wa.. real or one.. one swipe dun even leave a single droplet.. the car beads reallywell aniwaes.. Link to post Share on other sites More sharing options...
Nutty 4th Gear March 11, 2006 Author Share March 11, 2006 You dun think that's possible? Link to post Share on other sites More sharing options...
Koren Clutched March 11, 2006 Share March 11, 2006 unless your car is really evenly waxed.. works like a wiper blade.. most of the time it wun remove all the water when the windscreen is dirty.. Link to post Share on other sites More sharing options...
Evan015 Neutral Newbie March 11, 2006 Share March 11, 2006 any idea where to get it? thinking of getting it too.. but din see it ard.. ard how much does it cost? Link to post Share on other sites More sharing options...
Umgaia Neutral Newbie March 11, 2006 Share March 11, 2006 saw it at Giant @ Sembawang Shopping Ctr... Very expensive, in my opinion... around $30 Link to post Share on other sites More sharing options...
Ivan96935sg Neutral Newbie March 11, 2006 Share March 11, 2006 It's overprice....$25+ when I sae at Home-Fix DIY Store. Link to post Share on other sites More sharing options...
Cheeze Neutral Newbie March 11, 2006 Share March 11, 2006 i remember reading that you have to becareful when using such blades as any sand on the surface may cause you to scratch the car when you swipe the water away Link to post Share on other sites More sharing options...
Silver_blade Turbocharged March 11, 2006 Share March 11, 2006 It's quite effective but ex. My mum is using one. Link to post Share on other sites More sharing options...
Garlic 1st Gear March 11, 2006 Share March 11, 2006 Seen cheaper ones made by Mr Clean and AntoHub, price wise its $10+. Link to post Share on other sites More sharing options...
Kaiserdome 1st Gear March 11, 2006 Share March 11, 2006 Pretty risky blades Link to post Share on other sites More sharing options...
Silver_blade Turbocharged March 13, 2006 Share March 13, 2006 Why leh? Link to post Share on other sites More sharing options...
Ah_bon Neutral Newbie March 13, 2006 Share March 13, 2006 You must make sure your car paint surface is clean. if there's still any dirt... the blade might swipe the dirt across the paint work ... paint scratched! but if your car is clean, then it'll sure make the drying job very fast Link to post Share on other sites More sharing options...
L9turbo Neutral Newbie March 13, 2006 Share March 13, 2006 The blade does not look like its touching the car body. Link to post Share on other sites More sharing options...
Silver_blade Turbocharged March 13, 2006 Share March 13, 2006 Yah lah...as long as the car is cleaned...it should be a problem. Anyway, that is what you are supposed to use it for...after your car wash. Link to post Share on other sites More sharing options...
Lwteyu Neutral Newbie March 13, 2006 Share March 13, 2006 Saw something very similar in Carrefour at Suntec, But skeptical to used it. 1) might cause scratch if surface isn't ""Clean"" 2) Cars are not really that flat everywhere, more useful for bonnet and car top? Anyway car body not as hard as the glass and got paint somemore. Don't want end up with a lot of swirls. Link to post Share on other sites More sharing options...
Silver_blade Turbocharged March 13, 2006 Share March 13, 2006 I don't know about other brand. But the autoglym has soft flexible blade...that can bend a little. You can use it on various part of the cars....but it's important to wipe the blade after every few go...to remove the water and dirt (if any). Link to post Share on other sites More sharing options...
Lwteyu Neutral Newbie March 13, 2006 Share March 13, 2006 I don't know how "soft" is good. I have a feel of the one that is sold at Carrefour and in my own opinion still not "soft" enough to made me feel safe. Maybe autoglym one better? who knows ↡ Advertisement Link to post Share on other sites More sharing options...
The Big Read: Understanding why millennials and Gen Zers feel the way they do about work
Wiper Blade Refills
Wiper Blade Refills
Nothing Phone, Nothing but it's New to Me
