Can mixed shell helix ultra and mobil 1??
Galantspeedz
both are fully synthetic oil. but shell helix is 5w-40 and mobil is 5w-30.
using shell now and haf about 1/3 bottle left. wants to change to mobil 1.
can mixed both oils together?
thanks
Fyi.... I've been mixing quite a fair bit.... [laugh]
Mixed 2 quarts AMSOIL 10W-40 with Mobil 1 0W-40..... no problems...
Mixed 2 quarts of Mobil 1 0W-40 with Mobil 1 15W-50 also no problem.....
All because I had left over. Now I've just bought cxxxxxe and have left over M1 15W-50.... might mix again. [:p] But maybe not as I intend to do shorter OCI for cxxxxxe. M1 seems too good/expensive to use for short OCI. Most likely will buy more to make up a complete fill.
30 weight is too thin for me... thanks for the feedback. But should you see at least 40 weighted Mobil 1 and going cheap, let me know hor.... [;)]
can mix la..
i intend to mix this for my next servicing [sly]
200ml Mobil Delvac 15w40
1600ml M1 10w30
1000ml RP 5w20
[laugh][laugh]
dunno any chemical conflict or not [sweatdrop]
Edited by Cyberet
I cannot use too thin oil as I like to wack my ride. [laugh] Higher temps are experienced and my oil is usually badly sheared & comes out like water during my 10K oil changes. If using thin oil to start with... if it breaks down further, my engine might not get sufficient protection till the next OCI. [sweatdrop]
Also, thicker oils give quieter running engine at the expense of FC... but I can live with that. [:p]
ang mo rojak [laugh]
aiya got left over mah, so mix all in la [laugh]
thick ah.. thick and slimy and gooy
thin is.. thin, water, and slippery [laugh]
galant can use 30wt i think [;)]
Edited by Cyberet
u running turbo charged car, of course la [laugh]
NA seldom gets so hot unless u track
normal driving takes about 20mins for the oil to reach operating temperture
Edited by Cyberet
sounds like something u produce if u do to often and if u do it once awhile [laugh]
so means, thinner oil will be abit better FC but noisy engine? i dun really wack my ride so i think its alrite. moreover i always change at abt 7k instead of 10k [laugh]
so galant 5w-30 no problem hor?
20 mins for oil to reach operating temp? Wah... so long ah....
It takes about 3 mins of slow/easy driving (about 5km at below 2k rpm) for my oil temp to reach about 80 and about 5 min (~ 10km) to reach 90 deg. If wack from cold start (which is not advisable), then I think it'll be much , much faster. [rolleyes]
