Spade Neutral Newbie January 27, 2006 Share January 27, 2006 Test the speakers, wires, and polarity all in one step! If you are wiring a car stereo or home stereo and have the wires plugged into the speakers but at the other end do not know which wires go to which port? Rather than trace each wire seperately, grab a 9volt battery, hold one wire on a terminal, tap the other wire on the other terminal, and it will make the speaker pop. Now know which speaker is connected to that wire. Also, if wired correctly +/- the cone will pop OUT; if it sucks in, you have the polarity backwards. Too steps solved in one. You want all of the speakers to pop out with the +/-. This will make your stereo, home or car sound much fuller. If it sounds hollow or lacking bass, you may have just one speaker wired backwards. Eric B, certified car audio installer 9 years in biz ↡ Advertisement Link to post Share on other sites More sharing options...
Headshok 1st Gear January 27, 2006 Share January 27, 2006 for usin the battery to test, one draw back is that if not careful, u might activate the airbag.. this happened b4.. heheheh.. (for those who not sure which cable is wat. ).. Link to post Share on other sites More sharing options...
K2000 Neutral Newbie January 28, 2006 Share January 28, 2006 Test the speakers, wires, and polarity all in one step! If you are wiring a car stereo or home stereo and have the wires plugged into the speakers but at the other end do not know which wires go to which port? Rather than trace each wire seperately, grab a 9volt battery, hold one wire on a terminal, tap the other wire on the other terminal, and it will make the speaker pop. Now know which speaker is connected to that wire. Also, if wired correctly +/- the cone will pop OUT; if it sucks in, you have the polarity backwards. Too steps solved in one. You want all of the speakers to pop out with the +/-. This will make your stereo, home or car sound much fuller. If it sounds hollow or lacking bass, you may have just one speaker wired backwards. Eric B, certified car audio installer 9 years in biz If i not wrong, these article is from DLS speaker install manual, seems so familiar ↡ Advertisement Link to post Share on other sites More sharing options...
Kia Cerato speakers spoilt. Advise pls
Speaker Tan Chuan-Jin, MP Cheng Li Hui resign
First Testing
First Testing
Is a subwoofer necessary?
Hello, you must be notified
2019/2020 MCF Revamp - Feedback/Errors
