Orixy 2nd Gear January 20, 2006 Author Share January 20, 2006 "I thot I saw a discussion in another thread that higher temp gives better FC. Hmm... Well, it that theory is true, then a higher bar cap will improve FC as the cap will hold the pressure of boiling from 0.9bar to 1.3bar before releasing. Right?" >> But your theory should be reversed cos the higher 1.3bar cap will help the engine decrease its temp instead of increasing. Hmm... ↡ Advertisement Link to post Share on other sites More sharing options...
Orixy 2nd Gear January 20, 2006 Author Share January 20, 2006 Guys, this morning I have fitted the 1.3bar rad cap. All other stuff intact, only rad cap changed. It should be my placebo effect cos I did feel that engine is more torquey and responsive instantly. Earlier on my way home after work, I also felt that engine is more responsive. I know a change to higher bar rad cap won't give much noticeable performance gains, but what the heck, the cap cost $30 and I do feel better with it. Hee... Will monitor FC see how... 1 Link to post Share on other sites More sharing options...
Randall Neutral Newbie January 21, 2006 Share January 21, 2006 Hi bro....radiator cap main purpose is to release steam at designed temp so u can see that ur engine is over temp....i also brings higher boiling pt with higher bar...always stick will the original rating,.,...changing radiator cap doesnt impprove FC or power.... Link to post Share on other sites More sharing options...
richard_crl032 6th Gear February 15, 2020 Share February 15, 2020 Hi, Old thread but this may help bro venturing here like it helped me: http://www.tuneruniversity.com/blog/2011/06/beating-the-heat-advantage-of-a-high-pressure-radiator-cap/ Cheers. Richard ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Radiator Cap
Radiator Cap
HSA recalls 3 brands of high blood pressure drugs
Tyres pressure for 225/45/R17
Low sex drive be careful, expert warning : Double the risk of death
What's So Special About These Cars
WSQ specialist diploma/cert useful?
Radiator slight crack
