Ravrex Neutral Newbie January 17, 2006 Share January 17, 2006 Have you guys encountered low rpm idling thus causing unnecessary vibrations to ur car? If so what are the causes and remedies ah? ↡ Advertisement Link to post Share on other sites More sharing options...
Trex101 3rd Gear January 17, 2006 Share January 17, 2006 I think high chances its your throttle body, clean it and you will solve your rpm problem. Link to post Share on other sites More sharing options...
Apollo 1st Gear January 17, 2006 Share January 17, 2006 throttle - sensor - negative boost fr engine oil Link to post Share on other sites More sharing options...
Nhrisuzu 1st Gear January 17, 2006 Share January 17, 2006 how low is low?? for me, manual around 750rpm mark.. sometimes just turn the knob near the ignition there for the rpm thing can work.. Link to post Share on other sites More sharing options...
Trex101 3rd Gear January 17, 2006 Share January 17, 2006 Mine can go down to 400rpm too but i don't bother to clean the TB cos no vibration felt. Link to post Share on other sites More sharing options...
Nhrisuzu 1st Gear January 17, 2006 Share January 17, 2006 400rpm?!?!?! , no vibrations?? Link to post Share on other sites More sharing options...
Trex101 3rd Gear January 17, 2006 Share January 17, 2006 My TB get dirty very quickly because i'm using diy foam(oiled) filter. Yah if i clean my TB, it went up again to around 800rpm but i still like 400rpm, so quiet feel like car didn't start like that. Link to post Share on other sites More sharing options...
Dwoon 1st Gear January 17, 2006 Share January 17, 2006 ya....and also save petrol right.... Link to post Share on other sites More sharing options...
Ravrex Neutral Newbie January 18, 2006 Author Share January 18, 2006 I think high chances its your throttle body, clean it and you will solve your rpm problem. Yah thats what i thought also. My idling is about 650rpm to as low as 550rpm..cannot stand the vibrations man!! So going to try clean out my throttle body tmr and hopefully that works! Link to post Share on other sites More sharing options...
BlueSi Neutral Newbie January 20, 2006 Share January 20, 2006 You need to check all your vacuum lines and make sure there isn't a leak somewhere. If you are using an after mkt fuel pressure regulator (FPR) check to see if the adjusting knob came loose and check your fuel pressure while the car is at idle with the vacuum line to your intake manifold pinched. Those are some things that can cause irregular idles. Link to post Share on other sites More sharing options...
Cordia_gsr Neutral Newbie January 20, 2006 Share January 20, 2006 Have you guys encountered low rpm idling thus causing unnecessary vibrations to ur car? If so what are the causes and remedies ah? What kind of car are you driving? Carburator and injection engines have different ways of remedies too. Link to post Share on other sites More sharing options...
Ravrex Neutral Newbie January 21, 2006 Author Share January 21, 2006 Am driving a rav4 but i think its a common problem amongst my ride from what i heard. Just cleaned out the TB and the ECU is still adjusting to it. Was also told that vibrations could be cause by the engine mounting over time. Think thats another point to take note. Link to post Share on other sites More sharing options...
Pisces69 6th Gear January 25, 2006 Share January 25, 2006 My TB get dirty very quickly because i'm using diy foam(oiled) filter. Yah if i clean my TB, it went up again to around 800rpm but i still like 400rpm, so quiet feel like car didn't start like that. ================================ Too low idle puts alot of strain on the engine as it's not made to idle so low. The owners manual gives u what is recommended for your engine type. Try to get as close to it as possible. If u get vibrations, adjust it up or down a little to solve it but not too much. Remember adjustments sud b done with all accessories off & engine warm. If your mounts r still new, sud have little vibs, but does not mean it's OK. The mounts r absorbing all the vibs. Puts unnecessary stress on them. FC during idle is very small. Won't make much diff to your wallet. ↡ Advertisement Link to post Share on other sites More sharing options...
No Idling for cars
No Idling for cars
Intermittent erratic idling and hesitant acceleration
Engine revving up and down
My Airwave when idling vibrate violently
Subaru R2 Aircon idling is not cold, when cruising is cold
Unstable idling and stalling issues
Avante vibration during idling
Lancer EX 1.5 Idling rpm. Whats yours?
