Orixy 2nd Gear December 29, 2005 Share December 29, 2005 Just a quick question here: I'm currently using 195/50/R15 tyres. How can I know if I can use 205/50/R15? Which measurement of my rims should I look out for to know? Many thanks! ↡ Advertisement Link to post Share on other sites More sharing options...
Toalson 1st Gear December 29, 2005 Share December 29, 2005 The rims size 6.5 or 7. But this also depend on tyre model. Some model can for such size can still use 6.5 but some uses 7 min. Btw for this size might need to check if it will brush the wheel well when turning. Tis got to do with rim offset. Tis size also quite rare if not mistaken. Link to post Share on other sites More sharing options...
Genie47 1st Gear December 29, 2005 Share December 29, 2005 The problem with tires is the availability of the series. For example, someone needed 185/55-15 for his Aveo because he valued comfort but liked the idea of bigger rims. Very few tire brands/models have 185/55-15 compared to the abundance of 185/60-14 and 195/50-15. Then the other thing is that the tires fit onto the rim has to have the same rolling diameter as the stock or previous so as not to screw around with the speedo reading. Might even make the engine work harder just to turn those wheels. Link to post Share on other sites More sharing options...
Orixy 2nd Gear December 29, 2005 Author Share December 29, 2005 Thanks for quick reply! My rims are 15 x 6.5 and offset is 40. Link to post Share on other sites More sharing options...
Orixy 2nd Gear December 29, 2005 Author Share December 29, 2005 Thanx bro for your advice! Link to post Share on other sites More sharing options...
Toalson 1st Gear December 29, 2005 Share December 29, 2005 No lah, I happened to be surfing ard Now check the tyre n see if they have info on size of rim it can fit. Normally its stated in their specs, however if dont have u might need to go physically to the shop n try. Most shops can tell if can fit rim and if any problem with tyre hitting the rest ofthe car when turning. Btw wat model of tyre u'll be getting? Link to post Share on other sites More sharing options...
Ncss Clutched December 29, 2005 Share December 29, 2005 Just a quick question here: I'm currently using 195/50/R15 tyres. How can I know if I can use 205/50/R15? Which measurement of my rims should I look out for to know? Many thanks! Why you want change 205/50/15 since your rim is same?? 195/50/15 tire is cheaper mah... also won't reduce your power. why waste the money? Link to post Share on other sites More sharing options...
Tyreboy Neutral Newbie December 29, 2005 Share December 29, 2005 it can fits your rim...downside is FC will be a bit higher but the good thing is you have more grip on the road whether dry or wet...cornering good. Link to post Share on other sites More sharing options...
Robertoon Neutral Newbie December 29, 2005 Share December 29, 2005 Just a quick question here: I'm currently using 195/50/R15 tyres. How can I know if I can use 205/50/R15? Which measurement of my rims should I look out for to know? Many thanks! guess changing to 205/50R15 means you want more grip. Try hankook Rs2.... Link to post Share on other sites More sharing options...
Ncss Clutched December 29, 2005 Share December 29, 2005 Only small increase 195 to 205 can feel different in grip meh... . Must know what car he drives, some car don't suit 205... will increase noise & reduce power. I am opposite, I spec down my tire, change 235 down to 225 , save cost & increase power... Link to post Share on other sites More sharing options...
Tyreboy Neutral Newbie December 29, 2005 Share December 29, 2005 yes there is a difference, if you look closely at the 2 tyres...you spec down because 235 is simply too big...too low profile....look very beautiful...but run like kanasia...waste more fuel and more money...wise decision for you to go 225...if can go down to 215 la Link to post Share on other sites More sharing options...
Orixy 2nd Gear December 30, 2005 Author Share December 30, 2005 Now check the tyre n see if they have info on size of rim it can fit. Normally its stated in their specs, however if dont have u might need to go physically to the shop n try. Most shops can tell if can fit rim and if any problem with tyre hitting the rest ofthe car when turning. Btw wat model of tyre u'll be getting? Thanks! After hearing some of the other bro's advises, I think will keep to 195 as opposed increasing to 205. Thinking of getting the Hankook R-S2 for my next set of rubbers. Link to post Share on other sites More sharing options...
Orixy 2nd Gear December 30, 2005 Author Share December 30, 2005 Thanx for advice! Will stick to 195 then... Link to post Share on other sites More sharing options...
Orixy 2nd Gear December 30, 2005 Author Share December 30, 2005 Bro, any idea the Hankook R-S2 costs how much for 195/50/R15? and where to get them at good price? ↡ Advertisement Link to post Share on other sites More sharing options...
Does rims change shape/warp over time?
Replacing a 2yrs old tyre?
Shipping USA Rims
Shipping USA Rims
Singapore Brand Rims VS China Brand Rims
Someone's rims and tyres stolen at KSL carpark
