Difference between Mivec, Vtec, VVTi and VVL
Babymushroom
Hi, Seems like no one answer ur qn properly.
I'll try to explain a bit..
MIVEC, if u read sunday times, they did give u the full name of MIVEC, I cannot remem everything, but it's just a fanciful name lah to a similar concept.
Impt is getting the concept correct, then heck care all the fanciful names.
Anyway...MIVEC, VVTi and VTEC is variable valve timing (VVT) which means the timing of the valve intake and output(exhaust) is electronically altered to give better performance of the cylinder...get it?
VVL is variable valve lift...lift means the depth{paradoxically} of the valve opening, ie more air in/out of the cylinder. more air in means more power (if done right..something like turbo/supercharged engines)
So far most cars now have VVT...including honda, mitsubishi, nissan, toyota...just diff names...usu the VVT kicks in at a certain RPM eg 4000 for the nissan sunny. ie 2 stage
honda steam got i-vtec...3 stage, which means got kick in at 2 diff rpm, dunno wat.
VVL? Got.., Not sure, but mebbe honda stream got, but only for the intake valve.
got VVTL also...more advanced...but perhaps in some higher end cars.
Hope tt helps.
  Quote
Hi, anyone cares to talk more about these 4 differences in LAY MAN TERMS >..
what I know is that for Mivec and Vtec they are using 2 cam profile where at 5500 RPM (can be adjusted) it kicks in and open the 3rd cam to allow more fuel and air to combust ... is that true?
But cannot find anything for VVL leh ...
By the way anyone know which car in singapore using VTEC, Mivec, VVTi and VVL ?
Mitsubishi MIVEC - Variable Lift only
Toyota VVTi - Variable Timing only
Toyota VVTL-i - Variable Time and Lift
Nissan VTC - Variable Timing only
Nissan VVL - Variable Lift only
Honda VTEC - Variable Lift only
Honta iVTEC - Variable Lift and Timing
Heheee ... a bit of insight into iVTEC ... since I drive one [sly]
Honda iVTEC uses:
Variable Lift: 3 stage (Intake only)
1st stage - Economy ... one valve is disabled, thus a swirl in the engine is created like the Surbo. Total 12 valve operation for fuel economy during cruising
1st stage to 2nd stage is at 2200rpm
2nd stage - Normal .. 16V operation where the most torque is
2nd stage to 3rd stage is at 4700rpm
3rd stage - Wild cam ... more power lah
Variable Timing: Unlimited
Variable Intake: 2 stage. When below 4700rpm, the intake uses a longer route. Above 4700rpm, a valve closes and the intake uses a shorter route.
Will find a website that explain in details and post here....
Edited by Andrewkb
Hi Andrew,
Did a test drive on the Stream 2.0 i-Vtec & all I can say it's thumbsup.gifthumbsup.gifthumbsup.gifthumbsup.gifthumbsup.gif consider almost full load sly.giftongue.gif
There were 5 person onthe Stream: me (75kg) + Foo (60+kg) + Ahleong (80+kg) + Ahleong's friend (60+kg) + SE (90+kg) & all I can say is thumbsup.gifthumbsup.gifthumbsup.gifPosted ImagePosted ImagePosted Image when using the Manual Shift, but if using AutoPosted ImagePosted ImagePosted ImagePosted Image & Posted ImagePosted ImagePosted ImagePosted ImagePosted ImagePosted ImagePosted Image
In fact, the car feels more energetic when full load !
Guess it's the Variable Timing that have adjusted based on the load.
If the car has 2 person, the engine feels lethagic [shakehead]
One thing for sure, with full load, the car can still climb up a slope without feeling breathless ! [thumbsup]
Edited by Andrewkb
  Quote
May i know what's the difference between the VVTi and VVTL-i??
