Furrynadz 5th Gear June 3, 2007 Share June 3, 2007 see classifieds i selling ↡ Advertisement Link to post Share on other sites More sharing options...
Maddriver 4th Gear June 3, 2007 Share June 3, 2007 u selling yr Meg's range? Link to post Share on other sites More sharing options...
Furrynadz 5th Gear June 3, 2007 Share June 3, 2007 (edited) see classified lor...too much junk to clear..bit by bit.. set 1... set 2 in storeroom... Edited June 3, 2007 by Furrynadz Link to post Share on other sites More sharing options...
Weszt Neutral Newbie July 10, 2010 Share July 10, 2010 hi, newbie here. can i fit 6" foam pads on a bosch GEX 125-1AE random orbit sander? if not any recommendation? the sanding plate diamter is only 5"? Velcro-type fastening for rapid, convenient sanding sheet changes. any recommended pads for this model? i will buy this gex 125 @ anchorpoint selling for 181sgd. thanks a lot heres the website for this power tool: http://www.bosch-pt.com.sg/papocs-sg/Produ...object_id=14161 Link to post Share on other sites More sharing options...
Terentius Neutral Newbie August 1, 2011 Share August 1, 2011 hi, newbie here. can i fit 6" foam pads on a bosch GEX 125-1AE random orbit sander? if not any recommendation? the sanding plate diamter is only 5"? Velcro-type fastening for rapid, convenient sanding sheet changes. any recommended pads for this model? i will buy this gex 125 @ anchorpoint selling for 181sgd. thanks a lot heres the website for this power tool: http://www.bosch-pt.com.sg/papocs-sg/Produ...object_id=14161 Hi folks Need help on the following on Gex 125 1. Where to get the polish and fisnishing pad for Gex 125 2. How to mount the pad to Gex 125 - understand it is a sander 3. do you buffer off by hand using micro fiber clolth or use Gex 125. pls help... ↡ Advertisement Link to post Share on other sites More sharing options...
Power Tools Brand - Milwaukee versus the rest
Cordless power tool system - which one ?
Bosch automotive parts Stockist
Battery Brand You Use For Your Car?
Vacuum cleaner - Dyson vs Bosch
Bosch's tungsten-coated rotors reduce dust by 90%
Handheld Vaccum Cleaner -Bosch Bbhmove2 / Electrolux Ergorap
Bosch QuietCast Brake Pad
