Nissantoot Neutral Newbie November 2, 2005 Share November 2, 2005 (edited) replace all the engine oil seals for 280 bucks to plug a engine oil leak. cheap or ex? anything else i should take note of or use this opportunity to change? involves taking out gearbox. went to autosavers and they quoted me this. comments? Edited November 2, 2005 by Nissantoot ↡ Advertisement Link to post Share on other sites More sharing options...
Pisces69 6th Gear November 2, 2005 Share November 2, 2005 U have to specify what seals/gaskets u changed? Normally not all will go at the same time. Just change the ones that leak. Link to post Share on other sites More sharing options...
Nissantoot Neutral Newbie November 2, 2005 Author Share November 2, 2005 (edited) rear engine oil seal leaking...so taking opportunity to change all the seals since labour charge is already in. haven change yet. chking out the price.. good price? anything else should change since the gear box is going to be stripped? Edited November 2, 2005 by Nissantoot Link to post Share on other sites More sharing options...
Mivec9 1st Gear November 2, 2005 Share November 2, 2005 r they gaskets?? or the timing belt oil seal...if it's tat shd be quite cheap. Link to post Share on other sites More sharing options...
Yeobh 4th Gear November 2, 2005 Share November 2, 2005 Both front and rear seal much be replaced including the oil pan gasket.Looks easy but it hard work. Link to post Share on other sites More sharing options...
Nissantoot Neutral Newbie November 2, 2005 Author Share November 2, 2005 thanks yeobh...the gear box is going to be stripped...anything i should watch out for in terms of workmanship? Link to post Share on other sites More sharing options...
Yeobh 4th Gear November 3, 2005 Share November 3, 2005 No they are just dropping the gearbox to acess the rear seal.Maybe it is good to check the gearbox clutch bearing and linkage bushing. Link to post Share on other sites More sharing options...
Octopus 3rd Gear November 3, 2005 Share November 3, 2005 replace all the engine oil seals for 280 bucks to plug a engine oil leak. cheap or ex? anything else i should take note of or use this opportunity to change? involves taking out gearbox. went to autosavers and they quoted me this. comments? If the leakage is not excessive, why not wait until you need to change clutch pad, then do the oil seals together? Link to post Share on other sites More sharing options...
Mivec9 1st Gear November 3, 2005 Share November 3, 2005 any idea wat are the items to be changed for clutch package and how much roughly?? Link to post Share on other sites More sharing options...
Octopus 3rd Gear November 3, 2005 Share November 3, 2005 Item wise, I also not so sure .....I hear its between $200 ~ $300 range. Link to post Share on other sites More sharing options...
Pisces69 6th Gear November 3, 2005 Share November 3, 2005 rear engine oil seal leaking...so taking opportunity to change all the seals since labour charge is already in. haven change yet. chking out the price.. good price? anything else should change since the gear box is going to be stripped? ============================ I can't advise u if the price is ok as I;ve never changed these seals b4. Why don't u just get 2 more quotes from different WS to compare. Try to use WS that your frens have used b4 & recommend. Otherwise if it's badly done, God bless you. Link to post Share on other sites More sharing options...
Nissantoot Neutral Newbie November 4, 2005 Author Share November 4, 2005 auto car...no clutch... ↡ Advertisement Link to post Share on other sites More sharing options...
Replacing fuel filter
Replace washing machine door seal/gasket
Replace spark plugs
Replace spark plugs
How to find equivalent offset to replace stock wheel?
NS Square to replace The Float @ Marina Bay
