Armored_Saint Neutral Newbie January 24, 2003 Share January 24, 2003 (edited) Folks, My rear tyre started hissing today and I discovered the valve stem is leaking...if you push it to one side... The valve itself is replaceable without having to change the entire tyre, am I right? Never encountered this before! Edited January 24, 2003 by Armored_saint ↡ Advertisement Link to post Share on other sites More sharing options...
Sky8807 1st Gear January 24, 2003 Share January 24, 2003 The valve stem must be leaking, cost is only a few cents. The worst case is the whole rubber piece need replacement and not that expensive also, a few dollars only. Use the metal type, it is more rigid and lasting. Link to post Share on other sites More sharing options...
Armored_Saint Neutral Newbie January 24, 2003 Author Share January 24, 2003 Sky, thanks for the confirmation...will get it done first thing tomorrow morning...know if there are any Tyre/Battery shops at the auto section near Tampines Safra? You know, that spare tyre now used as a replacement doesn't look that bad at all! Raw and aggressive! Link to post Share on other sites More sharing options...
Sky8807 1st Gear January 24, 2003 Share January 24, 2003 Any tyre shop can fix the problem, suggest you do wheel balancing b4 installing back on the car. Sorri, don't have any shop near there to recommend. Do keep you speed lower than 105km when you are on spare tyre to be on the safe side. Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie January 24, 2003 Share January 24, 2003 "any Tyre/Battery shops at the auto section near Tampines Safra?" Hi! there, Armored_Saint, There's a Shell petrol kiosk opposite Blk 139 Tampines Ave.2/Holy Trinity Church. As Sky8807 mentioned, alloy valves last longer, but abit more expensive. Note: When alloy valves leak, it won't be a slow leak like the cheaper rubber valves, as it's secured to the wheel with a nut unlike the expansion of the cheap ones, so the tyre will be flat before you reach an air pump. Rgds Paul Yong Link to post Share on other sites More sharing options...
Armored_Saint Neutral Newbie January 24, 2003 Author Share January 24, 2003 Thanks, Paul! Shell ProServ does dabble with tyre valves too? If they do, I'd pop in at one closer to my home. Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie January 24, 2003 Share January 24, 2003 "Shell ProServ does dabble with tyre valves too?" Hi! there, Armored_Saint, I used to stay in Tampines, so I've used that particular Shell Station which has a tyre shop with competitive priced tyres. I'm not sure about the rest of the Shell stations. Rgds Paul Yong ↡ Advertisement Link to post Share on other sites More sharing options...
Portable Tyre Pump
Portable Tyre Pump
Tyre puncture
Tyre puncture
Continental CSC 7.
Continental CSC 7.
