Genie47 1st Gear October 25, 2005 Share October 25, 2005 See the links: http://www.raktron.com/misc/mt.htm http://forums.evolutionm.net/showthread.php?t=117418 You will reduce wheel hop and provide better launch if you like to track the car often. ↡ Advertisement Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear October 25, 2005 Share October 25, 2005 yup it does. I've got aftermarket solid rubber mounts but the effect is the same. One thing though, it makes the car shake/vibrate more, so if you don't like that, don't do it. Link to post Share on other sites More sharing options...
Zrun Neutral Newbie October 31, 2005 Share October 31, 2005 I bought inserts type. It is removeable if you are tired of the vibration. Also you cannot sell the car in future if it is vibrating like that. http://matrix.newobject.org/tech/esinstall/ Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear October 31, 2005 Share October 31, 2005 hmmz... interesting about the insert type. thats new to me. I wonder.... I'm using the Nismo mounts instead of the standard nissan ones. How come you can't sell the car??? because of legalities or less people that will buy it? Link to post Share on other sites More sharing options...
Zrun Neutral Newbie October 31, 2005 Share October 31, 2005 Less people will buy it and the glue method is not reversible, that's why I spent about $20 USD to buy these inserts. Car with stiff mounts will give false impression that the car is idling very rough, and will probably hurt resale value. Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear October 31, 2005 Share October 31, 2005 Thanks for clearing that up... like i said interesting Okies a few more ques. Are these inserts universal or vehicle specific? How easy is installation as changind mounts is easy and can even be DIY provided you have wrenches, axel stands and a trolley jack. Any links?? Link to post Share on other sites More sharing options...
Zrun Neutral Newbie October 31, 2005 Share October 31, 2005 (edited) It is made by Energy Suspension, a company that specializes in suspension bushings. http://www.energysuspension.com/ I am almost 100% sure it is vehicle specific, because the shape are different with each engine mounts. The installation link I provided above was made by me, on my car. Installation is easy on my car's model. No guarantee on other cars. Edited October 31, 2005 by Zrun Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear October 31, 2005 Share October 31, 2005 (edited) thanks for that hyperlinked your install process here>> http://matrix.newobject.org/tech/esinstall/ Edit: Okies i see the mount. yup, process is very similar to changing the mounts, and i now know how the inserts look like too Edited October 31, 2005 by Elfenstar ↡ Advertisement Link to post Share on other sites More sharing options...
SCHNELL Engine Oil 5W40
P2096 Check engine light
DIY engine oil change
