HELP - Oil Leaks!!!
Nissantoot
went to my workshop yesterday to do some stuff and he detected 2 different kind of leaks under the car 1) Engine oil - there was this little bit of engine oil hanging at the undercarriage and 2) Power steering fluid - there was this piece of cover at the undercarriage that was a little oily, obviously smudged with oil.
Driving a 1.5 sunny about 5 yrs, 90k milage. He told me that the engine oil leak is due to some worn out O ring or something like that. He advised no concern as it's pretty normal for old cars and no need to change.
For the power steering fluid leak, he's doing a follow up on that during next servicing to see how much fluid dropped in the reservoir. but he suspects it's due to the power steering pump. he advised getting a refurbished pump if there really is a need to change.
any advise?
engine oilleak dut to worn gasket...normal
as for power steering.....get them to tighten first.....if not, then change it...but monitor it fm time to timewink.gif
is it easy to replace that engine oil gasket? how to find out if it's the engine oil gasket that is causing the problem? complex task?
Quite an easy task....just changing the gasket
Edited by RadX
It is a simple process, but not worth doing it yourself. Did mine sometime ago for about S$20. However, you need a torque wrench to do it that cost S$200.
shine a bright torch into the engine bay and see the seal arnd the enging...look for oil stains and stuff....and if there are, then possibly a gasket leak
The problem will go away if you can get hold of a can of oil seal treatment.
The chemical is desinged to impregnates old worn oil seals and thereby increase the volume of of the seal.
any advise?
Me driving a COE car, and I also noticed that one of the piping for the power steering is wet, minor leakage (won't drip to the floor kind). So far power steering fluid level had been maintaining so I didn't do anything to it.smile.gif
Interesting.....I'd probably need one of that for my old car.nod.gif How to use it? Is it similiar to those STP stop leak?
thanks!
is that for the worn out gasket (engine oil leak) or for the power steering fluid? the workshop guy told me that the power steering fluid leak is due to the pump and not the seal. not an expert in this but i assume leak due to pump is different from seal.
same also...but I din go scrutinise my piping. saw a metal casing under the undercarriage wet with the power steering oil. doesn't leak to the floor kind and the fluid level has not been decreasing, so i din do anything to it yet. but the feeling is still not shiok to know that the car is leaking. trying to find out what i can do to stop it.
Assuming you have open the engine compartment and know where is the engine block. There are 2 places where oil can be, engine top and mid block. You can see it very oily or black. You can change the top, and it will not cost you more than S$30 or so. As for the mid block, you can use sealant instead.
Basically it is a stop leak chemical - it stop the leak by treating and expanding the leaking seals volume by 3%. Sutiable for cars over 3 years old and can be used to treat leaks in Tansmission, Differentials, Hydraulics systems, power steering etc.
