Heel & toe technique
Pauly75ts
Paul,
I remember reading somewhere, forgotten the website, there are other technics beside Heel-Toe, you know any website confused.gifconfused.gifconfused.gif
I posted the video link on www.daewootech.com and it sparked a lively discussion over his "twitching" of the throttle.
The answer came from "Audacityracing", that Senna is "feathering" the throttle.
  Quote
a car has the most speed ina corner when it at the instant where it loses traction. if the car breaks loose, speed is lost, but i order to maintain a high speed, you have to "feather" (or twitch if you will) on the trottle.
this prevents you from giving the wheels too much power while maintaining a high speed through the corner. you can break loose in small amount without sacrificing major speed, so the idea would be to cross that line (where traction is lost) as little as possible, but staying as close as possible
mmamdouh points out that Senna is practicing "manual traction control".
Quoting Audacityracing again,
  Quote
you have to look at his driving style, he's got a very powerful rear wheel drive car...
when exiting the corner, a rear wheel car will produce massive oversteer if too much power goes to the wheels, at the same time, if there is not enough power, the same thing will happen where the back end breaks loose (due to weight shift as opposed to reduction in dynamic friction). oversteer caused by reduced friction (wheel spin) is the side of that spectrum that produces the fastes way through the corner.
it's an imaginary boundry (see circle of traction). the closer to the limit of breaking free, the faster the car goes icon_twisted.gif
when it comes to front wheel drive cars, the same can be said for left foot braking...
in a fwd car, understeer occurrs when exiting the corner (and entering most of the time). to provide power to the wheels while maintaining an appropriate weight balance, you can "feather" the brake along with the gas to keep the weight forward (can produce oversteer, but that's easier to correct and control) and keep power to the ground
i can explain more and whip out some telemetry graphs if need be icon_biggrin.gif
Here comes the cheem part with telemetry graphs.
  Quote
this is the circle of traction (sometimes called the circle of friction)
here you can see the direction that forces are applied during travel
ACEELERATION- both negative and positive
if the vehicle is going forward in a straight line, the force is applied to the rear... the front of the car becomes lighter and the rear heavier... this is also why you get thrown into yoru seat
the opposite is true for braking... under perfect braking (strightline) the force is applied forward (why your junk moves around your car when you hit the brakes hard)... the rear becomes lighter and the front becomes heavier
LATERAL ACCELERATION- turning
when the vehicle is in a full wheel lock turn, the forces are applied in the opposite direction than the car is moving (centripital, or centrifugal force). everyone has been thrown into the passenger seat when they turned hard
**note** perfect lateral acceleration (turning) is a condition where there is no change in vehicle speed.
to keep the vehicle under control, you must remain INSIDE the circle... i'll show an example...
you can see that if you braked 100% and turned 100% you would lose control... you are outside the circle.
this circle represents the imaginary line i was talking about... as the car accelerates, it loses it's ability to be controlled, as the car turns, it loses it's ability to be accelerated (slowed or sped up)
you can make this graph 3D by applying the weights of the car. by placing the car's center of gravity on the center of the circle, you can determine handling characteristics. you can do some pretty easy trig and figure out how the weight will shift under each circumstance (assuming you know the corner weights and location of the center of gravity).
one final note (for now)... the size of the circle is determined by the surface , the tires being used, weight, CG, and downforce (driving weight). in the picture below, you can see that wet and icy asphualt SIGNIFICANTLY reduce the size of usable traction.
Finall Audacityracing introduces "feathering"
  Quote
now... to explain his feathering...
he was trying to maintain a perfect turn and throttle for the degree of turning he was performing...
he was trying to stay inside the green circle... by going outside the circle of traction you loose speed by having to correct. by "feathering" the throttle and steering he was able to keep this close area for the turn.
the car may have broken traction 1,000,000 times in that turn, but he always dialed it back in.
the car may have dropped below optimum speed, but he "feathered" to get the car back to optimum speed (considering the turn)
Edited by Genie47
The key note in the posts is the mention of FWD cars. The throttle feathering is for the RWD car but the FWD car needs you to feather the brakes with LFB. He did mention that it is easier to control compared to throttle feathering. sly.gif
this is the toughest part since we don't control the brake well with the left foot, it needs a lot of practise. i would say heel and toe is much easier to learn compared to feathering the brakes with left leg [sweatdrop]
Edited by En0203
Must learn. No choice. Unless you can fork out money for an RWD car (most notably BMW). All cars now are FWD.
BTW, brakes are not as sensitive as throttle. You really have a lot of play.
Then again, if you are racing with your FWD grocery getter, you got to pay more attention to the maintenance of brakes and the brake fluid replacement.
That is why I am completely baffled by all these hoo-ha over CAI and all that. FWD car go tracking better improve brakes first.
Edited by Genie47
in MY RX-7 is around RM$60k to RM$100k [sly]
i am forseeing the same for RX-8 (perfect 50:50 weight distribution) in the next 10 yrs [rolleyes]
not that easy, or maybe my left leg is stupid [whip]
anyway, i just realised my '74 lao pok car is a good car for training
1) u are forced to learn heel & toe and double clutching because u simply can't downshift at high speed without these two [furious]
2) u are forced to use ur left to brake while right to accelerate to dry the drum brakes in the rain after u go thru the water ponding area, otherwise u may not be able to brake later [shocked]
Yes agree esp our left foot is not as sensitive. I've tried LFB b4 & it's hard 2 control. Once in a blue moon I will try when there's no car behind me cos but til nw stil cant increase the sensitive & skill of my LFB [:|] I guess I nid more regular practice.
u are forced to use ur left to brake while right to accelerate to dry the drum brakes in the rain after u go thru the water ponding area, otherwise u may not be able to brake later [sweatdrop][sweatdrop] Flinstones style braking haf 2 b applied if the brakes r nt workin.
Edited by Atlantis_boi
