Port cylinder heads
Spade
I heard that porting your cylinder heads can increase performance - meaning to slightly deepen the cylinder heads and smoothen out all the factory machine marks during the manufacturing process. The only hand ported cars are Integra Type R and European sports cars like Ferrari. I read that it's relatively simple if you know how to remove the engine parts and you can do it yourself if have the tools, but usually would need bead blasting first as a preparation step.
My question is - where can I get this done for good and cheap in sg?
This job is time consuming and should be carried out by professional and therefore cannot be cheap. Porting requires use of special carbid cutters ,air powered high speed grinder, polising pad etc and very good knowledge of cylinder head contructions. Any mis grinding near the inlet and exhaust stem guide areas will render the cylinder head for scrap. The professional will normally smoke test the completed ported head for smooth gase flow to ensure all the grinding/porting are correct.
Go there and they will refer u to nearby shop. I tink the shop belongs to same boss. Anyway, pls call them inform them b4 u go there as they might haf to arrange somethings.
JOHOR BARU
17 & 19, Jalan Permas 10/10,
Bandar Baru Permas Jaya,
Johor Baru,
81750 Johor.
Tel : 07-3885235
Fax : 07-3866957
Boss
thanks for the info bro...what car are you driving? and I suppose you did PnP at this shop in JB? Hows the workmanship and service?
Edited by Sazali
I did on my previous ride. Proton Wira.. change eng to 1.8, P&P, CAI, reprograme ECU, etc... took mi 4 days.. Call and ask b4 u go.. Impt!!!
hi there... do visit us at facebook https://www.facebook.com/nastyportflow.
We offer services on cylinder head modification(Porting and Polishing/Multi-angle Valve job/etc) of any kinds engine model/type for your needed performance. With our new ROTTLER P69 5 - Axis CNC cylinder head, head job can be done more quickly and the most important more accurate.
