Mivec9 1st Gear October 2, 2005 Share October 2, 2005 Hi bros, what's cost of replacing water pump? Found leakage of coolant at engine block location. ↡ Advertisement Link to post Share on other sites More sharing options...
Octopus 3rd Gear October 2, 2005 Share October 2, 2005 I also once encountered water pump leaking. Mine was leaking from the water pump itself. That leaky water pump cause me to have high temperature and radiator water need to top up very frequently. So no choise, replaced the water pump and at the same time changed the timing belt together. Now OK, no more radiator water dissappearing problem. Link to post Share on other sites More sharing options...
Mivec9 1st Gear October 2, 2005 Author Share October 2, 2005 be either going yew tee simon or eunos lee sheng for replacement tomorrow morning. Link to post Share on other sites More sharing options...
Octopus 3rd Gear October 2, 2005 Share October 2, 2005 How's the costs like for the same work at both places? You plan to only replace the water pump or timing belt as well? Link to post Share on other sites More sharing options...
Mivec9 1st Gear October 2, 2005 Author Share October 2, 2005 (edited) juz called lee sheng...their timing belt is gd price...too bad i need the water pump too. Their water pump too ex liao. For my ride, they can give me less $200 (w/o water pump). Simon's is less $300 with water pump..hence will negotiate price with him before going down. My previous mech package lagi better...$240 niah - but tat exclude the fan belt. Apparently the timing belt cost much more than the fan belt. Edited October 2, 2005 by Xtraun Link to post Share on other sites More sharing options...
Mivec9 1st Gear October 2, 2005 Author Share October 2, 2005 i'll be doing all ...that's timing belt, fan belt, oil seals, bearings, waterpump cos planning to use the ride for long term. Link to post Share on other sites More sharing options...
Mivec9 1st Gear October 3, 2005 Author Share October 3, 2005 (edited) did whole package include water pump @ 250...after negotiation Edited October 3, 2005 by Xtraun ↡ Advertisement Link to post Share on other sites More sharing options...
Portable Tyre Pump
Portable Tyre Pump
