Disc brakes vs Drum brakes
Mikeyfingers
u're wrong in this aspect....drums bite better cos they have the self-energizing action...wheras discs dosent...thats explains why cars with discs have a brake servo...or in layman terms...vaccum assisted brakes
drum brakes collect moisture during raining as the water cant slide off in disc brakes. That why you dont see evo, wrx porsche or ferrari having drum brakes. When you life is on the line that extra 10 to 20 percent in braking counts when you are about to hit a tree
But if you drive frequently, heat from the friction will evaporate the moisture. Drum brakes also have got different sizes to accommodate the power of the car too. It's just that disc are more commonly used for the front. If you look at the rear of Vitara you will notice the size of the drum brakes.
Anyway both disc and drum system are mainly hydraulic action it's just that disc is more shiny and pretty to look at.
bro that the problem during rain, no matter how much heat, the moisture wont go away. Like a soup bowl if you hang it vertical water will not sip away. Anyway you wont see performance car having drum brakes. Vitara is a off roader not meant for high speed right
how do we gauge or know that the it's time to change the drum brake?
for disc brake pads at least we can still see,
for drum brake it is all enclosed, how to know when to change?
this is esp difficult if u buy a 2nd hand car and dunno the mileage of when the brakes have been changed be4.
Frankly, I prefer drums over disc, it is more practical and easier to maintain, contrary to many said otherwise. Drums have been superseded by Disc is because of the manufacturer cost and ease of making it. In term of strength, at least for a NORMAL sedan, they give similar braking power but cheaper maintenance cost and easier maintenance. There are better way to spend your money.
so far, u are 1 of a very few person that i came across knowing the diff of disk and drum brake. most of the new bird tot that dick brake are more superior... they are confuse by the ads and marketing people
its true that discs are more effective than drums...to a certain extent...
pros of discs:
better heat disspation
better bite under heavy loads
lesser noise as brake dust is not trapped within the contact area
lesser tendency to jam as the brake dust is not kept within
self adjusting ulike drums
easier maintainence
reduced unsprung weight
cons
expensive to manufacture
poor initial bite as no self energizing action (tts y need 2 have brake booster)
not effective when going thru floods or off road terrains or when discs are wet cos contact area is exposed
not effective as parking brake (which is why theres a drum in disc parking brake @ the rear if yr car is discs all round)
brake pads dosent last as long as the brake shoes
and also we mechanics never like drums cos they're more difficult to maintain compared to discs esp when the drums are siezed to the hub and u have 2 knock them like mad just to get them off...not to mention the amount of brake dust which is trapped inside....
Edited by Qr25vet
execellent comparison of discs versus drums. [thumbsup]
would drums be less likely to have warping of the disc rotors ? [gossip]
i heard that if the car is washed and people splash cold water at the hot disc rotors, there is a high chance of the disc rotor becoming warped and then will have to change them. is it true ? [speechless]
Supercharged
yes, those who knows the real diff between drum and disc brakes, will know that disc are NOT superior to drum
alot of ppl think that modern cars with disc brakes, means that disc brakes are better.
they are no way better than drums
the ony REAL difference is that drum brakes needs abit more maintainance coz of the rubber lining that needs to be checked and changed if it gets thinner. and its not not easy changing that rubber lining.
for disc brakes, its almost maintainance free except for checking the small brake pads.
as for performance areas, they are both the same.
i have driven both old and new cars with drum and all-disc brakes. Hell, no bloody difference.
In fact i need a E brake with an old car with rear drum brakes (no ABS, no fancy marketing gimmick for whatever a new car promises you).
it saves my life and $$...... it stopped in a very very short distance (2 cars' length when i was travelling at 90km/h). I wont dare to say it if it's a modern car with all-disc brakes.
What disc brakes provide is:
1) better heat dissipation than drum brakes, so they maintain their performance longer under sustained use. (Less brake fake)
2) Better performance in wet weather. Drum brakes can trap water inside the drum, while disc brakes quickly shed it off of the rotor.
3) More consistent brake 'feel' and modulation. Drum brakes have a 'self-energizing' effect (essentially, the shoes wedge against the drums) that can be difficult to control.
Ever wondered why some cars have rear drums?
It's mainly to save costs.
The front wheels are still using disc. Why? Because most of the braking force is done one the front.
By fitting disc brakes to the front wheels and drum brakes to the rear wheels, manufacturers can provide most of the benefits of disc brakes while lowering costs. (Drum brakes are less expensive to make than disc brakes, largely because they can also double as a parking brake, whereas disc brakes require a separate parking brake mechanism.)
A good and detail writeup on drum vs disc brakes. [thumbsup]
I'm using drum brakes and it still serve its purpose of braking effectively even in near crash situation.
Not really true on no.2... if u take a look @ those hardcore Offroaders they use Drums as Mud wont get trapped inside...also for wet weather the drums cover up the discs (unless u drive thru a flood) so the chances of water going in is alot less and even if they did get into the drum...they're holes where the water can be drained out almost instantenously....
Supercharged
Wish to ask something about the brakes as well.
Is there any required maintenance for brakes?
Like spraying WD40 on the disc to prevent rust and act as a lubri?
what is the indicative lifespan of brake pad?
eg. like required to change every 20k.
disc using brake pad but what about drum, same as well?
sorry, new to the car stuff
Woah.... Rule number one for brakes DO NOT spray anything on the disc or pad surfaces.
Read this on how brakes work http://www.google.com.sg/url?sa=t&sour...XYxx1YTSxjT4rmA
The rust is just surface rust. It will go away with some braking. There is no hard and fast rule for pad changes. However during servicing, the mech should check to make sure both the pad and disc have sufficient thickness to last till the next servicing.
Maintainence wise, it is just checking the thickness as well as checking the hoses, brake fluid level, and changing of brake fluid every 2 years.
Edited by Elfenstar
When you do your servicing each time, tell the mechanic to service your brakes [nod]
They will take out the pad & apply some greasing whatsoever [nod]
Brake pad only need to change when it wears out [nod]
Depends on individual. I'm still running on my 1st set of brake pad for the front & rear original from factory even though my mileage is 100K ++ liao [:)]
But do remember to change your brake fluid yearly if possible or every 40K servicing [nod]
Edited by Mzrmazda3
