Falc 3rd Gear November 14, 2005 Share November 14, 2005 Try this shop. Prices are very decent, got my varta from them. And they do door step install. Hurry Tyre & Battery Co Category : Tyre Distrs & Mfrs Address : 511 Bt Timah Rd Singapore 259765 Telephone : 6466 3776 ↡ Advertisement Link to post Share on other sites More sharing options...
Fcw75 Hypersonic May 24, 2006 Share May 24, 2006 Is this specs OK for a 1.4L car? 12V 35Ah 335CCA 55RC Link to post Share on other sites More sharing options...
Genie47 1st Gear May 26, 2006 Share May 26, 2006 Most important, what does your car require? The CCA seesm OK for our climate because we have no winters. 35Ah seems puny but the RC is impressive. You still need to meet your car's minimum CCA even though we have no winters. Most cars these days need about 420CCA minimum. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic May 26, 2006 Share May 26, 2006 OK, thanks for the information. Link to post Share on other sites More sharing options...
Dwoon 1st Gear May 26, 2006 Share May 26, 2006 I recently changed my battery and before doing so, I did check with a few manufacturers on using something that is higher rated. The feedback was that as long as the physical size can fit into the compartment, it is fine to use a higher rated battery. Can't remember exactly, but the message seemed to imply that by using a battery that has a higher capacity than required, the life of the battery is also extended somewhat. Link to post Share on other sites More sharing options...
Genie47 1st Gear May 26, 2006 Share May 26, 2006 Higher rated as in RC and Ah but CCA use minimum your car requires because we don't experience winters here. ↡ Advertisement Link to post Share on other sites More sharing options...
NTUC issues…and problems
National Service in Singapore
Shop Houses Collapse at Syed Alwi Road
