Jlim Clutched September 22, 2005 Share September 22, 2005 Oh ok i go look see look see. Thanks! ↡ Advertisement Link to post Share on other sites More sharing options...
Gohtg Neutral Newbie September 22, 2005 Share September 22, 2005 hi bro....i can get brand new Amaron MF battery at a gd price n with 1 year warranty also.what batt. size u using?mi driving civic n the size is NS60.the price is $60 but w/o install....feel free to give mi a call @ 97849512 if u want..only got Amaron batt only..all sizes available.cheers!! Link to post Share on other sites More sharing options...
Crv2004 Clutched September 23, 2005 Share September 23, 2005 My model of the battery is using 46b23l. Like that how much ah??? Link to post Share on other sites More sharing options...
Poortraveller 1st Gear September 23, 2005 Share September 23, 2005 jumper cable lah... simi power cable...u think xbox meh haha ... ok ok ... jump start cable Link to post Share on other sites More sharing options...
Poortraveller 1st Gear September 23, 2005 Share September 23, 2005 this thing not cheap $99.90+$15 shippment cost... i rather call ppl down to change my battery... Link to post Share on other sites More sharing options...
Gohtg Neutral Newbie September 23, 2005 Share September 23, 2005 thats NS60 size....its $60 Link to post Share on other sites More sharing options...
Robin 4th Gear September 23, 2005 Share September 23, 2005 u know how to connect bo... later both battery explode Link to post Share on other sites More sharing options...
Jiayong 3rd Gear September 23, 2005 Share September 23, 2005 you are shot both way. Either you invest to buy a battery starter or pay to join AA. The only other way is jump start or push start. And it doesn't work for maintenance free battery. Why do u think maintenance battery cant be jump started? my last two batteries both died on me. I jump started both of them with another car's battery before changing them. My first one i even use the battery for a few more months after i jump started it. All of them were maintainance free. Link to post Share on other sites More sharing options...
Fortress Clutched September 23, 2005 Share September 23, 2005 (edited) I meant maintenance free battery...If you can use it for a while more, it is still alright....it is probably drained because short, however, when it dies, it is dead. A dead battery cannot be charged. Edited September 23, 2005 by Fortress Link to post Share on other sites More sharing options...
Jiayong 3rd Gear September 23, 2005 Share September 23, 2005 oh i see...i didnt catch the drained and dead part. understood now. Link to post Share on other sites More sharing options...
Fortress Clutched September 23, 2005 Share September 23, 2005 No worries... Link to post Share on other sites More sharing options...
Jlim Clutched September 23, 2005 Share September 23, 2005 i also now then understand Link to post Share on other sites More sharing options...
Jiayong 3rd Gear September 23, 2005 Share September 23, 2005 most impt we all now stand liao.... Link to post Share on other sites More sharing options...
Jlim Clutched September 23, 2005 Share September 23, 2005 now cannot stand, else cannot sleep eh will kena banned or not huh? Link to post Share on other sites More sharing options...
Psfong Clutched November 14, 2005 Share November 14, 2005 My car battery died because of my stupid mistake on Sunday. I called up STAR (DBS Esso free service) to help jumpstart the car. At the same time, I noticed the current battery is quite a goner...(hmmmm, when did i last check it??) So, when the recovery van comes, and they suggest replacing it with a Amaron MF 60Ah battery @ $90 on the spot. I immediately jumped at it as I had the impression it usually costs $100++. Now come to think, is it really worth it? Got ppl selling at $60... here Link to post Share on other sites More sharing options...
Genie47 1st Gear November 14, 2005 Share November 14, 2005 Worth it but before you jumped into it, you should have checked what are the CCA and RC your car needed and not just the capacity at 60Ah. In our climate, CCA isn't a factor so getting the minimum required CCA is good enough. You should aim for a battery with higher RC. So given a couple of batteries with 60Ah but one with higher RC, you should go for the one with higher RC. Link to post Share on other sites More sharing options...
Psfong Clutched November 14, 2005 Share November 14, 2005 What's CCA and RC and how to check them? Anyway, I was using the 60Ah for the previous battery, so I replaced it using the same one. BTW, I found that after changing the new battery. The car is given a new lease of life. The window winds up faster and no straining, the aircon does not squeaking so much also, and best of all, the pickup seems to have improved! Link to post Share on other sites More sharing options...
Genie47 1st Gear November 14, 2005 Share November 14, 2005 (edited) CCA stands for Cold Crank Amps. There is English, US and DIN CCA but whatever it is, not crucial here because CCA is rated at -18 deg C. So it is for the battery's performance in cold conditions but you still need to meet you car's minimum CCA performance. RC stands for reserve capacity. US batteries are rated with RC. Warmer climates, higher RC the better. Why, lasts longer! RC is measured in minutes. This kind of explains why my stock Aveo battery which is a 55Ah, 550CCA but has an RC of 90min. That is pretty high for a battery used in a smallish 1.4L car. Closing to 2yrs with it and the hydrometer indicator is still as green as the day I received the car brand new. Edited November 14, 2005 by Genie47 ↡ Advertisement Link to post Share on other sites More sharing options...
National Service in Singapore
The ownself service car hobbyist! Pls come in Share your lobangs/parts hoot
My EV journey to the i4
Tyre puncture
Tyre puncture
